Hair Dryer Power Supply Replacement
  1. Hair Dryer Power Supply Replacement, Nozzle: step 1, image 1 of 2 Hair Dryer Power Supply Replacement, Nozzle: step 1, image 2 of 2
    • Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
    • If nozzle is not attached, skip to next step.
    Ask FixBot
  2. Hair Dryer Power Supply Replacement, Grating: step 2, image 1 of 1
    • Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
    • For most hair dryers, use a Phillips #1 screwdriver. For hair dryers with smaller screws, consider using a Phillips #00 screwdriver.
    Ask FixBot
  3. Hair Dryer Power Supply Replacement: step 3, image 1 of 1
    • Detach the hair dryer grating from the body by gently twisting the grating from side to side.
    Ask FixBot
  4. Hair Dryer Power Supply Replacement: step 4, image 1 of 1
    • Separate the hair dryer grating into the three pieces seen in the image.
    Ask FixBot
  5. Hair Dryer Power Supply Replacement, Power Supply: step 5, image 1 of 1
    • Locate the screws on the handle and remove with a Phillips screwdriver
    Ask FixBot
  6. Hair Dryer Power Supply Replacement: step 6, image 1 of 1
    • Carefully separate the plastic case with Plastic Opening Tools
    Ask FixBot
  7. Hair Dryer Power Supply Replacement: step 7, image 1 of 1
    • Your hairdryer should now be disassembled and you should easily be able to see the fan, motor, heating element cover, and internal wiring.
    Ask FixBot
  8. Hair Dryer Power Supply Replacement: step 8, image 1 of 1
    • After disassembly and isolating the button switchboard, locate the small component that is directly connected to the power cord. Desolder the wires using a desoldering wick and a soldering iron. Refer to the soldering page below.
    • Soldering Skills
    Ask FixBot
Mitch
37 Reputation
5 Guides authored
Cal Poly, Team 24-29, Regan Fall 2012 Member of Cal Poly, Team 24-29, Regan Fall 2012
CPSU-REGAN-F12S24G29
5 Members
11 Guides authored
1 Guide Comment
Will this work on damaged cord near the end of hair dryer? The hair dryer is great shape just the cord that needed to be stripped to get rid of damaged part then cut then wired again.
Donna Baillod - Reply Share
Past 24 Hours: 6
Past 7 Days: 15
Past 30 Days: 62
All Time: 23,118
