Up to 20% off select tools
Hamilton Beach 70740 Base Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
83
All Time:
735
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Replacing of processor base. Be sure the processor is unplugged before beginning.
    1. Hamilton Beach 70740 Base Replacement, Bowl and Lid: step 1, image 1 of 2 Hamilton Beach 70740 Base Replacement, Bowl and Lid: step 1, image 2 of 2
      • Turn the bowl counterclockwise and lift.
      Ask FixBot
    1. Hamilton Beach 70740 Base Replacement, Base: step 2, image 1 of 2 Hamilton Beach 70740 Base Replacement, Base: step 2, image 2 of 2
      • Using a #2 Phillips head screwdriver, remove the two 11 mm screws from the base.
      • Pull suction cups straight out.
      Ask FixBot
    2. Hamilton Beach 70740 Base Replacement: step 3, image 1 of 3 Hamilton Beach 70740 Base Replacement: step 3, image 2 of 3 Hamilton Beach 70740 Base Replacement: step 3, image 3 of 3
      Tool used on this step:
      Heavy-Duty Spudger
      Buy
      • Remove rubber caps using the heavy duty spudger.
      • Remove the four 11 mm screws using the #2 Phillips head screwdriver.
      • Pull base straight out.
      Ask FixBot
Author
with
Travis Williams
552 Reputation
5 Guides authored
USF Tampa, Team 17-4, Blackwell Spring 2017 Member of USF Tampa, Team 17-4, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G4
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 83
All Time: 735
