Up to 20% off select tools
HTC Vive Pro 2 Outer Shell Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
71
All Time:
554
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the outer shell on your HTC Vive Pro 2 headset.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the procedure.
Power off and unplug your headset before you begin your repair.
    1. HTC Vive Pro 2 Outer Shell Replacement, Unplug the All-In-One Cable: step 1, image 1 of 3 HTC Vive Pro 2 Outer Shell Replacement, Unplug the All-In-One Cable: step 1, image 2 of 3 HTC Vive Pro 2 Outer Shell Replacement, Unplug the All-In-One Cable: step 1, image 3 of 3
      • Unplug the All-In-One Cable from your headset.
      Ask FixBot
    2. HTC Vive Pro 2 Outer Shell Replacement, Remove the All-In-One Cable: step 2, image 1 of 2 HTC Vive Pro 2 Outer Shell Replacement, Remove the All-In-One Cable: step 2, image 2 of 2
      • Remove the All-In-One Cable from the cable guides along the left side of the head strap.
      • During reassembly, connect the All-In-One Cable to the headset before routing it through the cable guides. This will ensure it has the right amount of slack.
      Ask FixBot
    3. HTC Vive Pro 2 Outer Shell Replacement, Remove the All-in-One cable bracket screws: step 3, image 1 of 2 HTC Vive Pro 2 Outer Shell Replacement, Remove the All-in-One cable bracket screws: step 3, image 2 of 2
      • Use a Phillips screwdriver to remove the three 2.4 mm‑long screws securing the All-in-One cable bracket.
      Ask FixBot
    4. HTC Vive Pro 2 Outer Shell Replacement, Remove the All-in-One cable bracket: step 4, image 1 of 2 HTC Vive Pro 2 Outer Shell Replacement, Remove the All-in-One cable bracket: step 4, image 2 of 2
      • Lift the All-in-One cable bracket straight off the headset and remove it.
      • The bracket is aligned on the headset with pegs. During reassembly, make sure the pegs align properly and the bracket sits flush on the headset.
      Ask FixBot
    5. HTC Vive Pro 2 Outer Shell Replacement, Remove the outer shell: step 5, image 1 of 3 HTC Vive Pro 2 Outer Shell Replacement, Remove the outer shell: step 5, image 2 of 3 HTC Vive Pro 2 Outer Shell Replacement, Remove the outer shell: step 5, image 3 of 3
      • The four screws securing the outer shell are covered with black stickers. If the stickers are difficult to remove, simply press your T6 Torx driver through them.
      Ask FixBot
    6. HTC Vive Pro 2 Outer Shell Replacement: step 6, image 1 of 2 HTC Vive Pro 2 Outer Shell Replacement: step 6, image 2 of 2
      • Use a T6 Torx screwdriver to remove the four 3.9 mm screws (two on top, two on bottom) securing the outer shell to the headset.
      Ask FixBot
    7. HTC Vive Pro 2 Outer Shell Replacement: step 7, image 1 of 3 HTC Vive Pro 2 Outer Shell Replacement: step 7, image 2 of 3 HTC Vive Pro 2 Outer Shell Replacement: step 7, image 3 of 3
      • Insert an opening pick into the seam between the two halves of the outer shell.
      • Slide the opening pick through the seam to dislodge the clips securing it to the headset.
      • Only insert the opening pick as far as necessary. There are ribbon cables underneath the outer shell.
      Ask FixBot
    8. HTC Vive Pro 2 Outer Shell Replacement: step 8, image 1 of 3 HTC Vive Pro 2 Outer Shell Replacement: step 8, image 2 of 3 HTC Vive Pro 2 Outer Shell Replacement: step 8, image 3 of 3
      • Continue sliding the opening pick through each seam until all clips have been dislodged.
      Ask FixBot
    9. HTC Vive Pro 2 Outer Shell Replacement: step 9, image 1 of 3 HTC Vive Pro 2 Outer Shell Replacement: step 9, image 2 of 3 HTC Vive Pro 2 Outer Shell Replacement: step 9, image 3 of 3
      • Carefully slide each half of the outer shell off of the sensor array.
      • Be careful not to snag any of the ribbon cables underneath.
      Ask FixBot
Alex Diaz-Kokaisl
253,211 Reputation
1,200 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,189 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 71
All Time: 554
