Haiboxing 18859 Remote Motherboard Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
63
All Time:
372
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 35 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
When your Haiboxing 18859 isn't responding to inputs from the remote properly, it's likely that the remote's receiver is broken. In order to replace the receiver of the remote, the motherboard inside of the remote will need to be replaced. This is due to the fact that the receiver is directly incorporated in the motherboard. It is also important to note that in order to remove the motherboard, it must be desoldered.
Tools
    1. Haiboxing 18859 Remote Motherboard Replacement, Remote Motherboard: step 1, image 1 of 3 Haiboxing 18859 Remote Motherboard Replacement, Remote Motherboard: step 1, image 2 of 3 Haiboxing 18859 Remote Motherboard Replacement, Remote Motherboard: step 1, image 3 of 3
      • Remove all of five 8 mm Phillips #0 screws holding the back of the plastic shell of the remote in place.
      Ask FixBot
    2. Haiboxing 18859 Remote Motherboard Replacement: step 2, image 1 of 3 Haiboxing 18859 Remote Motherboard Replacement: step 2, image 2 of 3 Haiboxing 18859 Remote Motherboard Replacement: step 2, image 3 of 3
      • Lift the back shell off of the remote.
      Ask FixBot
    3. Haiboxing 18859 Remote Motherboard Replacement: step 3, image 1 of 3 Haiboxing 18859 Remote Motherboard Replacement: step 3, image 2 of 3 Haiboxing 18859 Remote Motherboard Replacement: step 3, image 3 of 3
      • Remove the two 6 mm Phillips #00 screws holding the motherboard in place.
      • Remove the motherboard by desoldering it.
      • In order to replace the receiver of the remote, the motherboard will need to be replaced. This is because the receiver is part of the motherboard. In order to do that, remove the wires connecting the motherboard to the remote. A guide on soldering and desoldering connections can be found here.
      Ask FixBot
NMiedema
317 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 63
All Time: 372
