Up to 20% off select tools
HTC Wizard 200 Motherboard Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
5
Past 7 Days:
25
Past 30 Days:
97
All Time:
1,835
Comments: 0
Go to guide comments
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 40 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your HTC Wizard 200 is frequently restarting, not turning on, or not transferring data, you may need to replace the motherboard. The motherboard is the control panel of the phone.
Follow the below steps to replace your HTC Wizard 200 motherboard.
Note: The motherboard is a very delicate structure and must be handled with care.
    1. HTC Wizard 200 Motherboard Replacement, Battery: step 1, image 1 of 2 HTC Wizard 200 Motherboard Replacement, Battery: step 1, image 2 of 2
      • To expose the battery, remove the outer case with your fingernail.
      • Remove the battery by pulling the black tab.
      Ask FixBot
    1. HTC Wizard 200 Motherboard Replacement, Back Panel: step 2, image 1 of 1
      Tool used on this step:
      Spudger
      $3.99
      Buy
      • Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
      Ask FixBot
    2. HTC Wizard 200 Motherboard Replacement: step 3, image 1 of 2 HTC Wizard 200 Motherboard Replacement: step 3, image 2 of 2
      Spudger
      $3.99
      Buy
      • Work the spudger around the edges of the camera cover until it comes off.
      Ask FixBot
    3. HTC Wizard 200 Motherboard Replacement: step 4, image 1 of 2 HTC Wizard 200 Motherboard Replacement: step 4, image 2 of 2
      T5 Torx Screwdriver
      $5.49
      Buy
      • Remove the four 6 mm screws with the T5 Torx screwdriver.
      • One of the screws is under the "void" sticker.
      Ask FixBot
    4. HTC Wizard 200 Motherboard Replacement: step 5, image 1 of 3 HTC Wizard 200 Motherboard Replacement: step 5, image 2 of 3 HTC Wizard 200 Motherboard Replacement: step 5, image 3 of 3
      • Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
      • Work the tool around the edges until all the clips release.
      Ask FixBot
    5. HTC Wizard 200 Motherboard Replacement: step 6, image 1 of 2 HTC Wizard 200 Motherboard Replacement: step 6, image 2 of 2
      • Once all the clips are open, remove the inner panel from the phone.
      Ask FixBot
    1. HTC Wizard 200 Motherboard Replacement, Motherboard: step 7, image 1 of 1
      Spudger
      $3.99
      Buy
      • Use the spudger to pry the camera off.
      Ask FixBot
    2. HTC Wizard 200 Motherboard Replacement: step 8, image 1 of 2 HTC Wizard 200 Motherboard Replacement: step 8, image 2 of 2
      Buy
      • Using tweezers, flip the connector latch away from the motherboard.
      • Detach the flexible connection from under the connector latch.
      Ask FixBot
    3. HTC Wizard 200 Motherboard Replacement: step 9, image 1 of 1
      • Slide the keyboard into the open position.
      Ask FixBot
    4. HTC Wizard 200 Motherboard Replacement: step 10, image 1 of 2 HTC Wizard 200 Motherboard Replacement: step 10, image 2 of 2
      Spudger
      $3.99
      Buy
      • Lift the motherboard out of the case using the spudger.
      • Expose the underside of the motherboard using your hands.
      Ask FixBot
    5. HTC Wizard 200 Motherboard Replacement: step 11, image 1 of 2 HTC Wizard 200 Motherboard Replacement: step 11, image 2 of 2
      • Remove the flexible connection from the motherboard.
      • Caution: Removing the connection too fast may cause damage to the connection and cables.
      Ask FixBot
Author
with
Kyle Champ
225 Reputation
12 Guides authored
Cal Poly, Team 20-27, Maness Fall 2011 Member of Cal Poly, Team 20-27, Maness Fall 2011
CPSU-MANESS-F11S20G27
4 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 97
All Time: 1,835
