Tools
Introduction
Go to step 1 ↓If your HTC Touch is producing distorted sound or no audio at all during calls or media playback, a faulty speaker may be to blame.
This guide walks you through the process of replacing the internal speaker with clear, step-by-step instructions. You’ll learn how to safely disassemble your device, remove the malfunctioning speaker, and install a new one—restoring full audio functionality to your HTC Touch.
Warning: Always ground yourself before handling any circuit or logic boards to avoid damaging sensitive components with static electricity.
Before you begin this repair, make sure to turn off and disconnect your camera from the charger.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
