Up to 20% off select tools
HTC Wizard 200 Keypad Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
91
All Time:
1,313
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
Introduction
Go to step 1 ↓
This guide will explain how to install / remove the keypad from the HTC Wizard 200.
    1. HTC Wizard 200 Keypad Replacement, Battery: step 1, image 1 of 2 HTC Wizard 200 Keypad Replacement, Battery: step 1, image 2 of 2
      • To expose the battery, remove the outer case with your fingernail.
      • Remove the battery by pulling the black tab.
      Ask FixBot
    1. HTC Wizard 200 Keypad Replacement, Back Panel: step 2, image 1 of 1
      Tool used on this step:
      Spudger
      $3.99
      Buy
      • Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
      Ask FixBot
    2. HTC Wizard 200 Keypad Replacement: step 3, image 1 of 2 HTC Wizard 200 Keypad Replacement: step 3, image 2 of 2
      Spudger
      $3.99
      Buy
      • Work the spudger around the edges of the camera cover until it comes off.
      Ask FixBot
    3. HTC Wizard 200 Keypad Replacement: step 4, image 1 of 2 HTC Wizard 200 Keypad Replacement: step 4, image 2 of 2
      T5 Torx Screwdriver
      $5.49
      Buy
      • Remove the four 6 mm screws with the T5 Torx screwdriver.
      • One of the screws is under the "void" sticker.
      Ask FixBot
    4. HTC Wizard 200 Keypad Replacement: step 5, image 1 of 3 HTC Wizard 200 Keypad Replacement: step 5, image 2 of 3 HTC Wizard 200 Keypad Replacement: step 5, image 3 of 3
      • Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
      • Work the tool around the edges until all the clips release.
      Ask FixBot
    5. HTC Wizard 200 Keypad Replacement: step 6, image 1 of 2 HTC Wizard 200 Keypad Replacement: step 6, image 2 of 2
      • Once all the clips are open, remove the inner panel from the phone.
      Ask FixBot
    1. HTC Wizard 200 Keypad Replacement, Motherboard: step 7, image 1 of 1
      Spudger
      $3.99
      Buy
      • Use the spudger to pry the camera off.
      Ask FixBot
    2. HTC Wizard 200 Keypad Replacement: step 8, image 1 of 2 HTC Wizard 200 Keypad Replacement: step 8, image 2 of 2
      Buy
      • Using tweezers, flip the connector latch away from the motherboard.
      • Detach the flexible connection from under the connector latch.
      Ask FixBot
    3. HTC Wizard 200 Keypad Replacement: step 9, image 1 of 1
      • Slide the keyboard into the open position.
      Ask FixBot
    4. HTC Wizard 200 Keypad Replacement: step 10, image 1 of 2 HTC Wizard 200 Keypad Replacement: step 10, image 2 of 2
      Spudger
      $3.99
      Buy
      • Lift the motherboard out of the case using the spudger.
      • Expose the underside of the motherboard using your hands.
      Ask FixBot
    5. HTC Wizard 200 Keypad Replacement: step 11, image 1 of 2 HTC Wizard 200 Keypad Replacement: step 11, image 2 of 2
      • Remove the flexible connection from the motherboard.
      • Caution: Removing the connection too fast may cause damage to the connection and cables.
      Ask FixBot
    1. HTC Wizard 200 Keypad Replacement, Keyboard Slider: step 12, image 1 of 3 HTC Wizard 200 Keypad Replacement, Keyboard Slider: step 12, image 2 of 3 HTC Wizard 200 Keypad Replacement, Keyboard Slider: step 12, image 3 of 3
      T5 Torx Screwdriver
      $5.49
      Buy
      • Remove the four 5mm screws with the T5 Torx screwdriver.
      • Remove the keyboard slider from the main body.
      Ask FixBot
    1. HTC Wizard 200 Keypad Replacement, Keypad: step 13, image 1 of 2 HTC Wizard 200 Keypad Replacement, Keypad: step 13, image 2 of 2
      • Use a screwdriver to remove eight 2mm Phillips screws that secure the keypad to the keyboard slider.
      Ask FixBot
    2. HTC Wizard 200 Keypad Replacement: step 14, image 1 of 2 HTC Wizard 200 Keypad Replacement: step 14, image 2 of 2
      • Use the plastic opening tool to gently lift up the keypad.
      Ask FixBot
Author
with
Kyle Champ
225 Reputation
12 Guides authored
Cal Poly, Team 20-27, Maness Fall 2011 Member of Cal Poly, Team 20-27, Maness Fall 2011
CPSU-MANESS-F11S20G27
4 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 91
All Time: 1,313
