Hair Dryer Fan/ Motor Assembly Replacement
Views: 19K
View statistics:
Past 24 Hours:
6
Past 7 Days:
40
Past 30 Days:
178
All Time:
18,625
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
Instead of buying a new hairdryer, simply use this guide to replace the motor on your old one!
Tools
    1. Hair Dryer Fan/ Motor Assembly Replacement, Nozzle: step 1, image 1 of 2 Hair Dryer Fan/ Motor Assembly Replacement, Nozzle: step 1, image 2 of 2
      • Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
      • If nozzle is not attached, skip to next step.
      Ask FixBot
    1. Hair Dryer Fan/ Motor Assembly Replacement, Grating: step 2, image 1 of 1
      • Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
      • For most hair dryers, use a Phillips #1 screwdriver. For hair dryers with smaller screws, consider using a Phillips #00 screwdriver.
      Ask FixBot
    2. Hair Dryer Fan/ Motor Assembly Replacement: step 3, image 1 of 1
      • Detach the hair dryer grating from the body by gently twisting the grating from side to side.
      Ask FixBot
    3. Hair Dryer Fan/ Motor Assembly Replacement: step 4, image 1 of 1
      • Separate the hair dryer grating into the three pieces seen in the image.
      Ask FixBot
    1. Hair Dryer Fan/ Motor Assembly Replacement, Fan/ Motor Assembly: step 5, image 1 of 1
      • Locate the screws on the handle and remove with a Phillips screwdriver.
      Ask FixBot
    2. Hair Dryer Fan/ Motor Assembly Replacement: step 6, image 1 of 1
      • Carefully separate the plastic case with the Plastic Opening Tool.
      Ask FixBot
    3. Hair Dryer Fan/ Motor Assembly Replacement: step 7, image 1 of 1
      • After removing the plastic case, locate the fan towards the back of the hair dryer.
      Ask FixBot
    4. Hair Dryer Fan/ Motor Assembly Replacement: step 8, image 1 of 1
      • Remove the screw that is holding the fan to the motor using a Phillips screwdriver.
      Ask FixBot
    5. Hair Dryer Fan/ Motor Assembly Replacement: step 9, image 1 of 1
      • Remove the screws holding the motor to the casing using a Phillips screwdriver.
      • NOTE: This may be unnecessary if the fan can be removed without using a screwdriver.
      Ask FixBot
    6. Hair Dryer Fan/ Motor Assembly Replacement: step 10, image 1 of 1
      • Isolate the fan from the rest of the dryer.
      • Remove the screws holding the motor in place. Replace with the new component.
      Ask FixBot
    7. Hair Dryer Fan/ Motor Assembly Replacement: step 11, image 1 of 1
      • Solder the wires to the motor. Refer to the soldering page below, which will help you replace this component.
      • Soldering Skills
      Ask FixBot
3 other people completed this guide.
Mitch
37 Reputation
5 Guides authored
Cal Poly, Team 24-29, Regan Fall 2012 Member of Cal Poly, Team 24-29, Regan Fall 2012
CPSU-REGAN-F12S24G29
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 40
Past 30 Days: 178
All Time: 18,625
