HTC Vive Pro 2 Daughterboard Replacement
    1. HTC Vive Pro 2 Daughterboard Replacement, Reposition the head strap: step 1, image 1 of 2 HTC Vive Pro 2 Daughterboard Replacement, Reposition the head strap: step 1, image 2 of 2
      • Rotate the head strap forward as far as it will go.
      Ask FixBot
    2. HTC Vive Pro 2 Daughterboard Replacement, Unplug the All-In-One Cable: step 2, image 1 of 2 HTC Vive Pro 2 Daughterboard Replacement, Unplug the All-In-One Cable: step 2, image 2 of 2
      • Unplug the All-In-One Cable from your headset.
      Ask FixBot
    3. HTC Vive Pro 2 Daughterboard Replacement, Remove the All-In-One Cable: step 3, image 1 of 3 HTC Vive Pro 2 Daughterboard Replacement, Remove the All-In-One Cable: step 3, image 2 of 3 HTC Vive Pro 2 Daughterboard Replacement, Remove the All-In-One Cable: step 3, image 3 of 3
      • Remove the All-In-One Cable from the cable guides along the left side of the head strap.
      • During reassembly, connect the All-In-One Cable to the headset before routing it through the cable guides. This will ensure it has the right amount of slack.
      Ask FixBot
    1. HTC Vive Pro 2 Daughterboard Replacement, Remove the top strap: step 4, image 1 of 2 HTC Vive Pro 2 Daughterboard Replacement, Remove the top strap: step 4, image 2 of 2
      • Separate the top strap from itself where the Velcro secures it.
      Ask FixBot
    2. HTC Vive Pro 2 Daughterboard Replacement: step 5, image 1 of 3 HTC Vive Pro 2 Daughterboard Replacement: step 5, image 2 of 3 HTC Vive Pro 2 Daughterboard Replacement: step 5, image 3 of 3
      • Peel back the Velcro securing the rear of the top strap.
      • Feed the top strap out through the head strap to partially remove it.
      Ask FixBot
    3. HTC Vive Pro 2 Daughterboard Replacement: step 6, image 1 of 3 HTC Vive Pro 2 Daughterboard Replacement: step 6, image 2 of 3 HTC Vive Pro 2 Daughterboard Replacement: step 6, image 3 of 3
      • Feed the top strap through the clip near the front of headset to fully remove it.
      Ask FixBot
    1. HTC Vive Pro 2 Daughterboard Replacement, Remove the front side foam pads: step 7, image 1 of 3 HTC Vive Pro 2 Daughterboard Replacement, Remove the front side foam pads: step 7, image 2 of 3 HTC Vive Pro 2 Daughterboard Replacement, Remove the front side foam pads: step 7, image 3 of 3
      • Peel off both front side foam pads to uncover the speaker wires.
      Ask FixBot
    2. HTC Vive Pro 2 Daughterboard Replacement, Remove the two rubber spacers: step 8, image 1 of 3 HTC Vive Pro 2 Daughterboard Replacement, Remove the two rubber spacers: step 8, image 2 of 3 HTC Vive Pro 2 Daughterboard Replacement, Remove the two rubber spacers: step 8, image 3 of 3
      • Use the point of your spudger to pry out the two rubber spacers next to the headphone screws.
      • Be careful not to accidentally pry any of the speaker wires under the rubber spacer.
      Ask FixBot
    3. HTC Vive Pro 2 Daughterboard Replacement, Disconnect the speaker wires: step 9, image 1 of 3 HTC Vive Pro 2 Daughterboard Replacement, Disconnect the speaker wires: step 9, image 2 of 3 HTC Vive Pro 2 Daughterboard Replacement, Disconnect the speaker wires: step 9, image 3 of 3
      • Use the point of your spudger to pry up and disconnect both the left and right headphone speaker wires.
      Ask FixBot
    4. HTC Vive Pro 2 Daughterboard Replacement, Remove the head strap: step 10, image 1 of 2 HTC Vive Pro 2 Daughterboard Replacement, Remove the head strap: step 10, image 2 of 2
      • Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
      • Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
      • Four 3.9 mm screws (two on each side)
      • Two 4.1 mm screws (one on each side)
      Ask FixBot
    5. HTC Vive Pro 2 Daughterboard Replacement: step 11, image 1 of 1
      • Remove the two plastic spacers underneath the previously removed Torx T6 screw.
      Ask FixBot
    6. HTC Vive Pro 2 Daughterboard Replacement: step 12, image 1 of 3 HTC Vive Pro 2 Daughterboard Replacement: step 12, image 2 of 3 HTC Vive Pro 2 Daughterboard Replacement: step 12, image 3 of 3
      • Thread the headphone speaker wires out through both ends of the head strap.
      Ask FixBot
    1. HTC Vive Pro 2 Daughterboard Replacement, Remove the outer shell: step 13, image 1 of 3 HTC Vive Pro 2 Daughterboard Replacement, Remove the outer shell: step 13, image 2 of 3 HTC Vive Pro 2 Daughterboard Replacement, Remove the outer shell: step 13, image 3 of 3
      • The four screws securing the outer shell are covered with black stickers. If the stickers are difficult to remove, simply press your T6 Torx driver through them.
      Ask FixBot
    2. HTC Vive Pro 2 Daughterboard Replacement: step 14, image 1 of 2 HTC Vive Pro 2 Daughterboard Replacement: step 14, image 2 of 2
      • Use a T6 Torx screwdriver to remove the four 3.9 mm screws (two on top, two on bottom) securing the outer shell to the headset.
      Ask FixBot
    3. HTC Vive Pro 2 Daughterboard Replacement: step 15, image 1 of 3 HTC Vive Pro 2 Daughterboard Replacement: step 15, image 2 of 3 HTC Vive Pro 2 Daughterboard Replacement: step 15, image 3 of 3
      • Insert an opening pick into the seam between the two halves of the outer shell.
      • Slide the opening pick through the seam to dislodge the clips securing it to the headset.
      • Only insert the opening pick as far as necessary. There are ribbon cables underneath the outer shell.
      Ask FixBot
    4. HTC Vive Pro 2 Daughterboard Replacement: step 16, image 1 of 3 HTC Vive Pro 2 Daughterboard Replacement: step 16, image 2 of 3 HTC Vive Pro 2 Daughterboard Replacement: step 16, image 3 of 3
      • Continue sliding the opening pick through each seam until all clips have been dislodged.
      Ask FixBot
    5. HTC Vive Pro 2 Daughterboard Replacement: step 17, image 1 of 3 HTC Vive Pro 2 Daughterboard Replacement: step 17, image 2 of 3 HTC Vive Pro 2 Daughterboard Replacement: step 17, image 3 of 3
      • Carefully slide each half of the outer shell off of the sensor array.
      • Be careful not to snag any of the ribbon cables underneath.
      Ask FixBot
    1. HTC Vive Pro 2 Daughterboard Replacement, Disconnect the microphone: step 18, image 1 of 2 HTC Vive Pro 2 Daughterboard Replacement, Disconnect the microphone: step 18, image 2 of 2
      • Use the point of your spudger, or a clean fingernail, to flip up the locking tab on the microphone ZIF connector on the daughterboard.
      Ask FixBot
    2. HTC Vive Pro 2 Daughterboard Replacement: step 19, image 1 of 2 HTC Vive Pro 2 Daughterboard Replacement: step 19, image 2 of 2
      • Use tweezers, or your fingers, to pull the microphone cable straight out of its socket.
      Ask FixBot
    3. HTC Vive Pro 2 Daughterboard Replacement, Disconnect the sensor array: step 20, image 1 of 2 HTC Vive Pro 2 Daughterboard Replacement, Disconnect the sensor array: step 20, image 2 of 2
      • Use tweezers, or your fingers, to peel the conductive fabric off the sensor array ZIF connector on the motherboard.
      Ask FixBot
    4. HTC Vive Pro 2 Daughterboard Replacement: step 21, image 1 of 2 HTC Vive Pro 2 Daughterboard Replacement: step 21, image 2 of 2
      • Use your spudger, or a clean fingernail, to flip up the locking tab on the sensor array ZIF connector.
      Ask FixBot
    5. HTC Vive Pro 2 Daughterboard Replacement: step 22, image 1 of 1
      • Use your fingers to grip the left and right sides of the sensor array cable and pull it straight out of its socket.
      Ask FixBot
    6. HTC Vive Pro 2 Daughterboard Replacement, Remove the sensor array screws: step 23, image 1 of 2 HTC Vive Pro 2 Daughterboard Replacement, Remove the sensor array screws: step 23, image 2 of 2
      • Use a T5 Torx screwdriver to remove the four 3.0 mm‑long screws securing the top of the sensor array.
      Ask FixBot
    7. HTC Vive Pro 2 Daughterboard Replacement: step 24, image 1 of 3 HTC Vive Pro 2 Daughterboard Replacement: step 24, image 2 of 3 HTC Vive Pro 2 Daughterboard Replacement: step 24, image 3 of 3
      • Use a T6 Torx screwdriver to remove the four 3.8 mm‑long screws securing the front of the sensor array.
      Ask FixBot
    8. HTC Vive Pro 2 Daughterboard Replacement, Remove the sensor array: step 25, image 1 of 2 HTC Vive Pro 2 Daughterboard Replacement, Remove the sensor array: step 25, image 2 of 2
      • Lift the sensor array straight off the lens assembly and remove it, making sure you thread the cable through its slot.
      • During reassembly, make sure the sensor assembly cable is threaded through its slot before continuing.
      Ask FixBot
    1. HTC Vive Pro 2 Daughterboard Replacement, Remove the thermal pad: step 26, image 1 of 3 HTC Vive Pro 2 Daughterboard Replacement, Remove the thermal pad: step 26, image 2 of 3 HTC Vive Pro 2 Daughterboard Replacement, Remove the thermal pad: step 26, image 3 of 3
      • Use your fingers to peel up the thermal pad covering the daughterboard.
      • The thermal pad will likely remove the Kapton tape from the ZIF connectors on the daughterboard. Replace the Kapton tape if necessary.
      • Set aside the thermal pad. You'll reuse it during reassembly.
      Ask FixBot
    2. HTC Vive Pro 2 Daughterboard Replacement, Disconnect the lens assembly: step 27, image 1 of 3 HTC Vive Pro 2 Daughterboard Replacement, Disconnect the lens assembly: step 27, image 2 of 3 HTC Vive Pro 2 Daughterboard Replacement, Disconnect the lens assembly: step 27, image 3 of 3
      • Insert the flat end of a spudger under a corner of the lens assembly press connector.
      • Don't insert your spudger anywhere else, as you risk dislodging nearby surface-mounted components.
      • Twist the spudger to lift the press connector up and disconnect it.
      • Repeat the same process to disconnect the other lens assembly press connector.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      Ask FixBot
    3. HTC Vive Pro 2 Daughterboard Replacement, Disconnect the IPD sensor: step 28, image 1 of 2 HTC Vive Pro 2 Daughterboard Replacement, Disconnect the IPD sensor: step 28, image 2 of 2
      • Use the point of a spudger to lift up the locking tab on the IPD sensor ZIF connector.
      Ask FixBot
    4. HTC Vive Pro 2 Daughterboard Replacement: step 29, image 1 of 2 HTC Vive Pro 2 Daughterboard Replacement: step 29, image 2 of 2
      • Use tweezers, or your fingers, to pull the IPD sensor cable straight out of its socket.
      Ask FixBot
    5. HTC Vive Pro 2 Daughterboard Replacement, Disconnect the proximity sensor: step 30, image 1 of 2 HTC Vive Pro 2 Daughterboard Replacement, Disconnect the proximity sensor: step 30, image 2 of 2
      • Use the point of a spudger to lift up the locking tab on the proximity sensor ZIF connector.
      Ask FixBot
    6. HTC Vive Pro 2 Daughterboard Replacement: step 31, image 1 of 2 HTC Vive Pro 2 Daughterboard Replacement: step 31, image 2 of 2
      • Use tweezers, or your fingers, to pull the proximity sensor cable straight out of its socket.
      Ask FixBot
    1. HTC Vive Pro 2 Daughterboard Replacement, Remove the sensor array cable: step 32, image 1 of 2 HTC Vive Pro 2 Daughterboard Replacement, Remove the sensor array cable: step 32, image 2 of 2
      • Use tweezers, or your fingers, to peel the conductive fabric off the sensor array ZIF connector on the daughterboard.
      Ask FixBot
    2. HTC Vive Pro 2 Daughterboard Replacement: step 33, image 1 of 2 HTC Vive Pro 2 Daughterboard Replacement: step 33, image 2 of 2
      • Use your spudger to flip up the locking tab on the sensor array ZIF connector.
      Ask FixBot
    3. HTC Vive Pro 2 Daughterboard Replacement: step 34, image 1 of 2 HTC Vive Pro 2 Daughterboard Replacement: step 34, image 2 of 2
      • Use your fingers to grip both sides of the cable and pull it straight out of its socket.
      • Remove the cable.
      Ask FixBot
    4. HTC Vive Pro 2 Daughterboard Replacement, Remove the daughterboard screws: step 35, image 1 of 2 HTC Vive Pro 2 Daughterboard Replacement, Remove the daughterboard screws: step 35, image 2 of 2
      • Use a T5 Torx screwdriver to remove the four 3.0 mm‑long screws securing the daughterboard.
      Ask FixBot
    5. HTC Vive Pro 2 Daughterboard Replacement, Remove the daughterboard: step 36, image 1 of 2 HTC Vive Pro 2 Daughterboard Replacement, Remove the daughterboard: step 36, image 2 of 2
      • Lift the daughterboard straight off the lens assembly and remove it.
      Ask FixBot
Alex Diaz-Kokaisl
248,583 Reputation
1,203 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,826 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 28
All Time: 547
