Hamilton Beach 64650 Motor Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
84
All Time:
3,051
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
This page will guide you through the replacement of the motor block in your Hamilton Beach Classic Stand Mixer 64650. You may also find this guide useful to access many other parts in your mixer that you may be experiencing problems with. Although this guide will require the use of a soldering iron, there is a link provided to walk through the process step-by-step.
Tools
    1. Hamilton Beach 64650 Motor Replacement, Motor: step 1, image 1 of 3 Hamilton Beach 64650 Motor Replacement, Motor: step 1, image 2 of 3 Hamilton Beach 64650 Motor Replacement, Motor: step 1, image 3 of 3
      • Flip the handle on its side. Remove five 3.8 mm Philips #2 screws shown and set aside them aside.
      Ask FixBot
    2. Hamilton Beach 64650 Motor Replacement: step 2, image 1 of 3 Hamilton Beach 64650 Motor Replacement: step 2, image 2 of 3 Hamilton Beach 64650 Motor Replacement: step 2, image 3 of 3
      • Remove the four 8.6 mm Philips #2 screws securing the motor mount and place them aside.
      Ask FixBot
    3. Hamilton Beach 64650 Motor Replacement: step 3, image 1 of 3 Hamilton Beach 64650 Motor Replacement: step 3, image 2 of 3 Hamilton Beach 64650 Motor Replacement: step 3, image 3 of 3
      • Carefully pull the motor block out of the case.
      • Collect the two spring located on top of the white beater gears. The springs are held in place with compression, and may fall into the case when the motor is moved.
      • Handle the wires with care to ensure you do not break any of them.
      Ask FixBot
    4. Hamilton Beach 64650 Motor Replacement: step 4, image 1 of 3 Hamilton Beach 64650 Motor Replacement: step 4, image 2 of 3 Hamilton Beach 64650 Motor Replacement: step 4, image 3 of 3
      • Desolder the six wires connected to the motor using this guide.
      • Make sure to note colors when you disconnect them and remember where to reconnect them later.
      Ask FixBot
    5. Hamilton Beach 64650 Motor Replacement: step 5, image 1 of 2 Hamilton Beach 64650 Motor Replacement: step 5, image 2 of 2
      • Once disconnected, the motor will slide out easily.
      Ask FixBot
Gwen Davis
519 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 84
All Time: 3,051
