HTC Vive XR Elite Lens Assembly Replacement
  1. HTC Vive XR Elite Lens Assembly Replacement, Prepare your Vive XR Elite for disassembly: step 1, image 1 of 1
    • Before starting this repair, discharge the batteries in your headset below 25%. A charged battery may leak dangerous chemicals or catch fire if damaged.
    • Playing Half Life: Alyx will do the trick!
    • The Vive XR Elite has a proximity sensor that puts the headset in standby mode to save battery when it isn't in use. To drain the battery faster you'll need to use the headset.
    Ask FixBot
  2. HTC Vive XR Elite Lens Assembly Replacement, Disconnect the USB-C power cable: step 2, image 1 of 2 HTC Vive XR Elite Lens Assembly Replacement, Disconnect the USB-C power cable: step 2, image 2 of 2
    • Disconnect the USB-C power cable.
    Ask FixBot
  3. HTC Vive XR Elite Lens Assembly Replacement, Disconnect the battery cradle: step 3, image 1 of 3 HTC Vive XR Elite Lens Assembly Replacement, Disconnect the battery cradle: step 3, image 2 of 3 HTC Vive XR Elite Lens Assembly Replacement, Disconnect the battery cradle: step 3, image 3 of 3
    • Press the release button on the right battery cradle temple slot.
    • Pull the battery cradle away from the right temple slot to disconnect it.
    Ask FixBot
  4. HTC Vive XR Elite Lens Assembly Replacement: step 4, image 1 of 3 HTC Vive XR Elite Lens Assembly Replacement: step 4, image 2 of 3 HTC Vive XR Elite Lens Assembly Replacement: step 4, image 3 of 3
    • Repeat the previous step for the left temple slot.
    Ask FixBot
  5. HTC Vive XR Elite Lens Assembly Replacement, Separate the headset and battery cradle: step 5, image 1 of 1
    • Separate the headset and battery cradle.
    Ask FixBot
  6. HTC Vive XR Elite Lens Assembly Replacement, Remove the face cushion: step 6, image 1 of 3 HTC Vive XR Elite Lens Assembly Replacement, Remove the face cushion: step 6, image 2 of 3 HTC Vive XR Elite Lens Assembly Replacement, Remove the face cushion: step 6, image 3 of 3
    • The face cushion is attached to the headset with two magnets. You'll feel the pull of the magnets as you remove it.
    • Grip the middle of the face cushion with your fingers and pull back to remove it.
    Ask FixBot
  7. HTC Vive XR Elite Lens Assembly Replacement, Remove the screw covers: step 7, image 1 of 2 HTC Vive XR Elite Lens Assembly Replacement, Remove the screw covers: step 7, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to remove the six screw covers from the right temple.
    Ask FixBot
  8. HTC Vive XR Elite Lens Assembly Replacement, Unfasten the right temple: step 8, image 1 of 2 HTC Vive XR Elite Lens Assembly Replacement, Unfasten the right temple: step 8, image 2 of 2
    • Use a T5 Torx screwdriver to remove the six 4.9 mm‑long screws securing the two right temple halves.
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing the right hinge cover.
    Ask FixBot
  9. HTC Vive XR Elite Lens Assembly Replacement, Remove the outer hinge cover: step 9, image 1 of 3 HTC Vive XR Elite Lens Assembly Replacement, Remove the outer hinge cover: step 9, image 2 of 3 HTC Vive XR Elite Lens Assembly Replacement, Remove the outer hinge cover: step 9, image 3 of 3
    • Insert the flat end of a spudger in the gap between the right outer and inner hinge covers.
    • Slide the spudger along the gap to separate the clips securing the outer hinge cover.
    • Remove the outer hinge cover.
    Ask FixBot
  10. HTC Vive XR Elite Lens Assembly Replacement, Remove the outer temple: step 10, image 1 of 3 HTC Vive XR Elite Lens Assembly Replacement, Remove the outer temple: step 10, image 2 of 3 HTC Vive XR Elite Lens Assembly Replacement, Remove the outer temple: step 10, image 3 of 3
    • Insert the flat end of a spudger in the gap between the outer and inner temple.
    • Slide the spudger along the gap to separate the clips securing the outer temple.
    Ask FixBot
  11. HTC Vive XR Elite Lens Assembly Replacement: step 11, image 1 of 3 HTC Vive XR Elite Lens Assembly Replacement: step 11, image 2 of 3 HTC Vive XR Elite Lens Assembly Replacement: step 11, image 3 of 3
    • Slide the top of the outer temple out of its slot in the hinge.
    Ask FixBot
  12. HTC Vive XR Elite Lens Assembly Replacement: step 12, image 1 of 2 HTC Vive XR Elite Lens Assembly Replacement: step 12, image 2 of 2
    Tesa 61395 Tape
    $10.95
    Buy
    • The speaker is lightly adhered to the outer temple.
    • Rotate the outer temple towards you to access the speaker.
    • Slide the flat end of a spudger under the speaker to separate its adhesive.
    • During reassembly, if your speaker adhesive isn't sticky, use double-sided tape to re-adhere the speaker to the outer temple.
    Ask FixBot
  13. HTC Vive XR Elite Lens Assembly Replacement: step 13, image 1 of 3 HTC Vive XR Elite Lens Assembly Replacement: step 13, image 2 of 3 HTC Vive XR Elite Lens Assembly Replacement: step 13, image 3 of 3
    • Thread the outer temple off of the USB‑C cable and remove it.
    Ask FixBot
  14. HTC Vive XR Elite Lens Assembly Replacement: step 14, image 1 of 2 HTC Vive XR Elite Lens Assembly Replacement: step 14, image 2 of 2
    • Pull the inner temple out of its slot in the hinge and remove it.
    Ask FixBot
  15. HTC Vive XR Elite Lens Assembly Replacement, Peel the hinge tape: step 15, image 1 of 2 HTC Vive XR Elite Lens Assembly Replacement, Peel the hinge tape: step 15, image 2 of 2
    • Use tweezers to peel back the black tape covering one of the inner hinge cover screws.
    Ask FixBot
  16. HTC Vive XR Elite Lens Assembly Replacement, Unfasten the inner hinge cover: step 16, image 1 of 1
    • Use a T5 Torx screwdriver to remove the two screws securing the inner hinge cover:
    • One 3.1 mm‑long screw
    • One 4.9 mm‑long screw
    Ask FixBot
  17. HTC Vive XR Elite Lens Assembly Replacement, Remove the inner hinge cover: step 17, image 1 of 3 HTC Vive XR Elite Lens Assembly Replacement, Remove the inner hinge cover: step 17, image 2 of 3 HTC Vive XR Elite Lens Assembly Replacement, Remove the inner hinge cover: step 17, image 3 of 3
    • Rotate the inner hinge cover off its groove in the frame.
    • Thread the inner hinge cover off of the USB-C and speaker cables and remove it.
    Ask FixBot
  18. HTC Vive XR Elite Lens Assembly Replacement, Remove the screw covers: step 18, image 1 of 2 HTC Vive XR Elite Lens Assembly Replacement, Remove the screw covers: step 18, image 2 of 2
    Buy
    • Use tweezers to remove the six screw covers from the left temple.
    Ask FixBot
  19. HTC Vive XR Elite Lens Assembly Replacement, Unfasten the left temple: step 19, image 1 of 2 HTC Vive XR Elite Lens Assembly Replacement, Unfasten the left temple: step 19, image 2 of 2
    • Use a T5 Torx screwdriver to remove the six 4.9 mm‑long screws securing the two left temple halves.
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing the left hinge cover.
    Ask FixBot
  20. HTC Vive XR Elite Lens Assembly Replacement, Remove the outer hinge cover: step 20, image 1 of 3 HTC Vive XR Elite Lens Assembly Replacement, Remove the outer hinge cover: step 20, image 2 of 3 HTC Vive XR Elite Lens Assembly Replacement, Remove the outer hinge cover: step 20, image 3 of 3
    • Insert the flat end of a spudger in the gap between the left outer and inner hinge covers.
    Ask FixBot
  21. HTC Vive XR Elite Lens Assembly Replacement, Remove the left temple: step 21, image 1 of 2 HTC Vive XR Elite Lens Assembly Replacement, Remove the left temple: step 21, image 2 of 2
    • Pull the left temple out of its slot in the hinge.
    • Don't try to fully remove it yet, as it's still connected by a cable.
    Ask FixBot
  22. HTC Vive XR Elite Lens Assembly Replacement: step 22, image 1 of 2 HTC Vive XR Elite Lens Assembly Replacement: step 22, image 2 of 2
    • Slide the spudger along the gap to separate the plastic clips securing the outer temple.
    Ask FixBot
  23. HTC Vive XR Elite Lens Assembly Replacement: step 23, image 1 of 2 HTC Vive XR Elite Lens Assembly Replacement: step 23, image 2 of 2
    • Pull the outer temple off of its inner half to completely release its plastic clips.
    Ask FixBot
  24. HTC Vive XR Elite Lens Assembly Replacement: step 24, image 1 of 2 HTC Vive XR Elite Lens Assembly Replacement: step 24, image 2 of 2
    Tesa 61395 Tape
    $10.95
    Buy
    • Let the speaker rest next to the headset before continuing.
    • During reassembly, if your speaker adhesive isn't sticky, use Tesa 61395 Tape to re-adhere the speaker to the outer temple.
    Ask FixBot
  25. HTC Vive XR Elite Lens Assembly Replacement, Peel the hinge tape: step 25, image 1 of 2 HTC Vive XR Elite Lens Assembly Replacement, Peel the hinge tape: step 25, image 2 of 2
    Ask FixBot
  26. HTC Vive XR Elite Lens Assembly Replacement, Unfasten the inner hinge cover: step 26, image 1 of 1
    • One 3.5 mm‑long screw
    Ask FixBot
  27. HTC Vive XR Elite Lens Assembly Replacement, Reposition the inner hinge cover: step 27, image 1 of 3 HTC Vive XR Elite Lens Assembly Replacement, Reposition the inner hinge cover: step 27, image 2 of 3 HTC Vive XR Elite Lens Assembly Replacement, Reposition the inner hinge cover: step 27, image 3 of 3
    • Don't fully remove the inner hinge cover, as it's connected by the volume button cable.
    • Let the cover hang off its volume button cable for now.
    Ask FixBot
  28. HTC Vive XR Elite Lens Assembly Replacement, Unfasten the face plate: step 28, image 1 of 2 HTC Vive XR Elite Lens Assembly Replacement, Unfasten the face plate: step 28, image 2 of 2
    • Use a T5 Torx screwdriver to remove the 12 screws securing the face plate:
    • Six 3.5 mm‑long screws
    • Four 4.9 mm‑long screws
    • Two 6.5 mm‑long screws
    • There are two magnets at the top corners of the face plate. As you remove nearby screws, they might stick to them.
    Ask FixBot
  29. HTC Vive XR Elite Lens Assembly Replacement, Unclip the face cover: step 29, image 1 of 2 HTC Vive XR Elite Lens Assembly Replacement, Unclip the face cover: step 29, image 2 of 2
    • Insert the flat end of the spudger in the gap between the frame and the bottom right corner of the face cover.
    • Pry up with the spudger to release the clips securing the face cover.
    Ask FixBot
  30. HTC Vive XR Elite Lens Assembly Replacement: step 30, image 1 of 2 HTC Vive XR Elite Lens Assembly Replacement: step 30, image 2 of 2
    • Repeat the prying process for the middle and bottom left portions of the face cover.
    Ask FixBot
  31. HTC Vive XR Elite Lens Assembly Replacement, Reposition the face cover: step 31, image 1 of 3 HTC Vive XR Elite Lens Assembly Replacement, Reposition the face cover: step 31, image 2 of 3 HTC Vive XR Elite Lens Assembly Replacement, Reposition the face cover: step 31, image 3 of 3
    • Don't fully remove the face cover completely, as it's connected by the proximity sensor cable.
    • Lift the face cover and rotate it over the top of the frame.
    • Lay the face cover face up before continuing.
    Ask FixBot
  32. HTC Vive XR Elite Lens Assembly Replacement, Unfasten the proximity sensor: step 32, image 1 of 1
    • Use a T5 Torx screwdriver to remove the two 3.3 mm‑long screws securing the proximity sensor cable.
    Ask FixBot
  33. HTC Vive XR Elite Lens Assembly Replacement, Remove the face cover: step 33, image 1 of 2 HTC Vive XR Elite Lens Assembly Replacement, Remove the face cover: step 33, image 2 of 2
    • Remove the face cover.
    Ask FixBot
  34. HTC Vive XR Elite Lens Assembly Replacement, Reposition the lens assembly: step 34, image 1 of 2 HTC Vive XR Elite Lens Assembly Replacement, Reposition the lens assembly: step 34, image 2 of 2
    • Pull the two lenses outward so they're as far apart as possible.
    Ask FixBot
  35. HTC Vive XR Elite Lens Assembly Replacement, Unfasten the lens assembly: step 35, image 1 of 1
    • Use a T5 Torx screwdriver to remove the four screws securing the lens assembly:
    • Three 4.9 mm‑long screws
    • One 3.3 mm‑long screw
    Ask FixBot
  36. HTC Vive XR Elite Lens Assembly Replacement, Remove the brackets: step 36, image 1 of 3 HTC Vive XR Elite Lens Assembly Replacement, Remove the brackets: step 36, image 2 of 3 HTC Vive XR Elite Lens Assembly Replacement, Remove the brackets: step 36, image 3 of 3
    Buy
    • The screw brackets are secured with clips and adhesive.
    • Use tweezers to pull the left screw bracket of its post in the frame.
    • This may require some force. Be careful not to scratch any surrounding components.
    • Repeat this process for the right bracket.
    • During reassembly, use tweezers to align the brackets on their posts. Press down with the flat end of a spudger to engage and re-adhere the clips.
    Ask FixBot
  37. HTC Vive XR Elite Lens Assembly Replacement, Reposition the lens assembly: step 37, image 1 of 2 HTC Vive XR Elite Lens Assembly Replacement, Reposition the lens assembly: step 37, image 2 of 2
    • Lift the bottom of the lens assembly up to separate the bottom rails from their slots in the frame.
    Ask FixBot
  38. HTC Vive XR Elite Lens Assembly Replacement: step 38, image 1 of 3 HTC Vive XR Elite Lens Assembly Replacement: step 38, image 2 of 3 HTC Vive XR Elite Lens Assembly Replacement: step 38, image 3 of 3
    • Pull the lens assembly upwards to separate the top rails from their slots in the frame.
    • Rotate the lens assembly towards the top of the frame so it sits upright with its cable connectors exposed.
    Ask FixBot
  39. HTC Vive XR Elite Lens Assembly Replacement, Unfasten the lens assembly cables: step 39, image 1 of 1
    • Use a T5 Torx screwdriver to remove the four 3.4 mm‑long screws securing the lens assembly cables.
    Ask FixBot
  40. HTC Vive XR Elite Lens Assembly Replacement, Disconnect the lens assembly cables: step 40, image 1 of 3 HTC Vive XR Elite Lens Assembly Replacement, Disconnect the lens assembly cables: step 40, image 2 of 3 HTC Vive XR Elite Lens Assembly Replacement, Disconnect the lens assembly cables: step 40, image 3 of 3
    • Use the flat end of a spudger to pry up and disconnect the lens assembly cable connector.
    • Repeat this procedure for the other connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Ask FixBot
  41. HTC Vive XR Elite Lens Assembly Replacement, Remove the lens assembly: step 41, image 1 of 2 HTC Vive XR Elite Lens Assembly Replacement, Remove the lens assembly: step 41, image 2 of 2
    • Lift up and remove the lens assembly.
    Ask FixBot
  42. HTC Vive XR Elite Lens Assembly Replacement, Reassembly information: step 42, image 1 of 3 HTC Vive XR Elite Lens Assembly Replacement, Reassembly information: step 42, image 2 of 3 HTC Vive XR Elite Lens Assembly Replacement, Reassembly information: step 42, image 3 of 3
    • The next four steps demonstrate how to secure the lens assembly to the frame during reassembly.
    • In order for the lens assembly to rest in the frame properly, it needs to align with a peg in the IPD (interpupillary distance) slider.
    • Before reinstalling the lens assembly, push the IPD slider to its right-most position.
    Ask FixBot
  43. HTC Vive XR Elite Lens Assembly Replacement: step 43, image 1 of 3 HTC Vive XR Elite Lens Assembly Replacement: step 43, image 2 of 3 HTC Vive XR Elite Lens Assembly Replacement: step 43, image 3 of 3
    • Pull the lens assembly outward until its plastic clips sit close to the end of the top rails.
    • You may need to push and pull the top rail so it sits evenly across the plastic clips.
    Ask FixBot
  44. HTC Vive XR Elite Lens Assembly Replacement: step 44, image 1 of 3 HTC Vive XR Elite Lens Assembly Replacement: step 44, image 2 of 3 HTC Vive XR Elite Lens Assembly Replacement: step 44, image 3 of 3
    • Push the bottom rails inwards as far as they will go.
    Ask FixBot
  45. HTC Vive XR Elite Lens Assembly Replacement: step 45, image 1 of 3 HTC Vive XR Elite Lens Assembly Replacement: step 45, image 2 of 3 HTC Vive XR Elite Lens Assembly Replacement: step 45, image 3 of 3
    • To secure the lens assembly into the frame:
    • Slide the top left rail into its slot.
    • Align the other rails.
    • Press the lens assembly into place, making sure to realign the center peg.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Alex Diaz-Kokaisl
244,742 Reputation
1,203 Guides authored
iFixit Member of iFixit
Staff
123 Members
27,751 Guides authored
1 Guide Comment
Geez Louise! All that disassembly just to replace the lenses? Why couldn't HTC simply come up with a bottle cap screw on design????
John Bell - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 26
All Time: 964
