HTC Vive Focus Battery Replacement
    1. HTC Vive Focus Battery Replacement, Remove the facerest cushion: step 1, image 1 of 3 HTC Vive Focus Battery Replacement, Remove the facerest cushion: step 1, image 2 of 3 HTC Vive Focus Battery Replacement, Remove the facerest cushion: step 1, image 3 of 3
      • Place your device upside-down on your work surface.
      • The facerest cushion is lightly held into place by seven plastic clips.
      • Use your fingers to gently pull the facerest cushion straight off of the facerest to remove it.
      Ask FixBot
    1. HTC Vive Focus Battery Replacement, Remove the facerest: step 2, image 1 of 1
      • Use a T5 Torx screwdriver to remove the eight 4.5 mm screws securing the facerest.
      • One of the screws will be covered by a tamper-evident sticker. Press the driver through the sticker to remove the screw.
      Ask FixBot
    2. HTC Vive Focus Battery Replacement: step 3, image 1 of 3 HTC Vive Focus Battery Replacement: step 3, image 2 of 3 HTC Vive Focus Battery Replacement: step 3, image 3 of 3
      • Insert an opening pick into the upper-left corner of the facerest.
      • Twist the opening pick to release the plastic clip securing the facerest.
      • Repeat for the upper-right corner.
      • Don't remove the facerest yet. It's still attached by the facerest sensor ribbon cable.
      Ask FixBot
    3. HTC Vive Focus Battery Replacement, Remove the facerest sensor: step 4, image 1 of 3 HTC Vive Focus Battery Replacement, Remove the facerest sensor: step 4, image 2 of 3 HTC Vive Focus Battery Replacement, Remove the facerest sensor: step 4, image 3 of 3
      • Carefully flip your device over.
      • Pull the facerest out just enough to access the screws securing the facerest sensor.
      • Don't put any strain on the facerest sensor ribbon cable.
      • During reassembly, make sure the facerest sensor ribbon cable is positioned between the lenses before reinstalling the facerest.
      Ask FixBot
    4. HTC Vive Focus Battery Replacement: step 5, image 1 of 1
      • Use a T5 Torx screwdriver to remove the two 2.4 mm screws securing the facerest sensor to the facerest.
      Ask FixBot
    5. HTC Vive Focus Battery Replacement: step 6, image 1 of 1
      • Remove the facerest.
      Ask FixBot
    1. HTC Vive Focus Battery Replacement, Unscrew the front cover: step 7, image 1 of 2 HTC Vive Focus Battery Replacement, Unscrew the front cover: step 7, image 2 of 2
      • Use your fingers to slide the lenses towards each other so that they are positioned towards the center of the device.
      Ask FixBot
    2. HTC Vive Focus Battery Replacement: step 8, image 1 of 2 HTC Vive Focus Battery Replacement: step 8, image 2 of 2
      • Use a T5 Torx screwdriver to remove the four screws securing the front cover from inside the device:
      • Two 5.7 mm screws with fine threads
      • Two 5.5 mm screws with coarse threads
      • The coarse-thread screws can strip easily. During reassembly, tighten the coarse-thread screws until they're hand tight and then no more.
      Ask FixBot
    3. HTC Vive Focus Battery Replacement, Remove the front cover: step 9, image 1 of 2 HTC Vive Focus Battery Replacement, Remove the front cover: step 9, image 2 of 2
      • Note the location of the plastic welds on both vertical edges of the front cover.
      • After reassembly, the gap between the front cover and the side panels may no longer be flush. This is a cosmetic defect only and will not affect operation. The front cover's clips and screws are sufficient to secure it to the rest of the device.
      Ask FixBot
    4. HTC Vive Focus Battery Replacement: step 10, image 1 of 3 HTC Vive Focus Battery Replacement: step 10, image 2 of 3 HTC Vive Focus Battery Replacement: step 10, image 3 of 3
      • Insert an opening pick into the top of the front cover near the upper left corner.
      • Slide the opening pick around the upper left corner of the front cover.
      Ask FixBot
    5. HTC Vive Focus Battery Replacement: step 11, image 1 of 2 HTC Vive Focus Battery Replacement: step 11, image 2 of 2
      • Use the opening pick to separate the weld securing the left side vertical edge of the front cover.
      • The weld may require significant force to separate.
      Ask FixBot
    6. HTC Vive Focus Battery Replacement: step 12, image 1 of 3 HTC Vive Focus Battery Replacement: step 12, image 2 of 3 HTC Vive Focus Battery Replacement: step 12, image 3 of 3
      • Insert an opening pick into the top of the front cover near the upper right corner.
      • Slide the opening pick around the upper right corner of the front cover.
      Ask FixBot
    7. HTC Vive Focus Battery Replacement: step 13, image 1 of 2 HTC Vive Focus Battery Replacement: step 13, image 2 of 2
      • Use the opening pick to separate the weld securing the right side vertical edge of the front cover.
      Ask FixBot
    8. HTC Vive Focus Battery Replacement: step 14, image 1 of 3 HTC Vive Focus Battery Replacement: step 14, image 2 of 3 HTC Vive Focus Battery Replacement: step 14, image 3 of 3
      • Flip the device upside-down.
      • Use an opening pick to disconnect the plastic clips securing the bottom right edge of the front cover to the device.
      Ask FixBot
    9. HTC Vive Focus Battery Replacement: step 15, image 1 of 2 HTC Vive Focus Battery Replacement: step 15, image 2 of 2
      • Slide the opening pick along the bottom edge of the front cover to separate it from the device.
      Ask FixBot
    10. HTC Vive Focus Battery Replacement: step 16, image 1 of 2 HTC Vive Focus Battery Replacement: step 16, image 2 of 2
      • Use the opening pick to disconnect the plastic clips securing the bottom-left edge of the front cover to the device.
      Ask FixBot
    11. HTC Vive Focus Battery Replacement: step 17, image 1 of 2 HTC Vive Focus Battery Replacement: step 17, image 2 of 2
      • Flip the device right-side up.
      • Use the opening pick to separate the last few plastic clips securing the top of the front cover.
      Ask FixBot
    12. HTC Vive Focus Battery Replacement: step 18, image 1 of 2 HTC Vive Focus Battery Replacement: step 18, image 2 of 2
      • Remove the front cover.
      Ask FixBot
    1. HTC Vive Focus Battery Replacement, Remove the CPU fan: step 19, image 1 of 3 HTC Vive Focus Battery Replacement, Remove the CPU fan: step 19, image 2 of 3 HTC Vive Focus Battery Replacement, Remove the CPU fan: step 19, image 3 of 3
      Tool used on this step:
      $3.99
      Buy
      • Use a pair of angled tweezers to disconnect the CPU fan cable from the motherboard.
      • Lift the CPU fan connector straight up from the motherboard to disconnect it from its socket.
      • During reassembly, align the CPU fan connector with its socket and use your finger to press it straight down into the motherboard.
      Ask FixBot
    2. HTC Vive Focus Battery Replacement: step 20, image 1 of 2 HTC Vive Focus Battery Replacement: step 20, image 2 of 2
      • Use a T5 Torx screwdriver to remove the three 5.5 mm screws securing the CPU fan.
      • Use a Phillips screwdriver to remove the two 2.3 mm screws securing the CPU heatsink.
      Ask FixBot
    3. HTC Vive Focus Battery Replacement: step 21, image 1 of 2 HTC Vive Focus Battery Replacement: step 21, image 2 of 2
      • Remove the CPU fan.
      • During reassembly, do not sandwich the red antenna cable between the heatsink and contact plates.
      Ask FixBot
    1. HTC Vive Focus Battery Replacement, Disconnect the power button: step 22, image 1 of 2 HTC Vive Focus Battery Replacement, Disconnect the power button: step 22, image 2 of 2
      • Use a T5 Torx screwdriver to remove the black 5.5 mm screw from the power button cable bracket.
      • Use a Phillips screwdriver to remove the 2.3 mm screw from the power button cable bracket.
      Ask FixBot
    2. HTC Vive Focus Battery Replacement: step 23, image 1 of 2 HTC Vive Focus Battery Replacement: step 23, image 2 of 2
      Buy
      • Use a pair of tweezers or your fingers to remove the power button cable bracket from the motherboard.
      • During reassembly, slot the power button cable bracket back onto the peg on the motherboard before reinstalling the screws.
      Ask FixBot
    3. HTC Vive Focus Battery Replacement: step 24, image 1 of 2 HTC Vive Focus Battery Replacement: step 24, image 2 of 2
      • Use the pointed end of a spudger to disconnect the power button cable from the motherboard.
      Ask FixBot
    4. HTC Vive Focus Battery Replacement, Remove the proximity sensor array: step 25, image 1 of 2 HTC Vive Focus Battery Replacement, Remove the proximity sensor array: step 25, image 2 of 2
      • Pry up with the flat end of a spudger to disconnect the three ribbon cables connecting the proximity sensor array to the motherboard.
      Ask FixBot
    5. HTC Vive Focus Battery Replacement: step 26, image 1 of 2 HTC Vive Focus Battery Replacement: step 26, image 2 of 2
      • Use a T5 Torx screwdriver to remove the 4.5 mm screw from the proximity sensor array.
      Ask FixBot
    6. HTC Vive Focus Battery Replacement: step 27, image 1 of 1
      • Remove the proximity sensor array from the motherboard.
      Ask FixBot
    7. HTC Vive Focus Battery Replacement, Remove the internal assembly: step 28, image 1 of 3 HTC Vive Focus Battery Replacement, Remove the internal assembly: step 28, image 2 of 3 HTC Vive Focus Battery Replacement, Remove the internal assembly: step 28, image 3 of 3
      • Antenna connectors are fragile and can break off of the motherboard. Use this technique when disconnecting antenna cables.
      • Use a spudger or a pair of tweezers to disconnect the red antenna cable from the front of the device.
      • De-route the antenna cable from the front of the device and place it to the side.
      • During reassembly, be sure to re-route the cable through the brackets and clips securing it.
      Ask FixBot
    8. HTC Vive Focus Battery Replacement: step 29, image 1 of 3 HTC Vive Focus Battery Replacement: step 29, image 2 of 3 HTC Vive Focus Battery Replacement: step 29, image 3 of 3
      • Use a spudger or a pair of tweezers to remove the black antenna cable from the motherboard.
      • During reassembly, re-route the black antenna cable through its channel and clip.
      Ask FixBot
    9. HTC Vive Focus Battery Replacement: step 30, image 1 of 2 HTC Vive Focus Battery Replacement: step 30, image 2 of 2
      • Use a spudger to disconnect the ribbon cable connecting the volume buttons and headset jack to the motherboard.
      Ask FixBot
    10. HTC Vive Focus Battery Replacement: step 31, image 1 of 2 HTC Vive Focus Battery Replacement: step 31, image 2 of 2
      • Use a pair of tweezers to carefully disconnect the speaker wire from the right side of the motherboard.
      • During reassembly, reinstall the speaker wire with the gold contacts facing towards you and the red wire on top.
      Ask FixBot
    11. HTC Vive Focus Battery Replacement: step 32, image 1 of 2 HTC Vive Focus Battery Replacement: step 32, image 2 of 2
      • Use a pair of tweezers to carefully disconnect the speaker wire from the left side of the motherboard.
      • During reassembly, reinstall the speaker wire with the gold contacts facing towards you and the black wire on top.
      Ask FixBot
    12. HTC Vive Focus Battery Replacement: step 33, image 1 of 2 HTC Vive Focus Battery Replacement: step 33, image 2 of 2
      • Use a T5 Torx screwdriver to remove the four 5.6 mm screws securing the corners of the internal assembly to the frame.
      • Use a Phillips screwdriver to remove the two 7.2 mm silver screws from the bottom of the motherboard.
      Ask FixBot
    13. HTC Vive Focus Battery Replacement: step 34, image 1 of 2 HTC Vive Focus Battery Replacement: step 34, image 2 of 2
      • Use a T5 Torx screwdriver to remove the two 5.5 mm screws securing the internal assembly to inside of the frame.
      • During reassembly, make sure the internal assembly is fully seated on its centering pegs on each side and sits flush on the tabs on the frame before tightening these two screws.
      • Check for proper rack and pinion operation before continuing reassembly.
      Ask FixBot
    14. HTC Vive Focus Battery Replacement: step 35, image 1 of 2 HTC Vive Focus Battery Replacement: step 35, image 2 of 2
      • Use a T5 Torx screwdriver to remove the two 4.5 mm screws securing the bracket under the left lens.
      Ask FixBot
    15. HTC Vive Focus Battery Replacement: step 36, image 1 of 2 HTC Vive Focus Battery Replacement: step 36, image 2 of 2
      • Remove the bracket under the left lens.
      • To ensure correct operation, make sure this piece is properly seated on the adjuster mechanism by sliding the lenses as close together as possible before reinstalling it.
      Ask FixBot
    16. HTC Vive Focus Battery Replacement: step 37, image 1 of 3 HTC Vive Focus Battery Replacement: step 37, image 2 of 3 HTC Vive Focus Battery Replacement: step 37, image 3 of 3
      • Before removing the internal assembly, tilt the front out slightly to feed the microSD card slot cover through the frame.
      Ask FixBot
    17. HTC Vive Focus Battery Replacement: step 38, image 1 of 3 HTC Vive Focus Battery Replacement: step 38, image 2 of 3 HTC Vive Focus Battery Replacement: step 38, image 3 of 3
      • Carefully remove the internal assembly through the front of the device.
      • The internal assembly may not come out easily. Gently bend the outer frame as necessary to create space for the edges to clear.
      • Do not force any part of the internal assembly out.
      • During reassembly, feed the microSD slot cover referenced in the previous step back through the frame as you slide the internal assembly back into place.
      Ask FixBot
    18. HTC Vive Focus Battery Replacement, Reassembly tips: step 39, image 1 of 2 HTC Vive Focus Battery Replacement, Reassembly tips: step 39, image 2 of 2
      • During reassembly:
      • Make sure not to trap any of the five loose wires and cables when reinstalling the internal assembly.
      • Hold the lenses as close together as possible and align the rack and pinion with the gear and washer.
      • This will ensure the lenses are properly aligned.
      Ask FixBot
    1. HTC Vive Focus Battery Replacement, Disconnect the LED displays: step 40, image 1 of 2 HTC Vive Focus Battery Replacement, Disconnect the LED displays: step 40, image 2 of 2
      • Use the flat end of a spudger to disconnect the left LED display ribbon cable from the motherboard.
      Ask FixBot
    2. HTC Vive Focus Battery Replacement: step 41, image 1 of 2 HTC Vive Focus Battery Replacement: step 41, image 2 of 2
      • Use the flat end of a spudger to disconnect the right LED display ribbon cable from the motherboard.
      Ask FixBot
    3. HTC Vive Focus Battery Replacement, Open the midframe: step 42, image 1 of 3 HTC Vive Focus Battery Replacement, Open the midframe: step 42, image 2 of 3 HTC Vive Focus Battery Replacement, Open the midframe: step 42, image 3 of 3
      • Swing the midframe open to access the battery.
      • During reassembly, be careful not to crush the LED display ribbon cables when folding the midframe back into place.
      Ask FixBot
    1. HTC Vive Focus Battery Replacement, Disconnect the battery: step 43, image 1 of 2 HTC Vive Focus Battery Replacement, Disconnect the battery: step 43, image 2 of 2
      • Use a Phillips screwdriver to remove the two 2.3 mm screws securing the battery cable to the back of the motherboard.
      Ask FixBot
    2. HTC Vive Focus Battery Replacement: step 44, image 1 of 2 HTC Vive Focus Battery Replacement: step 44, image 2 of 2
      • Use the tip of a spudger to disconnect the battery from the back of the motherboard.
      • During reassembly, use a spudger to align the battery connector screw holes and press it into place.
      Ask FixBot
    1. HTC Vive Focus Battery Replacement, Remove the battery: step 45, image 1 of 2 HTC Vive Focus Battery Replacement, Remove the battery: step 45, image 2 of 2
      • Apply high concentration isopropyl alcohol (90% or greater) along the left side of the battery and allow it to soak into the battery well.
      Ask FixBot
    2. HTC Vive Focus Battery Replacement: step 46, image 1 of 3 HTC Vive Focus Battery Replacement: step 46, image 2 of 3 HTC Vive Focus Battery Replacement: step 46, image 3 of 3
      • Apply more isopropyl alcohol along the remaining three edges of the battery.
      • Make sure the alcohol is soaking underneath the battery into the battery well.
      • Wait one minute for the alcohol to soften the adhesive under the battery.
      Ask FixBot
    3. HTC Vive Focus Battery Replacement: step 47, image 1 of 2 HTC Vive Focus Battery Replacement: step 47, image 2 of 2
      • Use a suction handle to lift the battery straight out of the battery well.
      • If the battery is difficult to remove, repeat the previous step and try again.
      • During reassembly, remove the old adhesive and apply double sided adhesive tape or pre-cut adhesive to secure the new battery.
      Ask FixBot
Sam Omiotek
100,054 Reputation
289 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 51
All Time: 1,961
