Up to 20% off select tools
HTC Vive Pro 2 Sensor Array Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
63
All Time:
543
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the sensor array on your HTC Vive Pro 2 headset.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the procedure.
Power off and unplug your headset before you begin your repair.
    1. HTC Vive Pro 2 Sensor Array Replacement, Reposition the head strap: step 1, image 1 of 2 HTC Vive Pro 2 Sensor Array Replacement, Reposition the head strap: step 1, image 2 of 2
      • Rotate the head strap forward as far as it will go.
      Ask FixBot
    2. HTC Vive Pro 2 Sensor Array Replacement, Unplug the All-In-One Cable: step 2, image 1 of 2 HTC Vive Pro 2 Sensor Array Replacement, Unplug the All-In-One Cable: step 2, image 2 of 2
      • Unplug the All-In-One Cable from your headset.
      Ask FixBot
    3. HTC Vive Pro 2 Sensor Array Replacement, Remove the All-In-One Cable: step 3, image 1 of 3 HTC Vive Pro 2 Sensor Array Replacement, Remove the All-In-One Cable: step 3, image 2 of 3 HTC Vive Pro 2 Sensor Array Replacement, Remove the All-In-One Cable: step 3, image 3 of 3
      • Remove the All-In-One Cable from the cable guides along the left side of the head strap.
      • During reassembly, connect the All-In-One Cable to the headset before routing it through the cable guides. This will ensure it has the right amount of slack.
      Ask FixBot
    1. HTC Vive Pro 2 Sensor Array Replacement, Remove the top strap: step 4, image 1 of 2 HTC Vive Pro 2 Sensor Array Replacement, Remove the top strap: step 4, image 2 of 2
      • Separate the top strap from itself where the Velcro secures it.
      Ask FixBot
    2. HTC Vive Pro 2 Sensor Array Replacement: step 5, image 1 of 3 HTC Vive Pro 2 Sensor Array Replacement: step 5, image 2 of 3 HTC Vive Pro 2 Sensor Array Replacement: step 5, image 3 of 3
      • Peel back the Velcro securing the rear of the top strap.
      • Feed the top strap out through the head strap to partially remove it.
      Ask FixBot
    3. HTC Vive Pro 2 Sensor Array Replacement: step 6, image 1 of 3 HTC Vive Pro 2 Sensor Array Replacement: step 6, image 2 of 3 HTC Vive Pro 2 Sensor Array Replacement: step 6, image 3 of 3
      • Feed the top strap through the clip near the front of headset to fully remove it.
      Ask FixBot
    1. HTC Vive Pro 2 Sensor Array Replacement, Remove the front side foam pads: step 7, image 1 of 3 HTC Vive Pro 2 Sensor Array Replacement, Remove the front side foam pads: step 7, image 2 of 3 HTC Vive Pro 2 Sensor Array Replacement, Remove the front side foam pads: step 7, image 3 of 3
      • Peel off both front side foam pads to uncover the speaker wires.
      Ask FixBot
    2. HTC Vive Pro 2 Sensor Array Replacement, Remove the two rubber spacers: step 8, image 1 of 3 HTC Vive Pro 2 Sensor Array Replacement, Remove the two rubber spacers: step 8, image 2 of 3 HTC Vive Pro 2 Sensor Array Replacement, Remove the two rubber spacers: step 8, image 3 of 3
      • Use the point of your spudger to pry out the two rubber spacers next to the headphone screws.
      • Be careful not to accidentally pry any of the speaker wires under the rubber spacer.
      Ask FixBot
    3. HTC Vive Pro 2 Sensor Array Replacement, Disconnect the speaker wires: step 9, image 1 of 3 HTC Vive Pro 2 Sensor Array Replacement, Disconnect the speaker wires: step 9, image 2 of 3 HTC Vive Pro 2 Sensor Array Replacement, Disconnect the speaker wires: step 9, image 3 of 3
      • Use the point of your spudger to pry up and disconnect both the left and right headphone speaker wires.
      Ask FixBot
    4. HTC Vive Pro 2 Sensor Array Replacement, Remove the head strap: step 10, image 1 of 2 HTC Vive Pro 2 Sensor Array Replacement, Remove the head strap: step 10, image 2 of 2
      • Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
      • Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
      • Four 3.9 mm screws (two on each side)
      • Two 4.1 mm screws (one on each side)
      Ask FixBot
    5. HTC Vive Pro 2 Sensor Array Replacement: step 11, image 1 of 1
      • Remove the two plastic spacers underneath the previously removed Torx T6 screw.
      Ask FixBot
    6. HTC Vive Pro 2 Sensor Array Replacement: step 12, image 1 of 3 HTC Vive Pro 2 Sensor Array Replacement: step 12, image 2 of 3 HTC Vive Pro 2 Sensor Array Replacement: step 12, image 3 of 3
      • Thread the headphone speaker wires out through both ends of the head strap.
      Ask FixBot
    1. HTC Vive Pro 2 Sensor Array Replacement, Remove the outer shell: step 13, image 1 of 3 HTC Vive Pro 2 Sensor Array Replacement, Remove the outer shell: step 13, image 2 of 3 HTC Vive Pro 2 Sensor Array Replacement, Remove the outer shell: step 13, image 3 of 3
      • The four screws securing the outer shell are covered with black stickers. If the stickers are difficult to remove, simply press your T6 Torx driver through them.
      Ask FixBot
    2. HTC Vive Pro 2 Sensor Array Replacement: step 14, image 1 of 2 HTC Vive Pro 2 Sensor Array Replacement: step 14, image 2 of 2
      • Use a T6 Torx screwdriver to remove the four 3.9 mm screws (two on top, two on bottom) securing the outer shell to the headset.
      Ask FixBot
    3. HTC Vive Pro 2 Sensor Array Replacement: step 15, image 1 of 3 HTC Vive Pro 2 Sensor Array Replacement: step 15, image 2 of 3 HTC Vive Pro 2 Sensor Array Replacement: step 15, image 3 of 3
      • Insert an opening pick into the seam between the two halves of the outer shell.
      • Slide the opening pick through the seam to dislodge the clips securing it to the headset.
      • Only insert the opening pick as far as necessary. There are ribbon cables underneath the outer shell.
      Ask FixBot
    4. HTC Vive Pro 2 Sensor Array Replacement: step 16, image 1 of 3 HTC Vive Pro 2 Sensor Array Replacement: step 16, image 2 of 3 HTC Vive Pro 2 Sensor Array Replacement: step 16, image 3 of 3
      • Continue sliding the opening pick through each seam until all clips have been dislodged.
      Ask FixBot
    5. HTC Vive Pro 2 Sensor Array Replacement: step 17, image 1 of 3 HTC Vive Pro 2 Sensor Array Replacement: step 17, image 2 of 3 HTC Vive Pro 2 Sensor Array Replacement: step 17, image 3 of 3
      • Carefully slide each half of the outer shell off of the sensor array.
      • Be careful not to snag any of the ribbon cables underneath.
      Ask FixBot
    1. HTC Vive Pro 2 Sensor Array Replacement, Remove the face rest cushion: step 18, image 1 of 3 HTC Vive Pro 2 Sensor Array Replacement, Remove the face rest cushion: step 18, image 2 of 3 HTC Vive Pro 2 Sensor Array Replacement, Remove the face rest cushion: step 18, image 3 of 3
      • Use your fingers to gently peel the face rest cushion off of the headset.
      Ask FixBot
    1. HTC Vive Pro 2 Sensor Array Replacement, Disconnect the microphone: step 19, image 1 of 2 HTC Vive Pro 2 Sensor Array Replacement, Disconnect the microphone: step 19, image 2 of 2
      • Use the point of your spudger, or a clean fingernail, to flip up the locking tab on the microphone ZIF connector on the daughterboard.
      Ask FixBot
    2. HTC Vive Pro 2 Sensor Array Replacement: step 20, image 1 of 2 HTC Vive Pro 2 Sensor Array Replacement: step 20, image 2 of 2
      • Use tweezers, or your fingers, to pull the microphone cable straight out of its socket.
      Ask FixBot
    3. HTC Vive Pro 2 Sensor Array Replacement, Disconnect the sensor array: step 21, image 1 of 2 HTC Vive Pro 2 Sensor Array Replacement, Disconnect the sensor array: step 21, image 2 of 2
      • Use tweezers, or your fingers, to peel the conductive fabric off the sensor array ZIF connector on the motherboard.
      Ask FixBot
    4. HTC Vive Pro 2 Sensor Array Replacement: step 22, image 1 of 2 HTC Vive Pro 2 Sensor Array Replacement: step 22, image 2 of 2
      • Use your spudger, or a clean fingernail, to flip up the locking tab on the sensor array ZIF connector.
      Ask FixBot
    5. HTC Vive Pro 2 Sensor Array Replacement: step 23, image 1 of 1
      • Use your fingers to grip the left and right sides of the sensor array cable and pull it straight out of its socket.
      Ask FixBot
    6. HTC Vive Pro 2 Sensor Array Replacement, Remove the sensor array screws: step 24, image 1 of 2 HTC Vive Pro 2 Sensor Array Replacement, Remove the sensor array screws: step 24, image 2 of 2
      • Use a T5 Torx screwdriver to remove the four 3.0 mm‑long screws securing the top of the sensor array.
      Ask FixBot
    7. HTC Vive Pro 2 Sensor Array Replacement: step 25, image 1 of 3 HTC Vive Pro 2 Sensor Array Replacement: step 25, image 2 of 3 HTC Vive Pro 2 Sensor Array Replacement: step 25, image 3 of 3
      • Use a T6 Torx screwdriver to remove the four 3.8 mm‑long screws securing the front of the sensor array.
      Ask FixBot
    8. HTC Vive Pro 2 Sensor Array Replacement, Remove the sensor array: step 26, image 1 of 2 HTC Vive Pro 2 Sensor Array Replacement, Remove the sensor array: step 26, image 2 of 2
      • Lift the sensor array straight off the lens assembly and remove it, making sure you thread the cable through its slot.
      • During reassembly, make sure the sensor assembly cable is threaded through its slot before continuing.
      Ask FixBot
    1. HTC Vive Pro 2 Sensor Array Replacement, Disconnect the motherboard from the sensor array: step 27, image 1 of 3 HTC Vive Pro 2 Sensor Array Replacement, Disconnect the motherboard from the sensor array: step 27, image 2 of 3 HTC Vive Pro 2 Sensor Array Replacement, Disconnect the motherboard from the sensor array: step 27, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of tweezers or your fingers to remove the four pieces of Kapton tape covering the ZIF connectors.
      Ask FixBot
    2. HTC Vive Pro 2 Sensor Array Replacement: step 28, image 1 of 3 HTC Vive Pro 2 Sensor Array Replacement: step 28, image 2 of 3 HTC Vive Pro 2 Sensor Array Replacement: step 28, image 3 of 3
      • Use the flat end of your spudger to flip up the locking flap on a ZIF connector on the sensor array.
      • Use the pointed end of your spudger to disconnect the ribbon cable from its ZIF connector.
      • Repeat this procedure for all four of the ZIF connectors.
      Ask FixBot
    3. HTC Vive Pro 2 Sensor Array Replacement: step 29, image 1 of 2 HTC Vive Pro 2 Sensor Array Replacement: step 29, image 2 of 2
      • Use a pair of tweezers to remove the Kapton tape covering the two ZIF connectors on the back of the motherboard.
      Ask FixBot
    4. HTC Vive Pro 2 Sensor Array Replacement: step 30, image 1 of 3 HTC Vive Pro 2 Sensor Array Replacement: step 30, image 2 of 3 HTC Vive Pro 2 Sensor Array Replacement: step 30, image 3 of 3
      • Use the point of your spudger to unlock the ZIF connector on the back of the motherboard.
      • Use the spudger, or your fingers, to slide the ribbon cable out of its socket.
      Ask FixBot
    5. HTC Vive Pro 2 Sensor Array Replacement: step 31, image 1 of 3 HTC Vive Pro 2 Sensor Array Replacement: step 31, image 2 of 3 HTC Vive Pro 2 Sensor Array Replacement: step 31, image 3 of 3
      Ask FixBot
    6. HTC Vive Pro 2 Sensor Array Replacement: step 32, image 1 of 2 HTC Vive Pro 2 Sensor Array Replacement: step 32, image 2 of 2
      • Use a pair of tweezers to remove the Kapton tape covering the remaining ZIF connector on the back of the motherboard.
      Ask FixBot
    7. HTC Vive Pro 2 Sensor Array Replacement: step 33, image 1 of 3 HTC Vive Pro 2 Sensor Array Replacement: step 33, image 2 of 3 HTC Vive Pro 2 Sensor Array Replacement: step 33, image 3 of 3
      • Use the pointed end of your spudger to unlock the ZIF connector on the back of the motherboard.
      Ask FixBot
    8. HTC Vive Pro 2 Sensor Array Replacement, Remove the motherboard: step 34, image 1 of 2 HTC Vive Pro 2 Sensor Array Replacement, Remove the motherboard: step 34, image 2 of 2
      • Reposition the long ribbon cable covering the back of the motherboard so it's out of the way.
      • Don't sharply crease or fold the ribbon cable.
      Ask FixBot
    9. HTC Vive Pro 2 Sensor Array Replacement: step 35, image 1 of 2 HTC Vive Pro 2 Sensor Array Replacement: step 35, image 2 of 2
      • Use a T5 Torx screwdriver to remove the three 3.0 mm‑long screws securing the motherboard to the sensor array.
      Ask FixBot
    10. HTC Vive Pro 2 Sensor Array Replacement: step 36, image 1 of 1
      • Apply a heated iOpener to the back of the motherboard for one minute to soften the light adhesive securing it to the sensor array.
      Ask FixBot
    11. HTC Vive Pro 2 Sensor Array Replacement: step 37, image 1 of 1
      • Remove the motherboard from the sensor array.
      • There are several plastic clips lightly securing the perimeter of the motherboard to the sensor array.
      • During reassembly, don't forget to reinstall any Kapton tape that was removed during disassembly. This will prevent malfunction of the sensors.
      Ask FixBot
    1. HTC Vive Pro 2 Sensor Array Replacement, Only the sensor array remains: step 38, image 1 of 1
      • Only the sensor array remains.
      Ask FixBot
Alex Diaz-Kokaisl
253,164 Reputation
1,200 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,189 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 63
All Time: 543
