HTC Wizard 200 Speakers Replacement
    1. HTC Wizard 200 Speakers Replacement, Battery: step 1, image 1 of 2 HTC Wizard 200 Speakers Replacement, Battery: step 1, image 2 of 2
      • To expose the battery, remove the outer case with your fingernail.
      • Remove the battery by pulling the black tab.
      Ask FixBot
    1. HTC Wizard 200 Speakers Replacement, Back Panel: step 2, image 1 of 1
      Tool used on this step:
      Spudger
      $3.99
      Buy
      • Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
      Ask FixBot
    2. HTC Wizard 200 Speakers Replacement: step 3, image 1 of 2 HTC Wizard 200 Speakers Replacement: step 3, image 2 of 2
      Spudger
      $3.99
      Buy
      • Work the spudger around the edges of the camera cover until it comes off.
      Ask FixBot
    3. HTC Wizard 200 Speakers Replacement: step 4, image 1 of 2 HTC Wizard 200 Speakers Replacement: step 4, image 2 of 2
      T5 Torx Screwdriver
      $5.49
      Buy
      • Remove the four 6 mm screws with the T5 Torx screwdriver.
      • One of the screws is under the "void" sticker.
      Ask FixBot
    4. HTC Wizard 200 Speakers Replacement: step 5, image 1 of 3 HTC Wizard 200 Speakers Replacement: step 5, image 2 of 3 HTC Wizard 200 Speakers Replacement: step 5, image 3 of 3
      • Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
      • Work the tool around the edges until all the clips release.
      Ask FixBot
    5. HTC Wizard 200 Speakers Replacement: step 6, image 1 of 2 HTC Wizard 200 Speakers Replacement: step 6, image 2 of 2
      • Once all the clips are open, remove the inner panel from the phone.
      Ask FixBot
    1. HTC Wizard 200 Speakers Replacement, Speakers: step 7, image 1 of 2 HTC Wizard 200 Speakers Replacement, Speakers: step 7, image 2 of 2
      • Device rotated 180 degrees.
      • Use the plastic opening tool to disconnect the speaker connections.
      Ask FixBot
Kyle Champ
225 Reputation
12 Guides authored
Cal Poly, Team 20-27, Maness Fall 2011 Member of Cal Poly, Team 20-27, Maness Fall 2011
CPSU-MANESS-F11S20G27
4 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 36
All Time: 1,121
