Up to 20% off select tools
Hair Dryer Heating Element Replacement
Views: 48K
View statistics:
Past 24 Hours:
8
Past 7 Days:
48
Past 30 Days:
254
All Time:
48,332
Comments: 0
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 2 hours
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Tools
Introduction
Go to step 1 ↓
Is your hair dryer only blowing cold air? You most likely need a new heating element. Use this guide if you are looking to remove and replace a heating element for any standard electric hair dryer. You will save money and learn more about your handheld dryer. For information about soldering/desoldering, please review this guide as it does require specific skills. As always, please solder in a well ventilated area. If your hair dryer is sensitive, be sure sure to work with electrostatic discharge (ESD)-safe tools in an ESD-safe environment.
    1. Hair Dryer Heating Element Replacement, Nozzle: step 1, image 1 of 2 Hair Dryer Heating Element Replacement, Nozzle: step 1, image 2 of 2
      • Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
      • If nozzle is not attached, skip to next step.
      Ask FixBot
    1. Hair Dryer Heating Element Replacement, Grating: step 2, image 1 of 1
      • Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
      • For most hair dryers, use a Phillips #1 screwdriver. For hair dryers with smaller screws, consider using a Phillips #00 screwdriver.
      Ask FixBot
    2. Hair Dryer Heating Element Replacement: step 3, image 1 of 1
      • Detach the hair dryer grating from the body by gently twisting the grating from side to side.
      Ask FixBot
    3. Hair Dryer Heating Element Replacement: step 4, image 1 of 1
      • Separate the hair dryer grating into the three pieces seen in the image.
      Ask FixBot
    1. Hair Dryer Heating Element Replacement, Heating Element: step 5, image 1 of 1
      • Using the Phillips #1 screwdriver remove the two screws holding the handle of the dryer together.
      Ask FixBot
    2. Hair Dryer Heating Element Replacement: step 6, image 1 of 2 Hair Dryer Heating Element Replacement: step 6, image 2 of 2
      • Carefully separate the plastic casing using a spudger. Your hairdryer should now be disassembled into two large halves.
      • This can also be done with your hands if you twist the sides of the hair dryer slightly in opposite directions.
      Ask FixBot
    3. Hair Dryer Heating Element Replacement: step 7, image 1 of 1
      • Remove the heat-element housing by sliding it off of the dryer in the direction away from the handle.
      • Make sure the heating element is facing up so that removal is easier. If there is a casing, slightly twist as needed.
      Ask FixBot
    4. Hair Dryer Heating Element Replacement: step 8, image 1 of 1
      • Isolate the heating element.
      • Use a desoldering wick and soldering iron to desolder the wires.
      • Refer to this soldering page for more information on soldering.
      • You will need to be careful with these wires. Do not cut or yank the wires; this may cause further issues with your hair dryer.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Make sure wiring is enclosed in the body of the hair dryer, and the heating element casing is attached properly before screwing it closed.
9 other people completed this guide.
Author
with
Mitch
37 Reputation
5 Guides authored
Cal Poly, Team 24-29, Regan Fall 2012 Member of Cal Poly, Team 24-29, Regan Fall 2012
CPSU-REGAN-F12S24G29
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 48
Past 30 Days: 254
All Time: 48,332
