Up to 20% off select tools
Hamilton Beach 70730 Motor Replacement
Views: 7.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
24
Past 30 Days:
124
All Time:
7,321
Comments: 9
2 comments on steps, 7 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 7 - 15 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
Introduction
Go to step 1 ↓
The Hamilton Beach 10-Cup Food Processor & Vegetable Chopper with Bowl Scraper (Model 70730) is a versatile machine that provides the functions of a food processor, food chopper, and vegetable chopper. The device has two speeds plus pulse and 450 watts of power.
This guide outlines the steps to replace the motor connecting the drive shaft to the chopping blade.
Warnings:
  • Be sure device is unplugged before beginning replacement.
  • Be aware of lubricant along the bottom of the drive shaft.
    1. Hamilton Beach 70730 Motor Replacement, Bowl: step 1, image 1 of 1
      • Unscrew the cover by turning it counterclockwise.
      Ask FixBot
    2. Hamilton Beach 70730 Motor Replacement: step 2, image 1 of 1
      • Grab the scraper by the midsection to remove.
      Ask FixBot
    3. Hamilton Beach 70730 Motor Replacement: step 3, image 1 of 1
      • Carefully remove the blades by lifting them off of the blade shaft.
      Ask FixBot
    4. Hamilton Beach 70730 Motor Replacement: step 4, image 1 of 1
      • Rotate the bowl counterclockwise to release it from the base.
      Ask FixBot
    5. Hamilton Beach 70730 Motor Replacement: step 5, image 1 of 1
      • Make sure there is no food or grime along the outside of the bowl or the base.
      Ask FixBot
    1. Hamilton Beach 70730 Motor Replacement, Switch: step 6, image 1 of 1
      • Using a metal spudger, pry the switch from the front of the device.
      Ask FixBot
    1. Hamilton Beach 70730 Motor Replacement, Drive Shaft: step 7, image 1 of 1
      • Using the metal spudger, remove the four adhesive plastic covers that hide the screws.
      • These covers are adhered to the screws.
      Ask FixBot
    2. Hamilton Beach 70730 Motor Replacement: step 8, image 1 of 1
      Tool used on this step:
      Buy
      • Remove any excess glue that is adhered to the screws with the precision tweezers.
      Ask FixBot
    3. Hamilton Beach 70730 Motor Replacement: step 9, image 1 of 1
      • Using a JIS #1 driver, remove the four 10 mm screws.
      Ask FixBot
    4. Hamilton Beach 70730 Motor Replacement: step 10, image 1 of 1
      • Lift the driveshaft off of the base.
      Ask FixBot
    1. Hamilton Beach 70730 Motor Replacement, Motor: step 11, image 1 of 1
      • Reach in and remove the set of 3 gears.
      Ask FixBot
    2. Hamilton Beach 70730 Motor Replacement: step 12, image 1 of 1
      • Remove the four 8 mm JIS #1 screws that were revealed after removing the set of gears.
      • There will be lubricant on the screws.
      Ask FixBot
    3. Hamilton Beach 70730 Motor Replacement: step 13, image 1 of 1
      • Flip the device over so the bottom is visible.
      Ask FixBot
    4. Hamilton Beach 70730 Motor Replacement: step 14, image 1 of 1
      • Using a JIS #1 screwdriver, remove each of the four suction cups that are attached to the bottom of the food processor.
      Ask FixBot
    5. Hamilton Beach 70730 Motor Replacement: step 15, image 1 of 1
      • Using a JIS #1 screwdriver, remove the four 12 mm screws on the bottom.
      • The screws are recessed about 3 mm inside of the device and may not be easily visible.
      Ask FixBot
    6. Hamilton Beach 70730 Motor Replacement: step 16, image 1 of 1
      • Remove the two 4 mm screws underneath the on/off switch with a JIS #1 screwdriver.
      Ask FixBot
    7. Hamilton Beach 70730 Motor Replacement: step 17, image 1 of 1
      • Pull the bottom plate away from the base.
      Ask FixBot
    8. Hamilton Beach 70730 Motor Replacement: step 18, image 1 of 1
      • Using a JIS # 1 screwdriver, remove the three screws on the white bracket.
      Ask FixBot
    9. Hamilton Beach 70730 Motor Replacement: step 19, image 1 of 1
      • Remove the white bracket and guide the wires away from their holders. Be careful not to dislodge the spring held inside the base.
      • Be careful not to dislodge the spring on the cylindrical white piece next to it.
      Ask FixBot
    10. Hamilton Beach 70730 Motor Replacement: step 20, image 1 of 1
      • The motor can now be removed from the inside of the food processor.
      Ask FixBot
5 other people completed this guide.
Author
with
Mack Bernard
639 Reputation
5 Guides authored
7 Guide Comments
Thanks for the guide! I would never have thought to dig through the grease in the gearbox to find the 4 machine screws buried under there. Turns out that my motor is fine, but the thermal fuse strapped to the windings burned out. $5 fix for a $150 device!
Louis H - Reply Share
I didnt see any thermal fuse
Micah the Challenger - Reply Share
Where do I find
On the bottom of the motor, connected to red lead, wrapped in white shielding
Fidel Cashflow - Reply Share
My Hamilton Beach food processor stopped working. So I ordered another bottom part(motor assembly) but t it will not come on either. Are they not interchangeable?
nelda lowe - Reply Share
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 124
All Time: 7,321
