Up to 20% off select tools
Hamilton Beach 48464 Base Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
5
Past 7 Days:
20
Past 30 Days:
89
All Time:
1,648
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Before starting, you should be sure to unplug the coffee maker. Also, me sure to empty all contents before making any repairs.
    1. Hamilton Beach 48464 Base Replacement, Base: step 1, image 1 of 1
      • This is what the bottom cover will look like. Flip the Brew Station upside down to easily access the screws.
      Ask FixBot
    2. Hamilton Beach 48464 Base Replacement: step 2, image 1 of 3 Hamilton Beach 48464 Base Replacement: step 2, image 2 of 3 Hamilton Beach 48464 Base Replacement: step 2, image 3 of 3
      • Using the Philips 2 Screwdriver, unscrew the three 8-mm screws labeled in a red outline.
      • Using the Crown Bolt #8 Steel Spanner, unscrew the two 8-mm screws labeled in a orange outline.
      Ask FixBot
    3. Hamilton Beach 48464 Base Replacement: step 3, image 1 of 1
      • Carefully slide off the bottom drip tray by sliding it out away from the Brew Station.
      Ask FixBot
    4. Hamilton Beach 48464 Base Replacement: step 4, image 1 of 1
      • Gently lift the base away from the Brew Station.
      Ask FixBot
Author
with
Michael Damico
661 Reputation
6 Guides authored
USF Tampa, Team 14-1, Lacy Spring 2016 Member of USF Tampa, Team 14-1, Lacy Spring 2016
USFT-LACY-S16S14G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 89
All Time: 1,648
