HTC Vive Focus Facerest Replacement
    1. HTC Vive Focus Facerest Replacement, Remove the facerest cushion: step 1, image 1 of 3 HTC Vive Focus Facerest Replacement, Remove the facerest cushion: step 1, image 2 of 3 HTC Vive Focus Facerest Replacement, Remove the facerest cushion: step 1, image 3 of 3
      • Place your device upside-down on your work surface.
      • The facerest cushion is lightly held into place by seven plastic clips.
      • Use your fingers to gently pull the facerest cushion straight off of the facerest to remove it.
      Ask FixBot
    1. HTC Vive Focus Facerest Replacement, Remove the facerest: step 2, image 1 of 1
      • Use a T5 Torx screwdriver to remove the eight 4.5 mm screws securing the facerest.
      • One of the screws will be covered by a tamper-evident sticker. Press the driver through the sticker to remove the screw.
      Ask FixBot
    2. HTC Vive Focus Facerest Replacement: step 3, image 1 of 3 HTC Vive Focus Facerest Replacement: step 3, image 2 of 3 HTC Vive Focus Facerest Replacement: step 3, image 3 of 3
      • Insert an opening pick into the upper-left corner of the facerest.
      • Twist the opening pick to release the plastic clip securing the facerest.
      • Repeat for the upper-right corner.
      • Don't remove the facerest yet. It's still attached by the facerest sensor ribbon cable.
      Ask FixBot
    3. HTC Vive Focus Facerest Replacement, Remove the facerest sensor: step 4, image 1 of 3 HTC Vive Focus Facerest Replacement, Remove the facerest sensor: step 4, image 2 of 3 HTC Vive Focus Facerest Replacement, Remove the facerest sensor: step 4, image 3 of 3
      • Carefully flip your device over.
      • Pull the facerest out just enough to access the screws securing the facerest sensor.
      • Don't put any strain on the facerest sensor ribbon cable.
      • During reassembly, make sure the facerest sensor ribbon cable is positioned between the lenses before reinstalling the facerest.
      Ask FixBot
    4. HTC Vive Focus Facerest Replacement: step 5, image 1 of 1
      • Use a T5 Torx screwdriver to remove the two 2.4 mm screws securing the facerest sensor to the facerest.
      Ask FixBot
    5. HTC Vive Focus Facerest Replacement: step 6, image 1 of 1
      • Remove the facerest.
      Ask FixBot
Sam Omiotek
100,054 Reputation
289 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 7
Past 30 Days: 16
All Time: 426
