Introduction
Follow this guide to replace the daughterboard in your HTC Vive Pro.
Power off and unplug your headset before you begin your repair.
Remove the All-In-One Cable from the cable guides along the left side of the head strap.
Peel off both front side foam pads to uncover the speaker wires.
Use the point of your spudger to pry out the two rubber spacers next to the headphone screws.
Use the point of your spudger to pry up and disconnect both the left and right headphone speaker wires.
Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
Four 3.9 mm screws (two on each side)
Two 4.1 mm screws (one on each side)
Use your fingers to gently peel the face rest cushion off of the headset.
Partially separate the facerest and the sensor array to access the daughterboard.
Tool used on this step:Tweezers$4.99
Use a pair of tweezers to remove the Kapton tape covering the ZIF connector on the daughterboard.
Use the flat end of your spudger to disconnect the two press connectors from the daughterboard.
2 Guide Comments
Unfort, no. The female port on the daughterboard has became loose from the solder and the daughterboard needs to be either replaced or the video/audio port needs to be re-soldered. There just simply is no ...easy fix.
