Up to 20% off select tools
HTC Wizard 200 LCD Screen Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
87
All Time:
1,651
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will explain how to install / remove the LCD screen from the HTC Wizard 200.
    1. HTC Wizard 200 LCD Screen Replacement, Battery: step 1, image 1 of 2 HTC Wizard 200 LCD Screen Replacement, Battery: step 1, image 2 of 2
      • To expose the battery, remove the outer case with your fingernail.
      • Remove the battery by pulling the black tab.
      Ask FixBot
    1. HTC Wizard 200 LCD Screen Replacement, Back Panel: step 2, image 1 of 1
      Tool used on this step:
      Spudger
      $3.99
      Buy
      • Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
      Ask FixBot
    2. HTC Wizard 200 LCD Screen Replacement: step 3, image 1 of 2 HTC Wizard 200 LCD Screen Replacement: step 3, image 2 of 2
      Spudger
      $3.99
      Buy
      • Work the spudger around the edges of the camera cover until it comes off.
      Ask FixBot
    3. HTC Wizard 200 LCD Screen Replacement: step 4, image 1 of 2 HTC Wizard 200 LCD Screen Replacement: step 4, image 2 of 2
      T5 Torx Screwdriver
      $5.49
      Buy
      • Remove the four 6 mm screws with the T5 Torx screwdriver.
      • One of the screws is under the "void" sticker.
      Ask FixBot
    4. HTC Wizard 200 LCD Screen Replacement: step 5, image 1 of 3 HTC Wizard 200 LCD Screen Replacement: step 5, image 2 of 3 HTC Wizard 200 LCD Screen Replacement: step 5, image 3 of 3
      • Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
      • Work the tool around the edges until all the clips release.
      Ask FixBot
    5. HTC Wizard 200 LCD Screen Replacement: step 6, image 1 of 2 HTC Wizard 200 LCD Screen Replacement: step 6, image 2 of 2
      • Once all the clips are open, remove the inner panel from the phone.
      Ask FixBot
    1. HTC Wizard 200 LCD Screen Replacement, Motherboard: step 7, image 1 of 1
      Spudger
      $3.99
      Buy
      • Use the spudger to pry the camera off.
      Ask FixBot
    2. HTC Wizard 200 LCD Screen Replacement: step 8, image 1 of 2 HTC Wizard 200 LCD Screen Replacement: step 8, image 2 of 2
      Buy
      • Using tweezers, flip the connector latch away from the motherboard.
      • Detach the flexible connection from under the connector latch.
      Ask FixBot
    3. HTC Wizard 200 LCD Screen Replacement: step 9, image 1 of 1
      • Slide the keyboard into the open position.
      Ask FixBot
    4. HTC Wizard 200 LCD Screen Replacement: step 10, image 1 of 2 HTC Wizard 200 LCD Screen Replacement: step 10, image 2 of 2
      Spudger
      $3.99
      Buy
      • Lift the motherboard out of the case using the spudger.
      • Expose the underside of the motherboard using your hands.
      Ask FixBot
    5. HTC Wizard 200 LCD Screen Replacement: step 11, image 1 of 2 HTC Wizard 200 LCD Screen Replacement: step 11, image 2 of 2
      • Remove the flexible connection from the motherboard.
      • Caution: Removing the connection too fast may cause damage to the connection and cables.
      Ask FixBot
    1. HTC Wizard 200 LCD Screen Replacement, Keyboard Slider: step 12, image 1 of 3 HTC Wizard 200 LCD Screen Replacement, Keyboard Slider: step 12, image 2 of 3 HTC Wizard 200 LCD Screen Replacement, Keyboard Slider: step 12, image 3 of 3
      T5 Torx Screwdriver
      $5.49
      Buy
      • Remove the four 5mm screws with the T5 Torx screwdriver.
      • Remove the keyboard slider from the main body.
      Ask FixBot
    1. HTC Wizard 200 LCD Screen Replacement, Screen Cover: step 13, image 1 of 2 HTC Wizard 200 LCD Screen Replacement, Screen Cover: step 13, image 2 of 2
      • Use the T5 Torx screwdriver to remove four 5mm screws that secure the back of the screen casing.
      Ask FixBot
    2. HTC Wizard 200 LCD Screen Replacement: step 14, image 1 of 2 HTC Wizard 200 LCD Screen Replacement: step 14, image 2 of 2
      • Insert the plastic opening tool between the front panel and the rear panel and pry open to reach the screen.
      Ask FixBot
    3. HTC Wizard 200 LCD Screen Replacement: step 15, image 1 of 2 HTC Wizard 200 LCD Screen Replacement: step 15, image 2 of 2
      • Once the rear panel is loose, lift it off of the front panel.
      • The flexible connection will pop loose.
      Ask FixBot
    4. HTC Wizard 200 LCD Screen Replacement: step 16, image 1 of 1
      • Device rotated 90 degrees CCW.
      • Remove the yellow anti-static tape.
      Ask FixBot
    5. HTC Wizard 200 LCD Screen Replacement: step 17, image 1 of 2 HTC Wizard 200 LCD Screen Replacement: step 17, image 2 of 2
      • Unscrew the two 3mm phillips #0 screws from the bottom of the device that secure the rigid flex board to the screen panel.
      Ask FixBot
    6. HTC Wizard 200 LCD Screen Replacement: step 18, image 1 of 1
      • Device rotated 180 degrees CW.
      • Unscrew the two 3mm Phillips #0 screws from the top of the device that secure the rigid flex board to the screen panel.
      Ask FixBot
    7. HTC Wizard 200 LCD Screen Replacement: step 19, image 1 of 1
      • Unhinge the flexible connection and use the tweezers to disconnect.
      Ask FixBot
    8. HTC Wizard 200 LCD Screen Replacement: step 20, image 1 of 1
      • Now that the rigid flex board is loose, remove it from the screen.
      Ask FixBot
    1. HTC Wizard 200 LCD Screen Replacement, LCD Screen: step 21, image 1 of 2 HTC Wizard 200 LCD Screen Replacement, LCD Screen: step 21, image 2 of 2
      • Simply pull out the loose screen.
      Ask FixBot
Author
with
Kyle Champ
225 Reputation
12 Guides authored
Cal Poly, Team 20-27, Maness Fall 2011 Member of Cal Poly, Team 20-27, Maness Fall 2011
CPSU-MANESS-F11S20G27
4 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 87
All Time: 1,651
