HTC Vive Cosmos Headstrap Hinge Replacement
  1. HTC Vive Cosmos Headstrap Hinge Replacement, Remove the facerest: step 1, image 1 of 3 HTC Vive Cosmos Headstrap Hinge Replacement, Remove the facerest: step 1, image 2 of 3 HTC Vive Cosmos Headstrap Hinge Replacement, Remove the facerest: step 1, image 3 of 3
    • Pull the bottom of the facerest straight away from the Vive Cosmos to unclip it from the Vive.
    • With the bottom unclipped, pull the top of the facerest away from the Vive to remove it.
    Ask FixBot
  2. HTC Vive Cosmos Headstrap Hinge Replacement, Unplug the audio connector: step 2, image 1 of 3 HTC Vive Cosmos Headstrap Hinge Replacement, Unplug the audio connector: step 2, image 2 of 3 HTC Vive Cosmos Headstrap Hinge Replacement, Unplug the audio connector: step 2, image 3 of 3
    • Twist the 3.5 mm audio connector counter-clockwise slightly and slide its cable out from under the plastic retaining clip.
    • Lift the audio connector straight up to unplug it.
    Ask FixBot
  3. HTC Vive Cosmos Headstrap Hinge Replacement, Remove the front headstrap pad: step 3, image 1 of 3 HTC Vive Cosmos Headstrap Hinge Replacement, Remove the front headstrap pad: step 3, image 2 of 3 HTC Vive Cosmos Headstrap Hinge Replacement, Remove the front headstrap pad: step 3, image 3 of 3
    • Grasp one end of the front headstrap pad and pull it away from the headstrap to remove it.
    • During reassembly, press the pads firmly against the headstrap, starting in the middle and moving toward the edges, until all the clips on the pads are completely seated in the headstrap. There should be no gaps between the pads and the headstrap.
    Ask FixBot
  4. HTC Vive Cosmos Headstrap Hinge Replacement, Remove the audio cables: step 4, image 1 of 3 HTC Vive Cosmos Headstrap Hinge Replacement, Remove the audio cables: step 4, image 2 of 3 HTC Vive Cosmos Headstrap Hinge Replacement, Remove the audio cables: step 4, image 3 of 3
    • Carefully lift the audio connector cable out of its slot in the front of the headstrap.
    Ask FixBot
  5. HTC Vive Cosmos Headstrap Hinge Replacement: step 5, image 1 of 2 HTC Vive Cosmos Headstrap Hinge Replacement: step 5, image 2 of 2
    • Carefully lift the audio interconnect cable out of its slot in the front of the headstrap.
    Ask FixBot
  6. HTC Vive Cosmos Headstrap Hinge Replacement, Remove the headstrap: step 6, image 1 of 1
    • Use a T5 Torx drive to remove the ten 4.1 mm long screws securing the headstrap.
    Ask FixBot
  7. HTC Vive Cosmos Headstrap Hinge Replacement: step 7, image 1 of 2 HTC Vive Cosmos Headstrap Hinge Replacement: step 7, image 2 of 2
    • Remove the headstrap.
    Ask FixBot
  8. HTC Vive Cosmos Headstrap Hinge Replacement, Release the faceplate switch: step 8, image 1 of 2 HTC Vive Cosmos Headstrap Hinge Replacement, Release the faceplate switch: step 8, image 2 of 2
    • Use your finger to push the sliding faceplate release switch, sitting to the left of the lenses, toward the bottom of the Vive.
    Ask FixBot
  9. HTC Vive Cosmos Headstrap Hinge Replacement, Remove the faceplate: step 9, image 1 of 2 HTC Vive Cosmos Headstrap Hinge Replacement, Remove the faceplate: step 9, image 2 of 2
    • While holding the switch in the bottom position, pull the faceplate straight up and away from the front of the Vive.
    • Remove the faceplate.
    Ask FixBot
  10. HTC Vive Cosmos Headstrap Hinge Replacement, Remove the headstrap hinge: step 10, image 1 of 1
    • Use a T5 Torx driver to remove the three 4.1 mm long screws securing the headstrap hinge.
    Ask FixBot
  11. HTC Vive Cosmos Headstrap Hinge Replacement: step 11, image 1 of 1
    • Use a T5 Torx driver to unscrew the captive screw securing the headstrap hinge.
    • There is a sticker covering this screw. Poke through it with your driver to access the screw.
    Ask FixBot
  12. HTC Vive Cosmos Headstrap Hinge Replacement: step 12, image 1 of 2 HTC Vive Cosmos Headstrap Hinge Replacement: step 12, image 2 of 2
    • Slide the headstrap hinge out of its slot in the Vive and remove it.
    Ask FixBot
Adam O'Camb
223,706 Reputation
416 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 43
All Time: 1,390
