Hamilton Beach 26030 Disassembly
Views: 1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
88
All Time:
1,039
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 55 minutes - 1 hour
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
Hamilton Beach 26030 Waffle Baker
This guide aims to showcase a full disassembly of the Hamilton Beach 26030.
If the machine disassembled has been heavily used, it may contain a significant amount of residue grease, which can tarnish and change the color of cables
We recommend wearing latex gloves for disassembly.
Tools
    1. Hamilton Beach 26030 Disassembly, Hamilton Beach 26030 Disassembly: step 1, image 1 of 2 Hamilton Beach 26030 Disassembly, Hamilton Beach 26030 Disassembly: step 1, image 2 of 2
      • Flip the device so that its underside faces upwards.
      Ask FixBot
    2. Hamilton Beach 26030 Disassembly: step 2, image 1 of 2 Hamilton Beach 26030 Disassembly: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers, remove the four rubber feet on each corner of the base.
      Ask FixBot
    3. Hamilton Beach 26030 Disassembly: step 3, image 1 of 3 Hamilton Beach 26030 Disassembly: step 3, image 2 of 3 Hamilton Beach 26030 Disassembly: step 3, image 3 of 3
      • Using the Phillips #2 screwdriver, remove the six 11.7 mm screws and remove the plastic plate.
      • Using the same screwdriver, remove the four 11.5 mm screws securing the handle brackets to the plastic base. (There should be two on each side.)
      Ask FixBot
    4. Hamilton Beach 26030 Disassembly: step 4, image 1 of 3 Hamilton Beach 26030 Disassembly: step 4, image 2 of 3 Hamilton Beach 26030 Disassembly: step 4, image 3 of 3
      • Flip the device again.
      • Remove the plastic bracket securing the power cord assembly to the base.
      • Gently unclip the handle-end of the device from its plastic bracket.
      Ask FixBot
    5. Hamilton Beach 26030 Disassembly: step 5, image 1 of 2 Hamilton Beach 26030 Disassembly: step 5, image 2 of 2
      • The device assembly is now free from the plastic base.
      • Activate both yellow locks to remove the grid plates from the device.
      • The first lock is a push button.
      • The second is a slide-to-release mechanism.
      Ask FixBot
    6. Hamilton Beach 26030 Disassembly: step 6, image 1 of 2 Hamilton Beach 26030 Disassembly: step 6, image 2 of 2
      • Using the Phillips #2 screwdriver, remove one 13.7 mm screw for the one securing the hinge and one 19.8 mm screw securing the two halves of the handle assembly.
      • With the screws removed, separate both halves of the handle and detach them from the lock assembly.
      Ask FixBot
    7. Hamilton Beach 26030 Disassembly: step 7, image 1 of 2 Hamilton Beach 26030 Disassembly: step 7, image 2 of 2
      • We will now start separating the bottom and top plates.
      • Using the Phillips #2 screwdriver, remove the two 15.8 mm screws on the first hinge assembly cover.
      • Delicately separate the two halves of the device. Be mindful of the cables running between the two sides.
      • Using the Phillips #2 screwdriver, remove the two 15.8 mm screws on the second hinge assembly/cable cover.
      Ask FixBot
    8. Hamilton Beach 26030 Disassembly: step 8, image 1 of 3 Hamilton Beach 26030 Disassembly: step 8, image 2 of 3 Hamilton Beach 26030 Disassembly: step 8, image 3 of 3
      • We will now remove the push-lock side heating element cover assembly.
      • Using the Phillips #2 screwdriver, remove three 9.6 mm screws.
      • Using the same Phillips #2 screwdriver, remove the two 7.7 mm screws securing the lock to the plates.
      • Remove the lock.
      • Remove the heating element cover assembly.
      Ask FixBot
    9. Hamilton Beach 26030 Disassembly: step 9, image 1 of 3 Hamilton Beach 26030 Disassembly: step 9, image 2 of 3 Hamilton Beach 26030 Disassembly: step 9, image 3 of 3
      • We will now remove the pull-lock side heating element cover assembly.
      • Using the Phillips #2 screwdriver, remove two 11.7 mm screws and a single 7.7 mm screw.
      • Using the Phillips #2 screwdriver, remove two 7.7 mm screws and a single 9.6 mm screw to detach the lock assembly.
      Ask FixBot
    10. Hamilton Beach 26030 Disassembly: step 10, image 1 of 1
      • For the first half:
      • Remove the lone lamp.
      • Using the Phillips #2 screwdriver, remove the four 10.1 mm screws and remove the single-lamp cover part.
      • Slide the cables through the hole.
      Ask FixBot
    11. Hamilton Beach 26030 Disassembly: step 11, image 1 of 3 Hamilton Beach 26030 Disassembly: step 11, image 2 of 3 Hamilton Beach 26030 Disassembly: step 11, image 3 of 3
      • For the second half:
      • Using the Phillips #2 screwdriver, remove a single 7.5 mm screw to remove the two LEDs.
      • Remove the four 10.1 mm Phillips #2 screws securing the control knob assembly to the device.
      • Remove the control knob assembly.
      • Make sure to unplug all connectors, and slide the cables through the gap.
      Ask FixBot
    12. Hamilton Beach 26030 Disassembly: step 12, image 1 of 3 Hamilton Beach 26030 Disassembly: step 12, image 2 of 3 Hamilton Beach 26030 Disassembly: step 12, image 3 of 3
      • Remove the two bolts retaining the thermostat.
      • Remove the two exposed springs.
      • Remove the thermostat.
      • You have successfully disassembled the device.
      Ask FixBot
    13. Hamilton Beach 26030 Disassembly: step 13, image 1 of 1
      • The device operates based on a thermostat, which has three settings and an off state.
      • When the knob is set to one of the power-on states, the two heating elements power on in parallel.
      • The red LED indicates that the device is powered on, while both green LEDs (one on each half for convenience) indicate when the device is hot enough to pour the batter in.
      Ask FixBot
1 Guide Comment
Nice write up, thank you!
Mike - Reply Share
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 88
All Time: 1,039
