HTC Vive Cosmos Lens and LCD Frame Replacement
  1. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the facerest: step 1, image 1 of 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the facerest: step 1, image 2 of 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the facerest: step 1, image 3 of 3
    • Pull the bottom of the facerest straight away from the Vive Cosmos to unclip it from the Vive.
    • With the bottom unclipped, pull the top of the facerest away from the Vive to remove it.
    Ask FixBot
  2. HTC Vive Cosmos Lens and LCD Frame Replacement, Release the faceplate switch: step 2, image 1 of 2 HTC Vive Cosmos Lens and LCD Frame Replacement, Release the faceplate switch: step 2, image 2 of 2
    • Use your finger to push the sliding faceplate release switch, sitting to the left of the lenses, toward the bottom of the Vive.
    Ask FixBot
  3. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the faceplate: step 3, image 1 of 2 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the faceplate: step 3, image 2 of 2
    • While holding the switch in the bottom position, pull the faceplate straight up and away from the front of the Vive.
    • Remove the faceplate.
    Ask FixBot
  4. HTC Vive Cosmos Lens and LCD Frame Replacement, Unscrew the focus knob: step 4, image 1 of 1
    • Use a T5 Torx driver to remove the 4.1 mm long screw securing the focus knob.
    Ask FixBot
  5. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the focus knob: step 5, image 1 of 2 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the focus knob: step 5, image 2 of 2
    • Slide the focus knob out of the plastic housing, off of the focus rod, and remove it.
    Ask FixBot
  6. HTC Vive Cosmos Lens and LCD Frame Replacement, Unplug the audio connector: step 6, image 1 of 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Unplug the audio connector: step 6, image 2 of 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Unplug the audio connector: step 6, image 3 of 3
    • Twist the 3.5 mm audio connector counter-clockwise slightly and slide its cable out from under the plastic retaining clip.
    • Lift the audio connector straight up to unplug it.
    Ask FixBot
  7. HTC Vive Cosmos Lens and LCD Frame Replacement, Unscrew the LCD and motherboard assembly: step 7, image 1 of 1
    • Use a T5 Torx driver to remove the three 4.1 mm long screws securing the LCD and motherboard assembly.
    Ask FixBot
  8. HTC Vive Cosmos Lens and LCD Frame Replacement: step 8, image 1 of 2 HTC Vive Cosmos Lens and LCD Frame Replacement: step 8, image 2 of 2
    • Gently peel up the stickers on either side of the front of the Vive. If possible, keep the stickers intact and reuse them.
    Ask FixBot
  9. HTC Vive Cosmos Lens and LCD Frame Replacement: step 9, image 1 of 1
    • Use a T5 Torx driver to unscrew the screws securing the upper component cover and the LCD and motherboard assembly:
    • Sixteen 4.1 mm long screws
    • One captive screw
    • This screw is covered by a sticker. Poke your driver through the sticker to access the screw.
    • Two 4.1 mm long screws
    • These screws are covered by stickers. Poke your driver through the stickers to access the screws.
    Ask FixBot
  10. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the microphone: step 10, image 1 of 1
    • Remove the microphone cover from the bottom edge of the headset.
    Ask FixBot
  11. HTC Vive Cosmos Lens and LCD Frame Replacement, Separate the microphone adhesive: step 11, image 1 of 2 HTC Vive Cosmos Lens and LCD Frame Replacement, Separate the microphone adhesive: step 11, image 2 of 2
    • Slide an opening pick under the microphone to separate the adhesive securing it to the Vive.
    • If this is difficult, use a heated iOpener, hair dryer, or heat gun to apply heat to adhesive.
    Ask FixBot
  12. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the upper component cover: step 12, image 1 of 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the upper component cover: step 12, image 2 of 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the upper component cover: step 12, image 3 of 3
    • Angle the bottom end of the upper component cover away from the front of the Vive.
    • Pull the upper component cover away from the front of the Vive and remove it.
    Ask FixBot
  13. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the camera connector covers: step 13, image 1 of 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the camera connector covers: step 13, image 2 of 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the camera connector covers: step 13, image 3 of 3
    • Slide the camera connector covers on either side of the LCD and motherboard assembly away from the center off of the assembly and remove them.
    Ask FixBot
  14. HTC Vive Cosmos Lens and LCD Frame Replacement, Disconnect the cameras: step 14, image 1 of 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Disconnect the cameras: step 14, image 2 of 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Disconnect the cameras: step 14, image 3 of 3
    • Peel the tape over the right camera connector back enough to access the camera's ZIF connector underneath.
    • Repeat the same process to peel back the tape over the left camera ZIF connector.
    Ask FixBot
  15. HTC Vive Cosmos Lens and LCD Frame Replacement: step 15, image 1 of 3 HTC Vive Cosmos Lens and LCD Frame Replacement: step 15, image 2 of 3 HTC Vive Cosmos Lens and LCD Frame Replacement: step 15, image 3 of 3
    • Use the point of a spudger to flip up the small locking flap securing the right camera cable ZIF connector.
    • Carefully slide the camera connector cable straight out of its socket on the motherboard.
    Ask FixBot
  16. HTC Vive Cosmos Lens and LCD Frame Replacement: step 16, image 1 of 2 HTC Vive Cosmos Lens and LCD Frame Replacement: step 16, image 2 of 2
    • Use the point of a spudger to flip up the small locking flap securing the left camera cable ZIF connector.
    Ask FixBot
  17. HTC Vive Cosmos Lens and LCD Frame Replacement, Disconnect the microphone: step 17, image 1 of 1
    • Peel the yellow tape off of the microphone connector.
    Ask FixBot
  18. HTC Vive Cosmos Lens and LCD Frame Replacement: step 18, image 1 of 2 HTC Vive Cosmos Lens and LCD Frame Replacement: step 18, image 2 of 2
    • Use the point of a spudger to flip up the small locking flap securing the microphone cable ZIF connector.
    Ask FixBot
  19. HTC Vive Cosmos Lens and LCD Frame Replacement: step 19, image 1 of 3 HTC Vive Cosmos Lens and LCD Frame Replacement: step 19, image 2 of 3 HTC Vive Cosmos Lens and LCD Frame Replacement: step 19, image 3 of 3
    • Carefully slide the microphone connector cable straight out of its socket on the motherboard.
    • With the cable out of its socket, slide the cable toward the bottom of the Vive and out of its clip on the LCD and motherboard assembly.
    • Take care not to crease or tear the cable while you're moving it.
    Ask FixBot
  20. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the LCD and motherboard assembly: step 20, image 1 of 2 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the LCD and motherboard assembly: step 20, image 2 of 2
    • Lift the LCD and motherboard assembly out of the headset.
    • The assembly is secured by clips around the edges. It may help to release the clips using a thin plastic tool, like an opening tool or a spudger.
    Ask FixBot
  21. HTC Vive Cosmos Lens and LCD Frame Replacement, Disconnect the LCD panels: step 21, image 1 of 1
    • Use a T5 Torx driver to remove the four 2.9 mm long screws securing the LCD connectors.
    Ask FixBot
  22. HTC Vive Cosmos Lens and LCD Frame Replacement: step 22, image 1 of 3 HTC Vive Cosmos Lens and LCD Frame Replacement: step 22, image 2 of 3 HTC Vive Cosmos Lens and LCD Frame Replacement: step 22, image 3 of 3
    • Use the flat end of a spudger to pry the LCD connectors straight up and out of their sockets on the daughterboard.
    Ask FixBot
  23. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the LCD frame assembly: step 23, image 1 of 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the LCD frame assembly: step 23, image 2 of 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the LCD frame assembly: step 23, image 3 of 3
    • Gently pull the bottom edge of the midframe away from the bottom edges of the LCD frames to unclip the LCD frames from the midframe.
    Ask FixBot
  24. HTC Vive Cosmos Lens and LCD Frame Replacement: step 24, image 1 of 2 HTC Vive Cosmos Lens and LCD Frame Replacement: step 24, image 2 of 2
    • Remove the LCD frame assembly from the midframe.
    • During reassembly, first seat the support rod in its slots in the midframe. Then gently press the rest of the LCD frame assembly into the midframe so that the bottom edges of the LCD frames clip into the midframe.
    Ask FixBot
  25. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the lens gasket: step 25, image 1 of 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the lens gasket: step 25, image 2 of 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the lens gasket: step 25, image 3 of 3
    • Gently lift the lens gasket off of the lens and LCD frames to remove it.
    Ask FixBot
  26. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the support rod: step 26, image 1 of 2 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the support rod: step 26, image 2 of 2
    • Slide the support rod out of its brackets on the lens and LCD frames.
    Ask FixBot
  27. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the focus rod: step 27, image 1 of 1
    • Use a T5 Torx driver to remove the four 4.1 mm screws securing the focus rod brackets.
    Ask FixBot
  28. HTC Vive Cosmos Lens and LCD Frame Replacement: step 28, image 1 of 2 HTC Vive Cosmos Lens and LCD Frame Replacement: step 28, image 2 of 2
    • Remove the focus rod and its brackets.
    Ask FixBot
  29. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the outer LCD cover: step 29, image 1 of 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the outer LCD cover: step 29, image 2 of 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the outer LCD cover: step 29, image 3 of 3
    • Pick one lens and LCD frame to work with for the rest of the guide. After removing the first frame, repeat the next seven steps with the other frame to remove it as well.
    • Insert the flat end of a spudger in between the edge of the lens LCD frame and the outer LCD cover.
    • Twist the spudger to release the clips securing the LCD cover to the frame.
    • Repeat the insertion and twisting process for each clip on the LCD cover.
    Ask FixBot
  30. HTC Vive Cosmos Lens and LCD Frame Replacement, Disconnect the LCD panel: step 30, image 1 of 1
    • Gently peel the sticker covering the LCD cable and connector back far enough to access the LCD connector.
    Ask FixBot
  31. HTC Vive Cosmos Lens and LCD Frame Replacement: step 31, image 1 of 3 HTC Vive Cosmos Lens and LCD Frame Replacement: step 31, image 2 of 3 HTC Vive Cosmos Lens and LCD Frame Replacement: step 31, image 3 of 3
    • Use the flat end of a spudger to flip up the locking flap securing the LCD cable ZIF connector.
    • Carefully slide the LCD cable straight out of its socket.
    Ask FixBot
  32. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the inner LCD cover: step 32, image 1 of 2 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the inner LCD cover: step 32, image 2 of 2
    • Slowly lift the LCD cover away from the lens and LCD frame, taking care to thread the LCD cable through the cover.
    Ask FixBot
  33. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the LCD panel: step 33, image 1 of 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the LCD panel: step 33, image 2 of 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the LCD panel: step 33, image 3 of 3
    • This step may damage the LCD panel. Continue only if the panel is already damaged.
    • Use the flat end of a spudger to pry up the LCD panel.
    • Remove the LCD panel.
    Ask FixBot
  34. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the lens: step 34, image 1 of 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the lens: step 34, image 2 of 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the lens: step 34, image 3 of 3
    • Push against the back of the lens to remove it from the frame.
    • If this is difficult, try heating the lens to soften the adhesive holding it to the frame.
    Ask FixBot
  35. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the lens and LCD frame: step 35, image 1 of 1
    • Only the lens and LCD frame remains.
    • Repeat the last seven steps with the other lens and LCD frame to remove it as well.
    Ask FixBot
Adam O'Camb
223,844 Reputation
416 Guides authored
3 Guide Comments
Good guide, it's not too hard it's just really tedious and annoying, I think I managed to finish the repair within an hour. The main annoying part is the mic and reconnecting the ribbon cable.
Josh (BeigeAnimal) - Reply Share
Would this process work on the Cosmos Elite as well?
Wickednoreaster - Reply Share
Yes it would. As the the elite is the same HMD but with a different faceplate.
Synapse - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 34
All Time: 1,972
