Up to 20% off select tools
Hair Dryer Grating Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
86
All Time:
3,382
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
    1. Hair Dryer Grating Replacement, Nozzle: step 1, image 1 of 2 Hair Dryer Grating Replacement, Nozzle: step 1, image 2 of 2
      • Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
      • If nozzle is not attached, skip to next step.
      Ask FixBot
    1. Hair Dryer Grating Replacement, Grating: step 2, image 1 of 1
      • Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
      • For most hair dryers, use a Phillips #1 screwdriver. For hair dryers with smaller screws, consider using a Phillips #00 screwdriver.
      Ask FixBot
    2. Hair Dryer Grating Replacement: step 3, image 1 of 1
      • Detach the hair dryer grating from the body by gently twisting the grating from side to side.
      Ask FixBot
    3. Hair Dryer Grating Replacement: step 4, image 1 of 1
      • Separate the hair dryer grating into the three pieces seen in the image.
      Ask FixBot
Author
with
Mitch
37 Reputation
5 Guides authored
Cal Poly, Team 24-29, Regan Fall 2012 Member of Cal Poly, Team 24-29, Regan Fall 2012
CPSU-REGAN-F12S24G29
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 86
All Time: 3,382
