Up to 20% off select tools
HTC Touch Pro CDMA Screen Replacement
Views: 4.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
95
All Time:
4,265
Comments: 2
2 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
This easy to follow guide will show you in the ins and outs on how to repair your HTC Touch Pro.
    1. HTC Touch Pro CDMA Screen Replacement, Battery: step 1, image 1 of 2 HTC Touch Pro CDMA Screen Replacement, Battery: step 1, image 2 of 2
      • First, gently press on the back plate and push down toward the camera.
      Ask FixBot
    2. HTC Touch Pro CDMA Screen Replacement: step 2, image 1 of 2 HTC Touch Pro CDMA Screen Replacement: step 2, image 2 of 2
      • Use your finger to lift up the edge of the battery.
      Ask FixBot
    1. HTC Touch Pro CDMA Screen Replacement, USB Logic Board: step 3, image 1 of 1
      • Remove the 4 screws using the T6 screw driver.
      Ask FixBot
    2. HTC Touch Pro CDMA Screen Replacement: step 4, image 1 of 2 HTC Touch Pro CDMA Screen Replacement: step 4, image 2 of 2
      • Lift the plastic cover near the memory card slot.
      Ask FixBot
    3. HTC Touch Pro CDMA Screen Replacement: step 5, image 1 of 1
      • Remove the two Phillips #00 screws from the backside of the screen.
      Ask FixBot
    4. HTC Touch Pro CDMA Screen Replacement: step 6, image 1 of 2 HTC Touch Pro CDMA Screen Replacement: step 6, image 2 of 2
      • Insert a spudger or a plastic opening tool into the seam on the side of the phone.
      • Gently pry apart the two halves of the phone.
      Ask FixBot
    5. HTC Touch Pro CDMA Screen Replacement: step 7, image 1 of 2 HTC Touch Pro CDMA Screen Replacement: step 7, image 2 of 2
      • Gently unplug the connectors.
      • Remove the screws with a 00 Phillips-head screwdriver.
      Ask FixBot
    6. HTC Touch Pro CDMA Screen Replacement: step 8, image 1 of 2 HTC Touch Pro CDMA Screen Replacement: step 8, image 2 of 2
      • Gently lift the motherboard up using a nylon spudger.
      • BE AWARE OF THE ANTENNA.
      Ask FixBot
    1. HTC Touch Pro CDMA Screen Replacement, Keyboard: step 9, image 1 of 2 HTC Touch Pro CDMA Screen Replacement, Keyboard: step 9, image 2 of 2
      • Remove the 4 screws circled in red using a 00 Phillips-head screwdriver.
      Ask FixBot
    1. HTC Touch Pro CDMA Screen Replacement, Screen: step 10, image 1 of 2 HTC Touch Pro CDMA Screen Replacement, Screen: step 10, image 2 of 2
      • Start by lifting the back plate of the screen by using yours finger or a plastic opener tool.
      Ask FixBot
    2. HTC Touch Pro CDMA Screen Replacement: step 11, image 1 of 1
      • Remove the 4 screws by using a 00 Phillips-head screwdriver.
      • Gently lift the connectors.
      Ask FixBot
    3. HTC Touch Pro CDMA Screen Replacement: step 12, image 1 of 1
      • Lift the front keyboard by removing the screws with a 00 Phillips-head screwdriver.
      Ask FixBot
    4. HTC Touch Pro CDMA Screen Replacement: step 13, image 1 of 3 HTC Touch Pro CDMA Screen Replacement: step 13, image 2 of 3 HTC Touch Pro CDMA Screen Replacement: step 13, image 3 of 3
      • With the front keyboard removed, gently lift the screen up with a plastic opener tool and remove it .
      Ask FixBot
3 other people completed this guide.
Author
with
Zhaowei Zhang
133 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 95
All Time: 4,265
