Hair Dryer Electrical Brushes Replacement
    1. Hair Dryer Electrical Brushes Replacement, Electrical Brushes: step 1, image 1 of 3 Hair Dryer Electrical Brushes Replacement, Electrical Brushes: step 1, image 2 of 3 Hair Dryer Electrical Brushes Replacement, Electrical Brushes: step 1, image 3 of 3
      • Make sure to unplug the device before beginning.
      • Rotate the stainless steel filter counterclockwise and pull upwards to remove it.
      Ask FixBot
    2. Hair Dryer Electrical Brushes Replacement: step 2, image 1 of 2 Hair Dryer Electrical Brushes Replacement: step 2, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the two screws securing the back cover.
      Ask FixBot
    3. Hair Dryer Electrical Brushes Replacement: step 3, image 1 of 3 Hair Dryer Electrical Brushes Replacement: step 3, image 2 of 3 Hair Dryer Electrical Brushes Replacement: step 3, image 3 of 3
      • Lift off the back cover.
      Ask FixBot
    4. Hair Dryer Electrical Brushes Replacement: step 4, image 1 of 3 Hair Dryer Electrical Brushes Replacement: step 4, image 2 of 3 Hair Dryer Electrical Brushes Replacement: step 4, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the two screws securing the dryer motor.
      • Remove the motor from its plastic housing.
      Ask FixBot
    5. Hair Dryer Electrical Brushes Replacement: step 5, image 1 of 3 Hair Dryer Electrical Brushes Replacement: step 5, image 2 of 3 Hair Dryer Electrical Brushes Replacement: step 5, image 3 of 3
      • Unscrew the small plastic cap on the side of the motor and lift out the spring.
      • Remove the carbon electrical brush.
      • Repeat for the cap on the other side of the motor.
      Ask FixBot
    6. Hair Dryer Electrical Brushes Replacement: step 6, image 1 of 3 Hair Dryer Electrical Brushes Replacement: step 6, image 2 of 3 Hair Dryer Electrical Brushes Replacement: step 6, image 3 of 3
      • Install the new carbon brushes, and screw the caps back on.
      • Make sure the spring beneath the cap is properly positioned before tightening,
      Ask FixBot
    7. Hair Dryer Electrical Brushes Replacement: step 7, image 1 of 3 Hair Dryer Electrical Brushes Replacement: step 7, image 2 of 3 Hair Dryer Electrical Brushes Replacement: step 7, image 3 of 3
      • Place the motor back into the housing.
      • Rotate the motor clockwise to screw it into place.
      • Refasten the two motor screws using a Phillips #1 screwdriver.
      Ask FixBot
    8. Hair Dryer Electrical Brushes Replacement: step 8, image 1 of 3 Hair Dryer Electrical Brushes Replacement: step 8, image 2 of 3 Hair Dryer Electrical Brushes Replacement: step 8, image 3 of 3
      • Place the white wires coming off the motor back in the slots.
      • Place the diode in the slots.
      Ask FixBot
    9. Hair Dryer Electrical Brushes Replacement: step 9, image 1 of 2 Hair Dryer Electrical Brushes Replacement: step 9, image 2 of 2
      • Set the power cord back in its slot.
      Ask FixBot
    10. Hair Dryer Electrical Brushes Replacement: step 10, image 1 of 3 Hair Dryer Electrical Brushes Replacement: step 10, image 2 of 3 Hair Dryer Electrical Brushes Replacement: step 10, image 3 of 3
      • Reinstall the back cover.
      Ask FixBot
    11. Hair Dryer Electrical Brushes Replacement: step 11, image 1 of 3 Hair Dryer Electrical Brushes Replacement: step 11, image 2 of 3 Hair Dryer Electrical Brushes Replacement: step 11, image 3 of 3
      • Place the two screws back in place and tighten them with a Phillips #1 screwdriver.
      Ask FixBot
Enjoy your functional hair dryer!
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 68
All Time: 2,578
