HTC Vive Pro Facerest Replacement
    1. HTC Vive Pro Facerest Replacement, Reposition the head strap: step 1, image 1 of 2 HTC Vive Pro Facerest Replacement, Reposition the head strap: step 1, image 2 of 2
      • Rotate the head strap forward as far as it will go.
      Ask FixBot
    2. HTC Vive Pro Facerest Replacement, Unplug the All-In-One Cable: step 2, image 1 of 2 HTC Vive Pro Facerest Replacement, Unplug the All-In-One Cable: step 2, image 2 of 2
      • Unplug the All-In-One Cable from your headset.
      Ask FixBot
    3. HTC Vive Pro Facerest Replacement, Remove the All-In-One Cable: step 3, image 1 of 3 HTC Vive Pro Facerest Replacement, Remove the All-In-One Cable: step 3, image 2 of 3 HTC Vive Pro Facerest Replacement, Remove the All-In-One Cable: step 3, image 3 of 3
      • Remove the All-In-One Cable from the cable guides along the left side of the head strap.
      • During reassembly, connect the All-In-One Cable to the headset before routing it through the cable guides. This will ensure it has the right amount of slack.
      Ask FixBot
    1. HTC Vive Pro Facerest Replacement, Remove the top strap: step 4, image 1 of 2 HTC Vive Pro Facerest Replacement, Remove the top strap: step 4, image 2 of 2
      • Separate the top strap from itself where the Velcro secures it.
      Ask FixBot
    2. HTC Vive Pro Facerest Replacement: step 5, image 1 of 3 HTC Vive Pro Facerest Replacement: step 5, image 2 of 3 HTC Vive Pro Facerest Replacement: step 5, image 3 of 3
      • Peel back the Velcro securing the rear of the top strap.
      • Feed the top strap out through the head strap to partially remove it.
      Ask FixBot
    3. HTC Vive Pro Facerest Replacement: step 6, image 1 of 3 HTC Vive Pro Facerest Replacement: step 6, image 2 of 3 HTC Vive Pro Facerest Replacement: step 6, image 3 of 3
      • Feed the top strap through the clip near the front of headset to fully remove it.
      Ask FixBot
    1. HTC Vive Pro Facerest Replacement, Remove the front side foam pads: step 7, image 1 of 3 HTC Vive Pro Facerest Replacement, Remove the front side foam pads: step 7, image 2 of 3 HTC Vive Pro Facerest Replacement, Remove the front side foam pads: step 7, image 3 of 3
      • Peel off both front side foam pads to uncover the speaker wires.
      Ask FixBot
    2. HTC Vive Pro Facerest Replacement, Remove the two rubber spacers: step 8, image 1 of 3 HTC Vive Pro Facerest Replacement, Remove the two rubber spacers: step 8, image 2 of 3 HTC Vive Pro Facerest Replacement, Remove the two rubber spacers: step 8, image 3 of 3
      • Use the point of your spudger to pry out the two rubber spacers next to the headphone screws.
      • Be careful not to accidentally pry any of the speaker wires under the rubber spacer.
      Ask FixBot
    3. HTC Vive Pro Facerest Replacement, Disconnect the speaker wires: step 9, image 1 of 3 HTC Vive Pro Facerest Replacement, Disconnect the speaker wires: step 9, image 2 of 3 HTC Vive Pro Facerest Replacement, Disconnect the speaker wires: step 9, image 3 of 3
      • Use the point of your spudger to pry up and disconnect both the left and right headphone speaker wires.
      Ask FixBot
    4. HTC Vive Pro Facerest Replacement, Remove the head strap: step 10, image 1 of 2 HTC Vive Pro Facerest Replacement, Remove the head strap: step 10, image 2 of 2
      • Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
      • Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
      • Four 3.9 mm screws (two on each side)
      • Two 4.1 mm screws (one on each side)
      Ask FixBot
    5. HTC Vive Pro Facerest Replacement: step 11, image 1 of 1
      • Remove the two plastic spacers underneath the previously removed Torx T6 screw.
      Ask FixBot
    6. HTC Vive Pro Facerest Replacement: step 12, image 1 of 3 HTC Vive Pro Facerest Replacement: step 12, image 2 of 3 HTC Vive Pro Facerest Replacement: step 12, image 3 of 3
      • Thread the headphone speaker wires out through both ends of the head strap.
      Ask FixBot
    1. HTC Vive Pro Facerest Replacement, Remove the outer shell: step 13, image 1 of 3 HTC Vive Pro Facerest Replacement, Remove the outer shell: step 13, image 2 of 3 HTC Vive Pro Facerest Replacement, Remove the outer shell: step 13, image 3 of 3
      • The four screws securing the outer shell are covered with black stickers. If the stickers are difficult to remove, simply press your T6 Torx driver through them.
      Ask FixBot
    2. HTC Vive Pro Facerest Replacement: step 14, image 1 of 2 HTC Vive Pro Facerest Replacement: step 14, image 2 of 2
      • Use a T6 Torx screwdriver to remove the four 3.9 mm screws (two on top, two on bottom) securing the outer shell to the headset.
      Ask FixBot
    3. HTC Vive Pro Facerest Replacement: step 15, image 1 of 3 HTC Vive Pro Facerest Replacement: step 15, image 2 of 3 HTC Vive Pro Facerest Replacement: step 15, image 3 of 3
      • Insert an opening pick into the seam between the two halves of the outer shell.
      • Slide the opening pick through the seam to dislodge the clips securing it to the headset.
      • Only insert the opening pick as far as necessary. There are ribbon cables underneath the outer shell.
      Ask FixBot
    4. HTC Vive Pro Facerest Replacement: step 16, image 1 of 3 HTC Vive Pro Facerest Replacement: step 16, image 2 of 3 HTC Vive Pro Facerest Replacement: step 16, image 3 of 3
      • Continue sliding the opening pick through each seam until all clips have been dislodged.
      Ask FixBot
    5. HTC Vive Pro Facerest Replacement: step 17, image 1 of 3 HTC Vive Pro Facerest Replacement: step 17, image 2 of 3 HTC Vive Pro Facerest Replacement: step 17, image 3 of 3
      • Carefully slide each half of the outer shell off of the sensor array.
      • Be careful not to snag any of the ribbon cables underneath.
      Ask FixBot
    1. HTC Vive Pro Facerest Replacement, Remove the facerest: step 18, image 1 of 2 HTC Vive Pro Facerest Replacement, Remove the facerest: step 18, image 2 of 2
      • Partially separate the facerest and the sensor array to access the daughterboard.
      Ask FixBot
    2. HTC Vive Pro Facerest Replacement: step 19, image 1 of 2 HTC Vive Pro Facerest Replacement: step 19, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers to remove the Kapton tape covering the white and purple wires on the daughterboard.
      Ask FixBot
    3. HTC Vive Pro Facerest Replacement: step 20, image 1 of 3 HTC Vive Pro Facerest Replacement: step 20, image 2 of 3 HTC Vive Pro Facerest Replacement: step 20, image 3 of 3
      • Use the pointed end of a spudger to pry up and disconnect the purple and white wires from the daughterboard.
      • Use caution when disconnecting these wires. If you pry up too hard, they may pull out of the connector.
      Ask FixBot
    4. HTC Vive Pro Facerest Replacement: step 21, image 1 of 2 HTC Vive Pro Facerest Replacement: step 21, image 2 of 2
      • Slide the facerest out of the front assembly.
      Ask FixBot
2 other people completed this guide.
Sam Omiotek
100,054 Reputation
289 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 28
All Time: 1,364
