HTC Vive XR Elite Rear Padding Replacement
    1. HTC Vive XR Elite Rear Padding Replacement, Prepare your Vive XR Elite for disassembly: step 1, image 1 of 1
      • Before starting this repair, discharge the batteries in your headset below 25%. A charged battery may leak dangerous chemicals or catch fire if damaged.
      • Playing Half Life: Alyx will do the trick!
      • The Vive XR Elite has a proximity sensor that puts the headset in standby mode to save battery when it isn't in use. To drain the battery faster you'll need to use the headset.
      Ask FixBot
    1. HTC Vive XR Elite Rear Padding Replacement, Insert an opening pick: step 2, image 1 of 2 HTC Vive XR Elite Rear Padding Replacement, Insert an opening pick: step 2, image 2 of 2
      • Insert a long edge of an opening pick in the gap between the two halves of the battery cradle, near the USB-C cable.
      Ask FixBot
    2. HTC Vive XR Elite Rear Padding Replacement, Release the top clips: step 3, image 1 of 3 HTC Vive XR Elite Rear Padding Replacement, Release the top clips: step 3, image 2 of 3 HTC Vive XR Elite Rear Padding Replacement, Release the top clips: step 3, image 3 of 3
      • Slide the opening pick along the top edge of battery cradle to release its plastic clips.
      Ask FixBot
    3. HTC Vive XR Elite Rear Padding Replacement: step 4, image 1 of 2 HTC Vive XR Elite Rear Padding Replacement: step 4, image 2 of 2
      • Flip the battery cradle over.
      • Insert the long edge of an opening pick in the gap between the two halves of the battery cradle.
      Ask FixBot
    4. HTC Vive XR Elite Rear Padding Replacement, Release the bottom clips: step 5, image 1 of 3 HTC Vive XR Elite Rear Padding Replacement, Release the bottom clips: step 5, image 2 of 3 HTC Vive XR Elite Rear Padding Replacement, Release the bottom clips: step 5, image 3 of 3
      • Slide the opening pick along the bottom edge of battery cradle to release its plastic clips.
      Ask FixBot
    5. HTC Vive XR Elite Rear Padding Replacement, Separate the battery cradle halves: step 6, image 1 of 2 HTC Vive XR Elite Rear Padding Replacement, Separate the battery cradle halves: step 6, image 2 of 2
      • Pull apart the two halves of the battery cradle to completely separate them.
      Ask FixBot
    1. HTC Vive XR Elite Rear Padding Replacement, Unfasten the rear padding: step 7, image 1 of 2 HTC Vive XR Elite Rear Padding Replacement, Unfasten the rear padding: step 7, image 2 of 2
      Tool used on this step:
      FixMat
      $36.95
      Buy
      • Use a T5 Torx screwdriver to remove the four 4.9 mm-long screws securing the rear padding.
      Ask FixBot
    2. HTC Vive XR Elite Rear Padding Replacement, Unclip the rear padding: step 8, image 1 of 3 HTC Vive XR Elite Rear Padding Replacement, Unclip the rear padding: step 8, image 2 of 3 HTC Vive XR Elite Rear Padding Replacement, Unclip the rear padding: step 8, image 3 of 3
      • Pivot one of the rear padding clips toward the center of the frame.
      • Lift the rear padding up to unclip it.
      Ask FixBot
    3. HTC Vive XR Elite Rear Padding Replacement, Remove the rear padding: step 9, image 1 of 3 HTC Vive XR Elite Rear Padding Replacement, Remove the rear padding: step 9, image 2 of 3 HTC Vive XR Elite Rear Padding Replacement, Remove the rear padding: step 9, image 3 of 3
      • The rear padding is not symmetrical. Note its orientation before continuing.
      • Unclip the remaining rear padding clip.
      • Remove the rear padding.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Chayton Ritter
27,375 Reputation
105 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
60,897 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 28
All Time: 378
