HTC Vive Pro Head Strap Replacement
    1. HTC Vive Pro Head Strap Replacement, Reposition the head strap: step 1, image 1 of 2 HTC Vive Pro Head Strap Replacement, Reposition the head strap: step 1, image 2 of 2
      • Rotate the head strap forward as far as it will go.
      Ask FixBot
    2. HTC Vive Pro Head Strap Replacement, Unplug the All-In-One Cable: step 2, image 1 of 2 HTC Vive Pro Head Strap Replacement, Unplug the All-In-One Cable: step 2, image 2 of 2
      • Unplug the All-In-One Cable from your headset.
      Ask FixBot
    3. HTC Vive Pro Head Strap Replacement, Remove the All-In-One Cable: step 3, image 1 of 3 HTC Vive Pro Head Strap Replacement, Remove the All-In-One Cable: step 3, image 2 of 3 HTC Vive Pro Head Strap Replacement, Remove the All-In-One Cable: step 3, image 3 of 3
      • Remove the All-In-One Cable from the cable guides along the left side of the head strap.
      • During reassembly, connect the All-In-One Cable to the headset before routing it through the cable guides. This will ensure it has the right amount of slack.
      Ask FixBot
    1. HTC Vive Pro Head Strap Replacement, Remove the top strap: step 4, image 1 of 2 HTC Vive Pro Head Strap Replacement, Remove the top strap: step 4, image 2 of 2
      • Separate the top strap from itself where the Velcro secures it.
      Ask FixBot
    2. HTC Vive Pro Head Strap Replacement: step 5, image 1 of 3 HTC Vive Pro Head Strap Replacement: step 5, image 2 of 3 HTC Vive Pro Head Strap Replacement: step 5, image 3 of 3
      • Peel back the Velcro securing the rear of the top strap.
      • Feed the top strap out through the head strap to partially remove it.
      Ask FixBot
    3. HTC Vive Pro Head Strap Replacement: step 6, image 1 of 3 HTC Vive Pro Head Strap Replacement: step 6, image 2 of 3 HTC Vive Pro Head Strap Replacement: step 6, image 3 of 3
      • Feed the top strap through the clip near the front of headset to fully remove it.
      Ask FixBot
    1. HTC Vive Pro Head Strap Replacement, Remove the front side foam pads: step 7, image 1 of 3 HTC Vive Pro Head Strap Replacement, Remove the front side foam pads: step 7, image 2 of 3 HTC Vive Pro Head Strap Replacement, Remove the front side foam pads: step 7, image 3 of 3
      • Peel off both front side foam pads to uncover the speaker wires.
      Ask FixBot
    2. HTC Vive Pro Head Strap Replacement, Remove the two rubber spacers: step 8, image 1 of 3 HTC Vive Pro Head Strap Replacement, Remove the two rubber spacers: step 8, image 2 of 3 HTC Vive Pro Head Strap Replacement, Remove the two rubber spacers: step 8, image 3 of 3
      • Use the point of your spudger to pry out the two rubber spacers next to the headphone screws.
      • Be careful not to accidentally pry any of the speaker wires under the rubber spacer.
      Ask FixBot
    3. HTC Vive Pro Head Strap Replacement, Disconnect the speaker wires: step 9, image 1 of 2 HTC Vive Pro Head Strap Replacement, Disconnect the speaker wires: step 9, image 2 of 2
      • Use the point of your spudger to pry up and disconnect both the left and right headphone speaker wires.
      Ask FixBot
    4. HTC Vive Pro Head Strap Replacement, Remove the head strap: step 10, image 1 of 2 HTC Vive Pro Head Strap Replacement, Remove the head strap: step 10, image 2 of 2
      • Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
      Ask FixBot
    5. HTC Vive Pro Head Strap Replacement: step 11, image 1 of 1
      • Remove the two plastic spacers underneath the previously removed Torx T6 screw.
      Ask FixBot
    6. HTC Vive Pro Head Strap Replacement: step 12, image 1 of 3 HTC Vive Pro Head Strap Replacement: step 12, image 2 of 3 HTC Vive Pro Head Strap Replacement: step 12, image 3 of 3
      • Thread the headphone speaker wires out through both ends of the head strap.
      Ask FixBot
    1. HTC Vive Pro Head Strap Replacement, Only the head strap remains: step 13, image 1 of 1
      • Transfer all foam pads from the old head strap to the new one.
      Ask FixBot
Sam Omiotek
100,108 Reputation
289 Guides authored
2 Guide Comments
There is a missing step. The replacement part doesn't contain anything to connect the audio wires to. You will have to remove a screw and pry up the little board that has the headphone connector on it. The spudger works well for this. Be aware that in addition to the screw, this little audio connector board is also held on with adhesive, so you will need to peel it off. The adhesive isn't too strong, so you can get it up pretty easily. When putting the audio connectors into the replacement head strap you'll want to be sure to peel off the backing on the adhesive before seating the board on it.
Ike - Reply Share
Nice tutorial! You do not actually have to remove those six T5 screws.
Lance Putnam - Reply Share
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 63
All Time: 3,264
