HTC Vive Pro 2 Headphones Replacement
  1. HTC Vive Pro 2 Headphones Replacement, Remove the head strap padding: step 1, image 1 of 3 HTC Vive Pro 2 Headphones Replacement, Remove the head strap padding: step 1, image 2 of 3 HTC Vive Pro 2 Headphones Replacement, Remove the head strap padding: step 1, image 3 of 3
    • Peel off the thin piece of padding covering the headphone screw for each headphone you're replacing.
    Ask FixBot
  2. HTC Vive Pro 2 Headphones Replacement, Unscrew the headphones: step 2, image 1 of 2 HTC Vive Pro 2 Headphones Replacement, Unscrew the headphones: step 2, image 2 of 2
    • Use your Phillips screwdriver to remove the 6.4 mm screw securing each headphone you are replacing.
    Ask FixBot
  3. HTC Vive Pro 2 Headphones Replacement, Remove the headphones: step 3, image 1 of 3 HTC Vive Pro 2 Headphones Replacement, Remove the headphones: step 3, image 2 of 3 HTC Vive Pro 2 Headphones Replacement, Remove the headphones: step 3, image 3 of 3
    • Remove the headphones.
    Ask FixBot
  4. HTC Vive Pro 2 Headphones Replacement, Remove the headphone pad: step 4, image 1 of 2 HTC Vive Pro 2 Headphones Replacement, Remove the headphone pad: step 4, image 2 of 2
    • Insert an opening pick under the headphone pad and pry up to unclip it from the headphone.
    Ask FixBot
  5. HTC Vive Pro 2 Headphones Replacement: step 5, image 1 of 2 HTC Vive Pro 2 Headphones Replacement: step 5, image 2 of 2
    • Pull the headphone pad straight off the headphone to remove it.
    Ask FixBot
  6. HTC Vive Pro 2 Headphones Replacement: step 6, image 1 of 1
    • You're now left with the headphone for replacement.
    Ask FixBot
Alex Diaz-Kokaisl
244,784 Reputation
1,203 Guides authored
iFixit Member of iFixit
Staff
123 Members
28,230 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 45
All Time: 535
