Up to 20% off select tools
HTC Wizard 200 Back Panel Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
86
All Time:
1,808
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will display how to remove and install the back panel of the HTC Wizard 200.
    1. HTC Wizard 200 Back Panel Replacement, Battery: step 1, image 1 of 2 HTC Wizard 200 Back Panel Replacement, Battery: step 1, image 2 of 2
      • To expose the battery, remove the outer case with your fingernail.
      • Remove the battery by pulling the black tab.
      Ask FixBot
    1. HTC Wizard 200 Back Panel Replacement, Back Panel: step 2, image 1 of 1
      Tool used on this step:
      Spudger
      $3.99
      Buy
      • Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
      Ask FixBot
    2. HTC Wizard 200 Back Panel Replacement: step 3, image 1 of 2 HTC Wizard 200 Back Panel Replacement: step 3, image 2 of 2
      Spudger
      $3.99
      Buy
      • Work the spudger around the edges of the camera cover until it comes off.
      Ask FixBot
    3. HTC Wizard 200 Back Panel Replacement: step 4, image 1 of 2 HTC Wizard 200 Back Panel Replacement: step 4, image 2 of 2
      T5 Torx Screwdriver
      $5.49
      Buy
      • Remove the four 6 mm screws with the T5 Torx screwdriver.
      • One of the screws is under the "void" sticker.
      Ask FixBot
    4. HTC Wizard 200 Back Panel Replacement: step 5, image 1 of 3 HTC Wizard 200 Back Panel Replacement: step 5, image 2 of 3 HTC Wizard 200 Back Panel Replacement: step 5, image 3 of 3
      • Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
      • Work the tool around the edges until all the clips release.
      Ask FixBot
    5. HTC Wizard 200 Back Panel Replacement: step 6, image 1 of 2 HTC Wizard 200 Back Panel Replacement: step 6, image 2 of 2
      • Once all the clips are open, remove the inner panel from the phone.
      Ask FixBot
Author
with
Kyle Champ
225 Reputation
12 Guides authored
Cal Poly, Team 20-27, Maness Fall 2011 Member of Cal Poly, Team 20-27, Maness Fall 2011
CPSU-MANESS-F11S20G27
4 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 86
All Time: 1,808
