HTC Vive Pro 2 Head Strap Replacement
    1. HTC Vive Pro 2 Head Strap Replacement, Reposition the head strap: step 1, image 1 of 2 HTC Vive Pro 2 Head Strap Replacement, Reposition the head strap: step 1, image 2 of 2
      • Rotate the head strap forward as far as it will go.
      Ask FixBot
    2. HTC Vive Pro 2 Head Strap Replacement, Unplug the All-In-One Cable: step 2, image 1 of 2 HTC Vive Pro 2 Head Strap Replacement, Unplug the All-In-One Cable: step 2, image 2 of 2
      • Unplug the All-In-One Cable from your headset.
      Ask FixBot
    3. HTC Vive Pro 2 Head Strap Replacement, Remove the All-In-One Cable: step 3, image 1 of 3 HTC Vive Pro 2 Head Strap Replacement, Remove the All-In-One Cable: step 3, image 2 of 3 HTC Vive Pro 2 Head Strap Replacement, Remove the All-In-One Cable: step 3, image 3 of 3
      • Remove the All-In-One Cable from the cable guides along the left side of the head strap.
      • During reassembly, connect the All-In-One Cable to the headset before routing it through the cable guides. This will ensure it has the right amount of slack.
      Ask FixBot
    1. HTC Vive Pro 2 Head Strap Replacement, Remove the top strap: step 4, image 1 of 2 HTC Vive Pro 2 Head Strap Replacement, Remove the top strap: step 4, image 2 of 2
      • Separate the top strap from itself where the Velcro secures it.
      Ask FixBot
    2. HTC Vive Pro 2 Head Strap Replacement: step 5, image 1 of 3 HTC Vive Pro 2 Head Strap Replacement: step 5, image 2 of 3 HTC Vive Pro 2 Head Strap Replacement: step 5, image 3 of 3
      • Peel back the Velcro securing the rear of the top strap.
      • Feed the top strap out through the head strap to partially remove it.
      Ask FixBot
    3. HTC Vive Pro 2 Head Strap Replacement: step 6, image 1 of 3 HTC Vive Pro 2 Head Strap Replacement: step 6, image 2 of 3 HTC Vive Pro 2 Head Strap Replacement: step 6, image 3 of 3
      • Feed the top strap through the clip near the front of headset to fully remove it.
      Ask FixBot
    1. HTC Vive Pro 2 Head Strap Replacement, Remove the front side foam pads: step 7, image 1 of 3 HTC Vive Pro 2 Head Strap Replacement, Remove the front side foam pads: step 7, image 2 of 3 HTC Vive Pro 2 Head Strap Replacement, Remove the front side foam pads: step 7, image 3 of 3
      • Peel off both front side foam pads to uncover the speaker wires.
      Ask FixBot
    2. HTC Vive Pro 2 Head Strap Replacement, Remove the two rubber spacers: step 8, image 1 of 3 HTC Vive Pro 2 Head Strap Replacement, Remove the two rubber spacers: step 8, image 2 of 3 HTC Vive Pro 2 Head Strap Replacement, Remove the two rubber spacers: step 8, image 3 of 3
      • Use the point of your spudger to pry out the two rubber spacers next to the headphone screws.
      • Be careful not to accidentally pry any of the speaker wires under the rubber spacer.
      Ask FixBot
    3. HTC Vive Pro 2 Head Strap Replacement, Disconnect the speaker wires: step 9, image 1 of 3 HTC Vive Pro 2 Head Strap Replacement, Disconnect the speaker wires: step 9, image 2 of 3 HTC Vive Pro 2 Head Strap Replacement, Disconnect the speaker wires: step 9, image 3 of 3
      • Use the point of your spudger to pry up and disconnect both the left and right headphone speaker wires.
      Ask FixBot
    4. HTC Vive Pro 2 Head Strap Replacement, Remove the head strap: step 10, image 1 of 2 HTC Vive Pro 2 Head Strap Replacement, Remove the head strap: step 10, image 2 of 2
      • Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
      • Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
      • Four 3.9 mm screws (two on each side)
      • Two 4.1 mm screws (one on each side)
      Ask FixBot
    5. HTC Vive Pro 2 Head Strap Replacement: step 11, image 1 of 1
      • Remove the two plastic spacers underneath the previously removed Torx T6 screw.
      Ask FixBot
    6. HTC Vive Pro 2 Head Strap Replacement: step 12, image 1 of 3 HTC Vive Pro 2 Head Strap Replacement: step 12, image 2 of 3 HTC Vive Pro 2 Head Strap Replacement: step 12, image 3 of 3
      • Thread the headphone speaker wires out through both ends of the head strap.
      Ask FixBot
    1. HTC Vive Pro 2 Head Strap Replacement, Remove the front side foam pads: step 13, image 1 of 3 HTC Vive Pro 2 Head Strap Replacement, Remove the front side foam pads: step 13, image 2 of 3 HTC Vive Pro 2 Head Strap Replacement, Remove the front side foam pads: step 13, image 3 of 3
      Ask FixBot
    2. HTC Vive Pro 2 Head Strap Replacement, Remove the two rubber spacers: step 14, image 1 of 3 HTC Vive Pro 2 Head Strap Replacement, Remove the two rubber spacers: step 14, image 2 of 3 HTC Vive Pro 2 Head Strap Replacement, Remove the two rubber spacers: step 14, image 3 of 3
      Ask FixBot
    3. HTC Vive Pro 2 Head Strap Replacement, Disconnect the speaker wires: step 15, image 1 of 2 HTC Vive Pro 2 Head Strap Replacement, Disconnect the speaker wires: step 15, image 2 of 2
      Ask FixBot
    4. HTC Vive Pro 2 Head Strap Replacement, Remove the head strap: step 16, image 1 of 2 HTC Vive Pro 2 Head Strap Replacement, Remove the head strap: step 16, image 2 of 2
      Ask FixBot
    5. HTC Vive Pro 2 Head Strap Replacement: step 17, image 1 of 1
      Ask FixBot
    6. HTC Vive Pro 2 Head Strap Replacement: step 18, image 1 of 3 HTC Vive Pro 2 Head Strap Replacement: step 18, image 2 of 3 HTC Vive Pro 2 Head Strap Replacement: step 18, image 3 of 3
      Ask FixBot
Alex Diaz-Kokaisl
248,631 Reputation
1,203 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,826 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 27
All Time: 501
