HTC Vive Focus 3 Battery Connection Re-solder Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
12
Past 30 Days:
51
All Time:
51
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
The HTC Vive Focus 3 features a battery pack that is removeable for charging and/or swapping with a spare.
On both of the batteries of my daughters headset, after about a year of extensive use, both batteries experienced charging issues, where it would require the charging cable to be carefully positioning to enable the batteries to charge. After investigation it became apparent that the solder joint had broken (on both) and required re-soldering.
Tools
    1. HTC Vive Focus 3 Battery Connection Re-solder Replacement, Battery Connection Re-solder: step 1, image 1 of 1
      • Assemble required items from the Essential Electronics Kit
      • Phillits 00 bit
      • Guitar pick
      • Solder
      • The 1.5mm bevel worked best
      Ask FixBot
    2. HTC Vive Focus 3 Battery Connection Re-solder Replacement: step 2, image 1 of 1
      • Optional - Chem pen with isopropyl alcohol
      • Optional - No clean flux pen
      Ask FixBot
    3. HTC Vive Focus 3 Battery Connection Re-solder Replacement: step 3, image 1 of 2 HTC Vive Focus 3 Battery Connection Re-solder Replacement: step 3, image 2 of 2
      • Remove the sticker to expose the 2 x phillips screws and unscrew both
      Ask FixBot
    4. HTC Vive Focus 3 Battery Connection Re-solder Replacement: step 4, image 1 of 3 HTC Vive Focus 3 Battery Connection Re-solder Replacement: step 4, image 2 of 3 HTC Vive Focus 3 Battery Connection Re-solder Replacement: step 4, image 3 of 3
      • Use the picks to open the larger edge first
      • Then start on the corner, this can be quite tricky
      • Get the end fully unlatched
      Ask FixBot
    5. HTC Vive Focus 3 Battery Connection Re-solder Replacement: step 5, image 1 of 2 HTC Vive Focus 3 Battery Connection Re-solder Replacement: step 5, image 2 of 2
      • Continue working around the entire case until it is seperated
      Ask FixBot
    6. HTC Vive Focus 3 Battery Connection Re-solder Replacement: step 6, image 1 of 2 HTC Vive Focus 3 Battery Connection Re-solder Replacement: step 6, image 2 of 2
      • Remove the 4 x phillips head screws show above
      • The battery and board can then be removed from the plastic case
      Ask FixBot
    7. HTC Vive Focus 3 Battery Connection Re-solder Replacement: step 7, image 1 of 3 HTC Vive Focus 3 Battery Connection Re-solder Replacement: step 7, image 2 of 3 HTC Vive Focus 3 Battery Connection Re-solder Replacement: step 7, image 3 of 3
      • You can then confirm the solder joint issue
      • Just sitting being plugged in, no lights illuminate
      • With gentle squeezing pressure on the charging port the charge indication lights illuminate
      • Additionally inspect the solder joint an identify if there is a break in the joint
      Ask FixBot
    8. HTC Vive Focus 3 Battery Connection Re-solder Replacement: step 8, image 1 of 3 HTC Vive Focus 3 Battery Connection Re-solder Replacement: step 8, image 2 of 3 HTC Vive Focus 3 Battery Connection Re-solder Replacement: step 8, image 3 of 3
      • Remove the three screws to allow the PCB to move to give additional space to resolder the joint
      • 2 x picks help seperate and hold the space open for soldering
      Ask FixBot
    9. HTC Vive Focus 3 Battery Connection Re-solder Replacement: step 9, image 1 of 2 HTC Vive Focus 3 Battery Connection Re-solder Replacement: step 9, image 2 of 2
      • Using the flux, heat the joint back up.
      • I found that the highest setting on the soldering iron didn't reflow the existing solder so I added some additional solder
      • Using the chem pen clean with isopropyl alcohol
      • Test to see if it charges without external intervention
      Ask FixBot
    10. HTC Vive Focus 3 Battery Connection Re-solder Replacement: step 10, image 1 of 3 HTC Vive Focus 3 Battery Connection Re-solder Replacement: step 10, image 2 of 3 HTC Vive Focus 3 Battery Connection Re-solder Replacement: step 10, image 3 of 3
      • Re-assemble noting there is a small and large notch at the top and bottom to aid alignment-continued next step
      Ask FixBot
    11. HTC Vive Focus 3 Battery Connection Re-solder Replacement: step 11, image 1 of 3 HTC Vive Focus 3 Battery Connection Re-solder Replacement: step 11, image 2 of 3 HTC Vive Focus 3 Battery Connection Re-solder Replacement: step 11, image 3 of 3
      • Also noting to position of the battery connector into the HTC Vive headset
      Ask FixBot
Gordon Hartley
1 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 51
All Time: 51
