HTC Vive Pro 2 Motherboard Replacement
    1. HTC Vive Pro 2 Motherboard Replacement, Reposition the head strap: step 1, image 1 of 2 HTC Vive Pro 2 Motherboard Replacement, Reposition the head strap: step 1, image 2 of 2
      • Rotate the head strap forward as far as it will go.
      Ask FixBot
    2. HTC Vive Pro 2 Motherboard Replacement, Unplug the All-In-One Cable: step 2, image 1 of 2 HTC Vive Pro 2 Motherboard Replacement, Unplug the All-In-One Cable: step 2, image 2 of 2
      • Unplug the All-In-One Cable from your headset.
      Ask FixBot
    3. HTC Vive Pro 2 Motherboard Replacement, Remove the All-In-One Cable: step 3, image 1 of 3 HTC Vive Pro 2 Motherboard Replacement, Remove the All-In-One Cable: step 3, image 2 of 3 HTC Vive Pro 2 Motherboard Replacement, Remove the All-In-One Cable: step 3, image 3 of 3
      • Remove the All-In-One Cable from the cable guides along the left side of the head strap.
      • During reassembly, connect the All-In-One Cable to the headset before routing it through the cable guides. This will ensure it has the right amount of slack.
      Ask FixBot
    1. HTC Vive Pro 2 Motherboard Replacement, Remove the top strap: step 4, image 1 of 2 HTC Vive Pro 2 Motherboard Replacement, Remove the top strap: step 4, image 2 of 2
      • Separate the top strap from itself where the Velcro secures it.
      Ask FixBot
    2. HTC Vive Pro 2 Motherboard Replacement: step 5, image 1 of 3 HTC Vive Pro 2 Motherboard Replacement: step 5, image 2 of 3 HTC Vive Pro 2 Motherboard Replacement: step 5, image 3 of 3
      • Peel back the Velcro securing the rear of the top strap.
      • Feed the top strap out through the head strap to partially remove it.
      Ask FixBot
    3. HTC Vive Pro 2 Motherboard Replacement: step 6, image 1 of 3 HTC Vive Pro 2 Motherboard Replacement: step 6, image 2 of 3 HTC Vive Pro 2 Motherboard Replacement: step 6, image 3 of 3
      • Feed the top strap through the clip near the front of headset to fully remove it.
      Ask FixBot
    1. HTC Vive Pro 2 Motherboard Replacement, Remove the front side foam pads: step 7, image 1 of 3 HTC Vive Pro 2 Motherboard Replacement, Remove the front side foam pads: step 7, image 2 of 3 HTC Vive Pro 2 Motherboard Replacement, Remove the front side foam pads: step 7, image 3 of 3
      • Peel off both front side foam pads to uncover the speaker wires.
      Ask FixBot
    2. HTC Vive Pro 2 Motherboard Replacement, Remove the two rubber spacers: step 8, image 1 of 3 HTC Vive Pro 2 Motherboard Replacement, Remove the two rubber spacers: step 8, image 2 of 3 HTC Vive Pro 2 Motherboard Replacement, Remove the two rubber spacers: step 8, image 3 of 3
      • Use the point of your spudger to pry out the two rubber spacers next to the headphone screws.
      • Be careful not to accidentally pry any of the speaker wires under the rubber spacer.
      Ask FixBot
    3. HTC Vive Pro 2 Motherboard Replacement, Disconnect the speaker wires: step 9, image 1 of 3 HTC Vive Pro 2 Motherboard Replacement, Disconnect the speaker wires: step 9, image 2 of 3 HTC Vive Pro 2 Motherboard Replacement, Disconnect the speaker wires: step 9, image 3 of 3
      • Use the point of your spudger to pry up and disconnect both the left and right headphone speaker wires.
      Ask FixBot
    4. HTC Vive Pro 2 Motherboard Replacement, Remove the head strap: step 10, image 1 of 2 HTC Vive Pro 2 Motherboard Replacement, Remove the head strap: step 10, image 2 of 2
      • Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
      • Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
      • Four 3.9 mm screws (two on each side)
      • Two 4.1 mm screws (one on each side)
      Ask FixBot
    5. HTC Vive Pro 2 Motherboard Replacement: step 11, image 1 of 1
      • Remove the two plastic spacers underneath the previously removed Torx T6 screw.
      Ask FixBot
    6. HTC Vive Pro 2 Motherboard Replacement: step 12, image 1 of 3 HTC Vive Pro 2 Motherboard Replacement: step 12, image 2 of 3 HTC Vive Pro 2 Motherboard Replacement: step 12, image 3 of 3
      • Thread the headphone speaker wires out through both ends of the head strap.
      Ask FixBot
    1. HTC Vive Pro 2 Motherboard Replacement, Remove the outer shell: step 13, image 1 of 3 HTC Vive Pro 2 Motherboard Replacement, Remove the outer shell: step 13, image 2 of 3 HTC Vive Pro 2 Motherboard Replacement, Remove the outer shell: step 13, image 3 of 3
      • The four screws securing the outer shell are covered with black stickers. If the stickers are difficult to remove, simply press your T6 Torx driver through them.
      Ask FixBot
    2. HTC Vive Pro 2 Motherboard Replacement: step 14, image 1 of 2 HTC Vive Pro 2 Motherboard Replacement: step 14, image 2 of 2
      • Use a T6 Torx screwdriver to remove the four 3.9 mm screws (two on top, two on bottom) securing the outer shell to the headset.
      Ask FixBot
    3. HTC Vive Pro 2 Motherboard Replacement: step 15, image 1 of 3 HTC Vive Pro 2 Motherboard Replacement: step 15, image 2 of 3 HTC Vive Pro 2 Motherboard Replacement: step 15, image 3 of 3
      • Insert an opening pick into the seam between the two halves of the outer shell.
      • Slide the opening pick through the seam to dislodge the clips securing it to the headset.
      • Only insert the opening pick as far as necessary. There are ribbon cables underneath the outer shell.
      Ask FixBot
    4. HTC Vive Pro 2 Motherboard Replacement: step 16, image 1 of 3 HTC Vive Pro 2 Motherboard Replacement: step 16, image 2 of 3 HTC Vive Pro 2 Motherboard Replacement: step 16, image 3 of 3
      • Continue sliding the opening pick through each seam until all clips have been dislodged.
      Ask FixBot
    5. HTC Vive Pro 2 Motherboard Replacement: step 17, image 1 of 3 HTC Vive Pro 2 Motherboard Replacement: step 17, image 2 of 3 HTC Vive Pro 2 Motherboard Replacement: step 17, image 3 of 3
      • Carefully slide each half of the outer shell off of the sensor array.
      • Be careful not to snag any of the ribbon cables underneath.
      Ask FixBot
    1. HTC Vive Pro 2 Motherboard Replacement, Disconnect the microphone: step 18, image 1 of 2 HTC Vive Pro 2 Motherboard Replacement, Disconnect the microphone: step 18, image 2 of 2
      • Use the point of your spudger, or a clean fingernail, to flip up the locking tab on the microphone ZIF connector on the daughterboard.
      Ask FixBot
    2. HTC Vive Pro 2 Motherboard Replacement: step 19, image 1 of 2 HTC Vive Pro 2 Motherboard Replacement: step 19, image 2 of 2
      • Use tweezers, or your fingers, to pull the microphone cable straight out of its socket.
      Ask FixBot
    3. HTC Vive Pro 2 Motherboard Replacement, Disconnect the sensor array: step 20, image 1 of 2 HTC Vive Pro 2 Motherboard Replacement, Disconnect the sensor array: step 20, image 2 of 2
      • Use tweezers, or your fingers, to peel the conductive fabric off the sensor array ZIF connector on the motherboard.
      Ask FixBot
    4. HTC Vive Pro 2 Motherboard Replacement: step 21, image 1 of 2 HTC Vive Pro 2 Motherboard Replacement: step 21, image 2 of 2
      • Use your spudger, or a clean fingernail, to flip up the locking tab on the sensor array ZIF connector.
      Ask FixBot
    5. HTC Vive Pro 2 Motherboard Replacement: step 22, image 1 of 1
      • Use your fingers to grip the left and right sides of the sensor array cable and pull it straight out of its socket.
      Ask FixBot
    6. HTC Vive Pro 2 Motherboard Replacement, Remove the sensor array screws: step 23, image 1 of 2 HTC Vive Pro 2 Motherboard Replacement, Remove the sensor array screws: step 23, image 2 of 2
      • Use a T5 Torx screwdriver to remove the four 3.0 mm‑long screws securing the top of the sensor array.
      Ask FixBot
    7. HTC Vive Pro 2 Motherboard Replacement: step 24, image 1 of 3 HTC Vive Pro 2 Motherboard Replacement: step 24, image 2 of 3 HTC Vive Pro 2 Motherboard Replacement: step 24, image 3 of 3
      • Use a T6 Torx screwdriver to remove the four 3.8 mm‑long screws securing the front of the sensor array.
      Ask FixBot
    8. HTC Vive Pro 2 Motherboard Replacement, Remove the sensor array: step 25, image 1 of 2 HTC Vive Pro 2 Motherboard Replacement, Remove the sensor array: step 25, image 2 of 2
      • Lift the sensor array straight off the lens assembly and remove it, making sure you thread the cable through its slot.
      • During reassembly, make sure the sensor assembly cable is threaded through its slot before continuing.
      Ask FixBot
    1. HTC Vive Pro 2 Motherboard Replacement, Disconnect the motherboard from the sensor array: step 26, image 1 of 3 HTC Vive Pro 2 Motherboard Replacement, Disconnect the motherboard from the sensor array: step 26, image 2 of 3 HTC Vive Pro 2 Motherboard Replacement, Disconnect the motherboard from the sensor array: step 26, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of tweezers or your fingers to remove the four pieces of Kapton tape covering the ZIF connectors.
      Ask FixBot
    2. HTC Vive Pro 2 Motherboard Replacement: step 27, image 1 of 3 HTC Vive Pro 2 Motherboard Replacement: step 27, image 2 of 3 HTC Vive Pro 2 Motherboard Replacement: step 27, image 3 of 3
      • Use the flat end of your spudger to flip up the locking flap on a ZIF connector on the sensor array.
      • Use the pointed end of your spudger to disconnect the ribbon cable from its ZIF connector.
      • Repeat this procedure for all four of the ZIF connectors.
      Ask FixBot
    3. HTC Vive Pro 2 Motherboard Replacement: step 28, image 1 of 2 HTC Vive Pro 2 Motherboard Replacement: step 28, image 2 of 2
      • Use a pair of tweezers to remove the Kapton tape covering the two ZIF connectors on the back of the motherboard.
      Ask FixBot
    4. HTC Vive Pro 2 Motherboard Replacement: step 29, image 1 of 3 HTC Vive Pro 2 Motherboard Replacement: step 29, image 2 of 3 HTC Vive Pro 2 Motherboard Replacement: step 29, image 3 of 3
      • Use the point of your spudger to unlock the ZIF connector on the back of the motherboard.
      • Use the spudger, or your fingers, to slide the ribbon cable out of its socket.
      Ask FixBot
    5. HTC Vive Pro 2 Motherboard Replacement: step 30, image 1 of 3 HTC Vive Pro 2 Motherboard Replacement: step 30, image 2 of 3 HTC Vive Pro 2 Motherboard Replacement: step 30, image 3 of 3
      Ask FixBot
    6. HTC Vive Pro 2 Motherboard Replacement: step 31, image 1 of 2 HTC Vive Pro 2 Motherboard Replacement: step 31, image 2 of 2
      • Use a pair of tweezers to remove the Kapton tape covering the remaining ZIF connector on the back of the motherboard.
      Ask FixBot
    7. HTC Vive Pro 2 Motherboard Replacement: step 32, image 1 of 3 HTC Vive Pro 2 Motherboard Replacement: step 32, image 2 of 3 HTC Vive Pro 2 Motherboard Replacement: step 32, image 3 of 3
      • Use the pointed end of your spudger to unlock the ZIF connector on the back of the motherboard.
      Ask FixBot
    8. HTC Vive Pro 2 Motherboard Replacement, Remove the motherboard: step 33, image 1 of 2 HTC Vive Pro 2 Motherboard Replacement, Remove the motherboard: step 33, image 2 of 2
      • Reposition the long ribbon cable covering the back of the motherboard so it's out of the way.
      • Don't sharply crease or fold the ribbon cable.
      Ask FixBot
    9. HTC Vive Pro 2 Motherboard Replacement: step 34, image 1 of 2 HTC Vive Pro 2 Motherboard Replacement: step 34, image 2 of 2
      • Use a T5 Torx screwdriver to remove the three 3.0 mm‑long screws securing the motherboard to the sensor array.
      Ask FixBot
    10. HTC Vive Pro 2 Motherboard Replacement: step 35, image 1 of 1
      • Apply a heated iOpener to the back of the motherboard for one minute to soften the light adhesive securing it to the sensor array.
      Ask FixBot
    11. HTC Vive Pro 2 Motherboard Replacement: step 36, image 1 of 1
      • Remove the motherboard from the sensor array.
      • There are several plastic clips lightly securing the perimeter of the motherboard to the sensor array.
      • During reassembly, don't forget to reinstall any Kapton tape that was removed during disassembly. This will prevent malfunction of the sensors.
      Ask FixBot
Alex Diaz-Kokaisl
248,646 Reputation
1,203 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,826 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 26
All Time: 457
