Up to 20% off select tools
HTC Wizard 200 Keyboard Slider Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
92
All Time:
1,633
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Tools
    1. HTC Wizard 200 Keyboard Slider Replacement, Battery: step 1, image 1 of 2 HTC Wizard 200 Keyboard Slider Replacement, Battery: step 1, image 2 of 2
      • To expose the battery, remove the outer case with your fingernail.
      • Remove the battery by pulling the black tab.
      Ask FixBot
    1. HTC Wizard 200 Keyboard Slider Replacement, Back Panel: step 2, image 1 of 1
      Tool used on this step:
      Spudger
      $3.99
      Buy
      • Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
      Ask FixBot
    2. HTC Wizard 200 Keyboard Slider Replacement: step 3, image 1 of 2 HTC Wizard 200 Keyboard Slider Replacement: step 3, image 2 of 2
      Spudger
      $3.99
      Buy
      • Work the spudger around the edges of the camera cover until it comes off.
      Ask FixBot
    3. HTC Wizard 200 Keyboard Slider Replacement: step 4, image 1 of 2 HTC Wizard 200 Keyboard Slider Replacement: step 4, image 2 of 2
      T5 Torx Screwdriver
      $5.49
      Buy
      • Remove the four 6 mm screws with the T5 Torx screwdriver.
      • One of the screws is under the "void" sticker.
      Ask FixBot
    4. HTC Wizard 200 Keyboard Slider Replacement: step 5, image 1 of 3 HTC Wizard 200 Keyboard Slider Replacement: step 5, image 2 of 3 HTC Wizard 200 Keyboard Slider Replacement: step 5, image 3 of 3
      • Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
      • Work the tool around the edges until all the clips release.
      Ask FixBot
    5. HTC Wizard 200 Keyboard Slider Replacement: step 6, image 1 of 2 HTC Wizard 200 Keyboard Slider Replacement: step 6, image 2 of 2
      • Once all the clips are open, remove the inner panel from the phone.
      Ask FixBot
    1. HTC Wizard 200 Keyboard Slider Replacement, Motherboard: step 7, image 1 of 1
      Spudger
      $3.99
      Buy
      • Use the spudger to pry the camera off.
      Ask FixBot
    2. HTC Wizard 200 Keyboard Slider Replacement: step 8, image 1 of 2 HTC Wizard 200 Keyboard Slider Replacement: step 8, image 2 of 2
      Buy
      • Using tweezers, flip the connector latch away from the motherboard.
      • Detach the flexible connection from under the connector latch.
      Ask FixBot
    3. HTC Wizard 200 Keyboard Slider Replacement: step 9, image 1 of 1
      • Slide the keyboard into the open position.
      Ask FixBot
    4. HTC Wizard 200 Keyboard Slider Replacement: step 10, image 1 of 2 HTC Wizard 200 Keyboard Slider Replacement: step 10, image 2 of 2
      Spudger
      $3.99
      Buy
      • Lift the motherboard out of the case using the spudger.
      • Expose the underside of the motherboard using your hands.
      Ask FixBot
    5. HTC Wizard 200 Keyboard Slider Replacement: step 11, image 1 of 2 HTC Wizard 200 Keyboard Slider Replacement: step 11, image 2 of 2
      • Remove the flexible connection from the motherboard.
      • Caution: Removing the connection too fast may cause damage to the connection and cables.
      Ask FixBot
    1. HTC Wizard 200 Keyboard Slider Replacement, Keyboard Slider: step 12, image 1 of 3 HTC Wizard 200 Keyboard Slider Replacement, Keyboard Slider: step 12, image 2 of 3 HTC Wizard 200 Keyboard Slider Replacement, Keyboard Slider: step 12, image 3 of 3
      T5 Torx Screwdriver
      $5.49
      Buy
      • Remove the four 5mm screws with the T5 Torx screwdriver.
      • Remove the keyboard slider from the main body.
      Ask FixBot
Author
with
Kyle Champ
225 Reputation
12 Guides authored
Cal Poly, Team 20-27, Maness Fall 2011 Member of Cal Poly, Team 20-27, Maness Fall 2011
CPSU-MANESS-F11S20G27
4 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 92
All Time: 1,633
