Up to 20% off select tools
HVAC Filter Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
104
All Time:
1,263
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide is for filter replacement of air conditioning. This replacement is needed to allow proper airflow while preventing particles from leaving the vent. I purchased the filter in Home Depot. Make sure to know the dimensions of the vent opening as there are filters with different dimensions. Additionally, there are 5 categories of filters and are rated by how effective they are. I bought a filter with a score of 9 out of 10 so choose one that meets your budget.
    1. HVAC Filter Replacement, Filter: step 1, image 1 of 1
      • Observe your air conditioning vent. If the filter appears to be dirty or damaged, then it is time to change it.
      Ask FixBot
    2. HVAC Filter Replacement: step 2, image 1 of 1
      • Remove the screws on the vent cover. There should be a minimum of 4 screws in each corner of the vent.
      • The screws in this vent are phillips hex head screws that are 1 3/4 in. long.
      Ask FixBot
    3. HVAC Filter Replacement: step 3, image 1 of 1
      • Grab a screwdriver with a hex head attachment to remove the screws. Grab the screwdriver and place it on the head of the screw. Twist in a counterclockwise motion until the screw is removed. Repeat for every screw.
      Ask FixBot
    4. HVAC Filter Replacement: step 4, image 1 of 1
      • Remove the vent cover to access the ventilation filter.
      Ask FixBot
    5. HVAC Filter Replacement: step 5, image 1 of 1
      • Optional: Put on a latex glove on the hand that you will use to remove the filter.
      Ask FixBot
    6. HVAC Filter Replacement: step 6, image 1 of 1
      • Remove the filter carefully.
      • Make sure to remove it slowly so that the dust does not come of it.
      Ask FixBot
    7. HVAC Filter Replacement: step 7, image 1 of 1
      • Dispose of the old filter in a waste bin.
      Ask FixBot
    8. HVAC Filter Replacement: step 8, image 1 of 1
      • Buy a Honeywell Air Filter from Home Depot and make sure to buy the filter with the correct dimensions.
      • The dimensions for filters will vary depending on the dimensions of the vent.
      • In this case, my vent was 14x25x1 and thus needed a filter with the same dimensions.
      Ask FixBot
    9. HVAC Filter Replacement: step 9, image 1 of 1
      • Place the new filter into the vent opening. Make sure that it is facing the right direction.
      • There will be an arrow on the side of the filter showing which way to place it.
      Ask FixBot
    10. HVAC Filter Replacement: step 10, image 1 of 1
      • Place vent cover.
      Ask FixBot
    11. HVAC Filter Replacement: step 11, image 1 of 1
      • Grab the same screws that were taken out at Step 3 and use them to secure the vent cover.
      • Place the screwdriver on the head of the screw and twist in a clockwise motion until screw is secure.
      • Repeat for every screw.
      Ask FixBot
    12. HVAC Filter Replacement: step 12, image 1 of 1
      • Turn on your air conditioner to make sure the filter does not move.
      • If the filter does not move, then you have successfully replaced the filter of your air conditioner.
      Ask FixBot
2 other people completed this guide.
Author
with
Anthony Estevez
67 Reputation
1 Guide authored
CSU Los Angeles, Team 2-1, Briggs Fall 2023 Member of CSU Los Angeles, Team 2-1, Briggs Fall 2023
CSULA-BRIGGS-F23S2G1
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 104
All Time: 1,263
