Tools
Introduction
Go to step 1 ↓Be sure to keep the processor unplugged throughout the replacement process.
Tool used on this step:Heavy-Duty Spudger$4.99
Using the heavy duty spudger pry the plastic knob off the front of the processor.
Using a #2 Phillips head screwdriver, remove the two 11 mm screws from the base.
Pull suction cups straight out.
Remove rubber caps using the heavy duty spudger.
Remove the four 11 mm screws using the #2 Phillips head screwdriver.
Pull base straight out.
Cut all four red wires using the wire stripper crimping tool.
Using the wire stripper crimping tool strip the ends of each red wire and insert them into a new wiring connector cap, then crimp firmly.
Cut the white wire using the stripper crimping tool.
Using the wire stripper crimping tool strip the ends of each of the white wires and insert them into the opposite ends of a parallel connector, then crimp firmly.
2 Guide Comments
On our unit the control knob became stuck. Where can I get a new control knob? Do you happen to know the part number?
I used a hair dryer and that did the trick, but am wondering if WD 40 would work as well. I went online e with the company and they want $2.00 for tech advice which is dumb to me. At first I thought it was the locking device on top; it is actually the pulse switch and my machine is just over a year old.
