HTC Wizard 100 Speakers Replacement
    1. HTC Wizard 100 Speakers Replacement, Battery: step 1, image 1 of 2 HTC Wizard 100 Speakers Replacement, Battery: step 1, image 2 of 2
      • Power the phone off.
      • Use your thumb to gently press downward and away from the camera to remove the battery cover.
      Ask FixBot
    2. HTC Wizard 100 Speakers Replacement: step 2, image 1 of 2 HTC Wizard 100 Speakers Replacement: step 2, image 2 of 2
      • Pull on the plastic tab to release the battery.
      Ask FixBot
    1. HTC Wizard 100 Speakers Replacement, Back Case: step 3, image 1 of 2 HTC Wizard 100 Speakers Replacement, Back Case: step 3, image 2 of 2
      • Use a plastic opening tool to remove the camera cover.
      • Work around the corners to avoid breaking the plastic clips that hold the camera cover on.
      • Lift the camera cover off of the phone.
      Ask FixBot
    2. HTC Wizard 100 Speakers Replacement: step 4, image 1 of 1
      • Remove the stylus from the phone.
      • Remove the four 5.5 mm screws with the T6 Torx Screwdriver.
      • One of the screws might be under a sticker, which will void your warranty.
      Ask FixBot
    3. HTC Wizard 100 Speakers Replacement: step 5, image 1 of 3 HTC Wizard 100 Speakers Replacement: step 5, image 2 of 3 HTC Wizard 100 Speakers Replacement: step 5, image 3 of 3
      • Be Careful! Do not insert the spudger in between the keyboard and screen. This could break the keyboard off the phone.
      • If your phone contains a memory card, you may want to remove it before proceeding with this step.
      • Insert spudger in the bottom corner as seen in the picture. Carefully slide the spudger from the bottom towards the top as seen in the second picture.
      • Lift the back case off completely.
      • The speakers might be dangling and unsecured.
      Ask FixBot
    1. HTC Wizard 100 Speakers Replacement, Speakers: step 6, image 1 of 2 HTC Wizard 100 Speakers Replacement, Speakers: step 6, image 2 of 2
      • Grip the speaker connector with your thumb and finger and gently pull up.
      • Repeat for 2nd speaker.
      Ask FixBot
Taylor Stone
45 Reputation
2 Guides authored
Cal Poly, Team 20-28, Maness Fall 2011 Member of Cal Poly, Team 20-28, Maness Fall 2011
CPSU-MANESS-F11S20G28
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 17
All Time: 908
