Up to 20% off select tools
HTC Vive Sensor Array Replacement
Views: 4.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
23
Past 30 Days:
107
All Time:
4,423
Comments: 9
7 comments on steps, 2 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 40 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to remove and replace the sensor array in an HTC Vive.
You'll need a narrow, long-shaft driver to reach some of the screws in this guide.
    1. HTC Vive Sensor Array Replacement, Open the cable compartment: step 1, image 1 of 3 HTC Vive Sensor Array Replacement, Open the cable compartment: step 1, image 2 of 3 HTC Vive Sensor Array Replacement, Open the cable compartment: step 1, image 3 of 3
      • Be sure to power down and disconnect your Vive before beginning.
      • Place a finger on the top edge of the compartment cover assembly and slide the assembly toward the front of the Vive until it comes loose from the headset.
      • Lift the cover away from the headset and slide it up the cables until it's out of the way.
      Ask FixBot
    2. HTC Vive Sensor Array Replacement, Unplug the HDMI cable: step 2, image 1 of 2 HTC Vive Sensor Array Replacement, Unplug the HDMI cable: step 2, image 2 of 2
      • Lift the HDMI cable straight up to unplug it from the headset.
      Ask FixBot
    3. HTC Vive Sensor Array Replacement, Unplug the remaining cables: step 3, image 1 of 3 HTC Vive Sensor Array Replacement, Unplug the remaining cables: step 3, image 2 of 3 HTC Vive Sensor Array Replacement, Unplug the remaining cables: step 3, image 3 of 3
      • Repeat the lifting and unplugging process with the remaining USB, power, and audio cables.
      Ask FixBot
    1. HTC Vive Sensor Array Replacement, Unscrew the head strap mounts: step 4, image 1 of 2 HTC Vive Sensor Array Replacement, Unscrew the head strap mounts: step 4, image 2 of 2
      • Use a T5 Torx driver to remove the two 12 mm-long screws securing the head strap mounts on either side of the headset.
      • For some devices, a T6 Torx driver may work better.
      • The mounts may fall off when the screws are removed, so be careful not to lose any parts.
      Ask FixBot
    2. HTC Vive Sensor Array Replacement, Remove the head strap mounts: step 5, image 1 of 3 HTC Vive Sensor Array Replacement, Remove the head strap mounts: step 5, image 2 of 3 HTC Vive Sensor Array Replacement, Remove the head strap mounts: step 5, image 3 of 3
      • Remove both head strap mounts.
      Ask FixBot
    3. HTC Vive Sensor Array Replacement, Remove the facerest: step 6, image 1 of 2 HTC Vive Sensor Array Replacement, Remove the facerest: step 6, image 2 of 2
      • Slide the facerest straight away from the headset to remove it.
      Ask FixBot
    1. HTC Vive Sensor Array Replacement, Unscrew the outer shell: step 7, image 1 of 3 HTC Vive Sensor Array Replacement, Unscrew the outer shell: step 7, image 2 of 3 HTC Vive Sensor Array Replacement, Unscrew the outer shell: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to remove the small stickers over the four screws securing the outer shell.
      • Use a T5 Torx driver to remove the four 3.4 mm-long screws securing the outer shell.
      Ask FixBot
    2. HTC Vive Sensor Array Replacement, Remove the outer shell: step 8, image 1 of 3 HTC Vive Sensor Array Replacement, Remove the outer shell: step 8, image 2 of 3 HTC Vive Sensor Array Replacement, Remove the outer shell: step 8, image 3 of 3
      • Grasp the top edge of the right half of the outer shell, behind the component cover and near the seam in the center. Pull it to the right and upward, away from the headset to release the clip securing that part of the shell.
      Ask FixBot
    3. HTC Vive Sensor Array Replacement: step 9, image 1 of 2 HTC Vive Sensor Array Replacement: step 9, image 2 of 2
      • Grasp the right half the outer shell and pull it to the right and toward the front of the headset in a twisting motion until you feel the clips on the front of the cover release.
      Ask FixBot
    4. HTC Vive Sensor Array Replacement: step 10, image 1 of 2 HTC Vive Sensor Array Replacement: step 10, image 2 of 2
      • Slide the right side of the outer shell to the right and off of the headset.
      Ask FixBot
    5. HTC Vive Sensor Array Replacement: step 11, image 1 of 2 HTC Vive Sensor Array Replacement: step 11, image 2 of 2
      • Repeat the last three steps for the left side of the outer shell and remove it.
      Ask FixBot
    1. HTC Vive Sensor Array Replacement, Disconnect the sensor array cables: step 12, image 1 of 3 HTC Vive Sensor Array Replacement, Disconnect the sensor array cables: step 12, image 2 of 3 HTC Vive Sensor Array Replacement, Disconnect the sensor array cables: step 12, image 3 of 3
      Buy
      • Use tweezers to remove the clear tape over all four of the sensor array cable connectors.
      Ask FixBot
    2. HTC Vive Sensor Array Replacement: step 13, image 1 of 3 HTC Vive Sensor Array Replacement: step 13, image 2 of 3 HTC Vive Sensor Array Replacement: step 13, image 3 of 3
      • Use the pointed end of a spudger to flip up the small locking flap on one of the sensor array ZIF connectors.
      • Slide the cable straight out of its socket on the motherboard.
      Ask FixBot
    3. HTC Vive Sensor Array Replacement: step 14, image 1 of 3 HTC Vive Sensor Array Replacement: step 14, image 2 of 3 HTC Vive Sensor Array Replacement: step 14, image 3 of 3
      • Repeat the previous step for the remaining three sensor array cables to disconnect the remaining cables.
      Ask FixBot
    4. HTC Vive Sensor Array Replacement: step 15, image 1 of 2 HTC Vive Sensor Array Replacement: step 15, image 2 of 2
      • Use tweezers or a spudger to pry up the camera cable cover and remove it.
      Ask FixBot
    5. HTC Vive Sensor Array Replacement: step 16, image 1 of 2 HTC Vive Sensor Array Replacement: step 16, image 2 of 2
      • Use the flat end of a spudger to pry the camera cable connector straight up from its socket on the motherboard.
      Ask FixBot
    6. HTC Vive Sensor Array Replacement, Unscrew the sensor array: step 17, image 1 of 1
      • Use a PH000 driver to remove the five 3.9 mm screws securing the sensor array.
      Ask FixBot
    7. HTC Vive Sensor Array Replacement: step 18, image 1 of 1
      • Use a PH000 driver to remove the four 3.9 mm screws securing the sensor array.
      Ask FixBot
    8. HTC Vive Sensor Array Replacement: step 19, image 1 of 2 HTC Vive Sensor Array Replacement: step 19, image 2 of 2
      Phillips #000 Screwdriver
      $5.49
      Buy
      • You'll need a narrow, long-shaft driver to reach these screws.
      Ask FixBot
    9. HTC Vive Sensor Array Replacement, Remove the sensor array: step 20, image 1 of 2 HTC Vive Sensor Array Replacement, Remove the sensor array: step 20, image 2 of 2
      • Lift the sensor array away from the headset to remove it.
      Ask FixBot
3 other people completed this guide.
Author
with
Adam O'Camb
226,696 Reputation
415 Guides authored
2 Guide Comments
Herzlichen Dank für diese ausführliche Anleitung! Sie war sehr hilfreich und hat mir vermutlich eine Menge Zeit erspart!
Holger - Reply Share
Buongiorno, dove trovate i pezzi di ricambio per questo tipo di maschera?
Grazie
sandro verta - Reply Share
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 107
All Time: 4,423
