Hamilton Beach 70740 Motor Replacement
    1. Hamilton Beach 70740 Motor Replacement, Bowl and Lid: step 1, image 1 of 2 Hamilton Beach 70740 Motor Replacement, Bowl and Lid: step 1, image 2 of 2
      • Turn the bowl counterclockwise and lift.
      Ask FixBot
    1. Hamilton Beach 70740 Motor Replacement, Gears: step 2, image 1 of 2 Hamilton Beach 70740 Motor Replacement, Gears: step 2, image 2 of 2
      • Use the nylon spudger to remove the plastic screw covers.
      Ask FixBot
    2. Hamilton Beach 70740 Motor Replacement: step 3, image 1 of 3 Hamilton Beach 70740 Motor Replacement: step 3, image 2 of 3 Hamilton Beach 70740 Motor Replacement: step 3, image 3 of 3
      • Using a #2 Phillips head screwdriver, remove the four 10 mm screws and pull the shaft straight upwards to uncover gears.
      Ask FixBot
    3. Hamilton Beach 70740 Motor Replacement: step 4, image 1 of 2 Hamilton Beach 70740 Motor Replacement: step 4, image 2 of 2
      • Firmly grasp center piece of gear mechanism and pull straight upward.
      Ask FixBot
    1. Hamilton Beach 70740 Motor Replacement, Motor: step 5, image 1 of 2 Hamilton Beach 70740 Motor Replacement, Motor: step 5, image 2 of 2
      • Using a #2 Phillips head screwdriver, remove the two 11 mm screws and pull the rubber suction cups straight up.
      Ask FixBot
    2. Hamilton Beach 70740 Motor Replacement: step 6, image 1 of 3 Hamilton Beach 70740 Motor Replacement: step 6, image 2 of 3 Hamilton Beach 70740 Motor Replacement: step 6, image 3 of 3
      • Using the heavy duty plastic spudger remove the four rubber caps.
      • Using a #2 Phillips head screwdriver, remove the four 11 mm screws inside each of the bases legs.
      • Pull the base straight up to remove it from the processor.
      Ask FixBot
    3. Hamilton Beach 70740 Motor Replacement: step 7, image 1 of 3 Hamilton Beach 70740 Motor Replacement: step 7, image 2 of 3 Hamilton Beach 70740 Motor Replacement: step 7, image 3 of 3
      • Using a #2 Phillips head screwdriver, remove the four 9 mm screws.
      • From the open base pull the motor straight out.
      Ask FixBot
    4. Hamilton Beach 70740 Motor Replacement: step 8, image 1 of 2 Hamilton Beach 70740 Motor Replacement: step 8, image 2 of 2
      • Using the wire stripper crimping tool cut the black wire connection from the power cord to the motor.
      • Using the wire stripper crimping tool strip the ends of each of the black cords and insert them into the opposite ends of a parallel connector, then crimp firmly.
      • Using the wire stripper crimping tool cut the four red wire connections from the switch to the motor and then rewire the four red wires together in a wiring connector cap.
      • Using the wire stripper crimping tool strip the ends of each red wire and insert them into a new wiring connector cap, then crimp firmly.
      Ask FixBot
Travis Williams
552 Reputation
5 Guides authored
USF Tampa, Team 17-4, Blackwell Spring 2017 Member of USF Tampa, Team 17-4, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G4
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 30
All Time: 3,652
