Video Guide
This guide was transcribed from a YouTube video.
Tools
Introduction
Go to step 1 ↓Use this guide to begin disassembling a Hafury Umax for repair access, including access toward the charging or power connector. This guide covers safe preparation and removal of the visible screws only. It doesn't cover advanced repairs, soldering, connector replacement, or reassembly.
Step 1 Prepare the phone
Power off the Hafury Umax and unplug the charging cable before you begin.
Work on a clean, dry, static-safe surface with good lighting.
Step 2 Position the phone
Place the phone on the work surface with the visible screw heads facing up.
Step 3 Remove the visible screws
Use a precision screwdriver to remove the visible screws from the exposed phone frame.
Keep the screwdriver straight and press down firmly enough to avoid stripping the screw heads.
Step 4 Stop at the basic disassembly point
Check that no visible screws remain in the area you plan to access.
Stop here if you only need the basic disassembly covered by this guide.
The Hafury Umax is ready for a component-specific repair guide. Repair didn't go as planned? Try some basic troubleshooting, or ask our Answers community for help.
