Haiboxing 18859 Motor Replacement
    1. Haiboxing 18859 Motor Replacement, Battery: step 1, image 1 of 3 Haiboxing 18859 Motor Replacement, Battery: step 1, image 2 of 3 Haiboxing 18859 Motor Replacement, Battery: step 1, image 3 of 3
      • Remove the 4 clips holding down the hard plastic shell of the RC car. Do this by pinching them with your thumb and index finger and pulling away.
      Ask FixBot
    2. Haiboxing 18859 Motor Replacement: step 2, image 1 of 1
      • Lift the hard plastic shell off of the RC car.
      Ask FixBot
    3. Haiboxing 18859 Motor Replacement: step 3, image 1 of 3 Haiboxing 18859 Motor Replacement: step 3, image 2 of 3 Haiboxing 18859 Motor Replacement: step 3, image 3 of 3
      • Disconnect the Lego-style battery connector by gripping either side and pulling them away from each other, slowly and consistently.
      Ask FixBot
    4. Haiboxing 18859 Motor Replacement: step 4, image 1 of 3 Haiboxing 18859 Motor Replacement: step 4, image 2 of 3 Haiboxing 18859 Motor Replacement: step 4, image 3 of 3
      • Unfasten the Velcro strap that secures the battery.
      Ask FixBot
    5. Haiboxing 18859 Motor Replacement: step 5, image 1 of 2 Haiboxing 18859 Motor Replacement: step 5, image 2 of 2
      • Remove the battery.
      Ask FixBot
    1. Haiboxing 18859 Motor Replacement, Motor: step 6, image 1 of 1
      • Unplug the motor from the receiver.
      Ask FixBot
    2. Haiboxing 18859 Motor Replacement: step 7, image 1 of 1
      • Peel back the warning tape covering the motor.
      Ask FixBot
    3. Haiboxing 18859 Motor Replacement: step 8, image 1 of 3 Haiboxing 18859 Motor Replacement: step 8, image 2 of 3 Haiboxing 18859 Motor Replacement: step 8, image 3 of 3
      • Unscrew the 10 mm Phillips #0 screws holding down the motor. This includes the shaft attached down the middle.
      • Place the mounting screws where you won't lose them, such as in a plastic bag or container.
      Ask FixBot
    4. Haiboxing 18859 Motor Replacement: step 9, image 1 of 3 Haiboxing 18859 Motor Replacement: step 9, image 2 of 3 Haiboxing 18859 Motor Replacement: step 9, image 3 of 3
      • Unscrew the 16 mm Phillips #1 screws at the rear of the Haiboxing.
      Ask FixBot
    5. Haiboxing 18859 Motor Replacement: step 10, image 1 of 2 Haiboxing 18859 Motor Replacement: step 10, image 2 of 2
      • Remove the upwards facing rear-most 8 mm Phillips #1 screws.
      • Remove the trapezoid-shaped part.
      Ask FixBot
    6. Haiboxing 18859 Motor Replacement: step 11, image 1 of 1
      • Lift out the motor and the shaft it is attached to.
      Ask FixBot
    7. Haiboxing 18859 Motor Replacement: step 12, image 1 of 1
      • Remove the 6 mm Phillips #0 screw holding the motor to the black, plastic shaft.
      Ask FixBot
    8. Haiboxing 18859 Motor Replacement: step 13, image 1 of 2 Haiboxing 18859 Motor Replacement: step 13, image 2 of 2
      • Flip over.
      • Detach the shaft from motor.
      Ask FixBot
    9. Haiboxing 18859 Motor Replacement: step 14, image 1 of 3 Haiboxing 18859 Motor Replacement: step 14, image 2 of 3 Haiboxing 18859 Motor Replacement: step 14, image 3 of 3
      • Remove the remaining 6 mm Phillips #0 screw holding black, plastic washer in place.
      • Remove the black, plastic washer.
      • Remove the red, paper washer.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Ty.
219 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 49
All Time: 737
