Up to 20% off select tools
HTC Vive Facerest Replacement
Views: 3.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
25
Past 30 Days:
106
All Time:
3,523
Comments: 2
2 comments on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to remove and replace the facerest on an HTC Vive.
    1. HTC Vive Facerest Replacement, Unscrew the head strap mounts: step 1, image 1 of 2 HTC Vive Facerest Replacement, Unscrew the head strap mounts: step 1, image 2 of 2
      • Be sure to power down and disconnect your Vive before beginning.
      • Use a T5 Torx driver to remove the two 12 mm-long screws securing the head strap mounts on either side of the headset.
      • For some devices, a T6 Torx driver may work better.
      • The mounts may fall off when the screws are removed, so be careful not to lose any parts.
      Ask FixBot
    2. HTC Vive Facerest Replacement, Remove the head strap mounts: step 2, image 1 of 3 HTC Vive Facerest Replacement, Remove the head strap mounts: step 2, image 2 of 3 HTC Vive Facerest Replacement, Remove the head strap mounts: step 2, image 3 of 3
      • Remove both head strap mounts.
      Ask FixBot
    3. HTC Vive Facerest Replacement, Remove the facerest: step 3, image 1 of 2 HTC Vive Facerest Replacement, Remove the facerest: step 3, image 2 of 2
      • Slide the facerest straight away from the headset to remove it.
      Ask FixBot
4 other people completed this guide.
Author
with
Adam O'Camb
226,699 Reputation
415 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 106
All Time: 3,523
