Up to 20% off select tools
HTC Wizard 100 Camera Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
92
All Time:
1,365
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
By removing the back plate and disconnecting the bus for the camera, replacing it isn't difficult.
    1. HTC Wizard 100 Camera Replacement, Battery: step 1, image 1 of 2 HTC Wizard 100 Camera Replacement, Battery: step 1, image 2 of 2
      • Power the phone off.
      • Use your thumb to gently press downward and away from the camera to remove the battery cover.
      Ask FixBot
    2. HTC Wizard 100 Camera Replacement: step 2, image 1 of 2 HTC Wizard 100 Camera Replacement: step 2, image 2 of 2
      • Pull on the plastic tab to release the battery.
      Ask FixBot
    1. HTC Wizard 100 Camera Replacement, Back Case: step 3, image 1 of 2 HTC Wizard 100 Camera Replacement, Back Case: step 3, image 2 of 2
      • Use a plastic opening tool to remove the camera cover.
      • Work around the corners to avoid breaking the plastic clips that hold the camera cover on.
      • Lift the camera cover off of the phone.
      Ask FixBot
    2. HTC Wizard 100 Camera Replacement: step 4, image 1 of 1
      • Remove the stylus from the phone.
      • Remove the four 5.5 mm screws with the T6 Torx Screwdriver.
      • One of the screws might be under a sticker, which will void your warranty.
      Ask FixBot
    3. HTC Wizard 100 Camera Replacement: step 5, image 1 of 3 HTC Wizard 100 Camera Replacement: step 5, image 2 of 3 HTC Wizard 100 Camera Replacement: step 5, image 3 of 3
      • Be Careful! Do not insert the spudger in between the keyboard and screen. This could break the keyboard off the phone.
      • If your phone contains a memory card, you may want to remove it before proceeding with this step.
      • Insert spudger in the bottom corner as seen in the picture. Carefully slide the spudger from the bottom towards the top as seen in the second picture.
      • Lift the back case off completely.
      • The speakers might be dangling and unsecured.
      Ask FixBot
    1. HTC Wizard 100 Camera Replacement, Camera: step 6, image 1 of 1
      • Locate the camera and pry off with the plastic opening tool or spudger.
      Ask FixBot
Author
with
Kevin Gingrich
180 Reputation
2 Guides authored
Cal Poly, Team 20-28, Maness Fall 2011 Member of Cal Poly, Team 20-28, Maness Fall 2011
CPSU-MANESS-F11S20G28
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 92
All Time: 1,365
