Up to 20% off select tools
HTC Vive Controller Motherboard Replacement
Views: 14K
View statistics:
Past 24 Hours:
5
Past 7 Days:
26
Past 30 Days:
135
All Time:
13,718
Comments: 56
43 comments on steps, 13 guide comments.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 40 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
The HTC Vive controller motherboard may be damaged and not able to function. The motherboard is crucial for all functions of the remote. This guide will show you how to replace the motherboard.
    1. HTC Vive Controller Motherboard Replacement, Saucer Panels: step 1, image 1 of 3 HTC Vive Controller Motherboard Replacement, Saucer Panels: step 1, image 2 of 3 HTC Vive Controller Motherboard Replacement, Saucer Panels: step 1, image 3 of 3
      • Turn over the Vive controller so that the bottom saucer is facing up.
      • Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer.
      Ask FixBot
    2. HTC Vive Controller Motherboard Replacement: step 2, image 1 of 2 HTC Vive Controller Motherboard Replacement: step 2, image 2 of 2
      • Use the nylon spudger to separate the top and bottom saucer covers all around the edges.
      • Remove only the top saucer cover by pulling up with your hand.
      Ask FixBot
    3. HTC Vive Controller Motherboard Replacement: step 3, image 1 of 2 HTC Vive Controller Motherboard Replacement: step 3, image 2 of 2
      • Use the Phillips 00 screwdriver to remove the three silver 12.8mm screws from the exposed upper sensor panel.
      Ask FixBot
    4. HTC Vive Controller Motherboard Replacement: step 4, image 1 of 3 HTC Vive Controller Motherboard Replacement: step 4, image 2 of 3 HTC Vive Controller Motherboard Replacement: step 4, image 3 of 3
      • Carefully pull away the bottom saucer cover with your hand.
      • To aid in removing the saucer cover, squeeze the base of the controller with your other hand, as shown in the second image of this step. Squeezing will make the clips easier to release and help prevent them from breaking.
      Ask FixBot
    1. HTC Vive Controller Motherboard Replacement, Front Panel: step 5, image 1 of 2 HTC Vive Controller Motherboard Replacement, Front Panel: step 5, image 2 of 2
      • Use the T5 Torx screwdriver to remove the two black 5.2mm screws on the back gray panel.
      Ask FixBot
    2. HTC Vive Controller Motherboard Replacement: step 6, image 1 of 1
      • Turn over the Vive controller so that the exposed bottom saucer panel is facing up.
      • Use the T5 Torx screwdriver to remove the three black 5.2mm screws.
      Ask FixBot
    3. HTC Vive Controller Motherboard Replacement: step 7, image 1 of 2 HTC Vive Controller Motherboard Replacement: step 7, image 2 of 2
      • Use the nylon spudger to separate the front panel gently by running the spudger around the edges of the handle.
      • Only separate the front panel around the edges. Do not try to completely remove the panel yet.
      • Gently lift the right side of the panel to the left.
      Ask FixBot
    4. HTC Vive Controller Motherboard Replacement: step 8, image 1 of 1
      • Disconnect the upper ribbon cable gently by pulling the ribbon up and away from the motherboard with two fingers.
      • Do not try to disconnect the ribbon cables from the front panel.
      Ask FixBot
    5. HTC Vive Controller Motherboard Replacement: step 9, image 1 of 2 HTC Vive Controller Motherboard Replacement: step 9, image 2 of 2
      • Disconnect the middle ribbon cable gently by pulling the ribbon cable up and away from the motherboard with two fingers.
      Ask FixBot
    6. HTC Vive Controller Motherboard Replacement: step 10, image 1 of 3 HTC Vive Controller Motherboard Replacement: step 10, image 2 of 3 HTC Vive Controller Motherboard Replacement: step 10, image 3 of 3
      • Use the nylon spudger to lift the white tab by 90 degrees.
      • Disconnect the bottom ribbon cable gently by pulling the ribbon cable down with two fingers.
      Ask FixBot
    1. HTC Vive Controller Motherboard Replacement, Battery: step 11, image 1 of 2 HTC Vive Controller Motherboard Replacement, Battery: step 11, image 2 of 2
      • Use the Phillips 00 screwdriver to remove two black 2.8mm screws from the silver plate.
      • Use the Phillips 00 screwdriver to remove the black 5.8mm screw from the bottom right corner of the silver plate.
      Ask FixBot
    2. HTC Vive Controller Motherboard Replacement: step 12, image 1 of 1
      • Remove the silver plate by pinching it with two fingers and lifting up.
      Ask FixBot
    3. HTC Vive Controller Motherboard Replacement: step 13, image 1 of 1
      • Use the Phillips 00 screwdriver to remove the black 5.8mm screw from the top left of the battery frame.
      Ask FixBot
    4. HTC Vive Controller Motherboard Replacement: step 14, image 1 of 2 HTC Vive Controller Motherboard Replacement: step 14, image 2 of 2
      • Use the T5 Torx screwdriver to remove the two silver 4.2mm screws from the bottom of the battery frame.
      Ask FixBot
    5. HTC Vive Controller Motherboard Replacement: step 15, image 1 of 2 HTC Vive Controller Motherboard Replacement: step 15, image 2 of 2
      • Disconnect the three-pin cable gently by pinching the cable with two fingers and pulling up.
      Ask FixBot
    6. HTC Vive Controller Motherboard Replacement: step 16, image 1 of 3 HTC Vive Controller Motherboard Replacement: step 16, image 2 of 3 HTC Vive Controller Motherboard Replacement: step 16, image 3 of 3
      • Lift the battery frame to remove the battery from the Vive controller
      Ask FixBot
    1. HTC Vive Controller Motherboard Replacement, Motherboard: step 17, image 1 of 1
      • Use the Phillips 00 screwdriver to remove the two black 5.8mm screws from the top of the motherboard.
      Ask FixBot
    2. HTC Vive Controller Motherboard Replacement: step 18, image 1 of 2 HTC Vive Controller Motherboard Replacement: step 18, image 2 of 2
      • Use the T5 Torx screwdriver to remove the two silver 4.2mm screws from the bottom of the motherboard.
      Ask FixBot
    3. HTC Vive Controller Motherboard Replacement: step 19, image 1 of 3 HTC Vive Controller Motherboard Replacement: step 19, image 2 of 3 HTC Vive Controller Motherboard Replacement: step 19, image 3 of 3
      • Use the nylon spudger to rotate the black tab up by 90 degrees.
      • Disconnect the ribbon cable carefully with your finger.
      Ask FixBot
    4. HTC Vive Controller Motherboard Replacement: step 20, image 1 of 3 HTC Vive Controller Motherboard Replacement: step 20, image 2 of 3 HTC Vive Controller Motherboard Replacement: step 20, image 3 of 3
      • Lift the motherboard up and out of the Vive controller using your hands.
      Ask FixBot
9 other people completed this guide.
Author
with
Christopher Amaro
972 Reputation
5 Guides authored
Cal Poly, Team S15-G5, Livingston Fall 2017 Member of Cal Poly, Team S15-G5, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G5
4 Members
96 Guides authored
13 Guide Comments
Hi, do you know where I can get a new motherboard? I bought my controller second hand and after several months it stoppedworking…. when I took it apart the connection at the bottom has been removed and two wires soldered in place but it’s so small I can’t do it again so I need a new motherboard
thanks
nick.bentley.france - Reply Share
I am looking for the connetor at step 10. The top of the connector is broken (fail quality assurence). I am not interrested to purchase a new controler at 200$ because of a 2 cents connector.
Thank you
Yahveh Me - Reply Share
I had the same connector problem in step 10, where can I just buy the mother board
Adam Vosburgh - Reply Share
did either of you find the connector for the power button to mother board in step 10
stang98kjg - Reply Share
what plug is the for the bottom of the mother board for the main button looking to replace in step 10
angeloro - Reply Share
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 135
All Time: 13,718
