Hamilton Beach 25460Z Thermal Switch Replacement
  1. Hamilton Beach 25460Z Thermal Switch Replacement, Plug Wiring: step 1, image 1 of 2 Hamilton Beach 25460Z Thermal Switch Replacement, Plug Wiring: step 1, image 2 of 2
    • Unplug your device before proceeding with disassembly.
    • Remove the four 14mm screws from the bottom of the Panini Press using the T10 Screwdriver.
    Ask FixBot
  2. Hamilton Beach 25460Z Thermal Switch Replacement: step 2, image 1 of 1
    • Lift up the plastic cover to expose the plug wiring.
    • Mark the plug wire connected to the red wire with a piece of tape. This will be used as a reference for reassembly.
    Ask FixBot
  3. Hamilton Beach 25460Z Thermal Switch Replacement: step 3, image 1 of 3 Hamilton Beach 25460Z Thermal Switch Replacement: step 3, image 2 of 3 Hamilton Beach 25460Z Thermal Switch Replacement: step 3, image 3 of 3
    • Use the pliers to pinch the widest point of the cap. This should be done opposite of the already existing crimps.
    • Slide off the white cap.
    • Repeat these steps for the second white cap.
    Ask FixBot
  4. Hamilton Beach 25460Z Thermal Switch Replacement: step 4, image 1 of 2 Hamilton Beach 25460Z Thermal Switch Replacement: step 4, image 2 of 2
    • Remove the two rubber screw covers from the bottom of the Panini Press.
    • Remove the four uncovered 10mm screws with the PH2 Screwdriver.
    Ask FixBot
  5. Hamilton Beach 25460Z Thermal Switch Replacement: step 5, image 1 of 2 Hamilton Beach 25460Z Thermal Switch Replacement: step 5, image 2 of 2
    • Lift the plastic lower heating element up and place to the side for reassembly. You have now disconnected the plug wiring completely.
    Ask FixBot
  6. Hamilton Beach 25460Z Thermal Switch Replacement, Thermal Switch: step 6, image 1 of 2 Hamilton Beach 25460Z Thermal Switch Replacement, Thermal Switch: step 6, image 2 of 2
    • Remove the two 10mm screws connecting the thermal switch with the PH2 Screwdriver and a bit of force.
    • These screws may be difficult to remove.
    Ask FixBot
  7. Hamilton Beach 25460Z Thermal Switch Replacement: step 7, image 1 of 1
    • De-solder the connection between the wires and the thermal switch.
    • Refer to this page if you need to brush up on your soldering skills.
    • Replace the thermal switch.
    • The lead on the red (with the small hole), marked in red, connects to the white wire.
    • The lead on the right, marked in blue, connects to the blue wire.
    Ask FixBot
Forrest Rodeman
342 Reputation
2 Guides authored
Cal Poly, Team 6-27, Amido Winter 2015 Member of Cal Poly, Team 6-27, Amido Winter 2015
CPSU-AMIDO-W15S6G27
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 30
All Time: 2,530
