Up to 20% off select tools
HTC Touch LCD Screen Replacement
Views: 12K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
102
All Time:
11,602
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide instructs readers on how to replace the LCD Screen of a HTC Touch MP6900 smartphone.
The screen of a smartphone is crucial as it allows the user to interact with the phone without touching the internal electrical parts of the device. An individual might replace the screen of a smartphone for aesthetics or because cracks and wear have appeared on the original screen. LCD stands for liquid-crystal display, in simpler terms an LCD screen is the front touchscreen of the smartphone that the user interacts with.
Included is a description of how to remove the previous LCD Screen and replace it with a new LCD Screen. Follow the steps in order, then repeat them in reverse to reassemble your device with the new LCD screen.
Warnings before you begin:
  • Always be sure you are grounded whenever handling any of the circuit or logic boards. Find some advice on ways to ground yourself at this link. The internal areas of the smartphone include electrical circuits, so it is crucial to be grounded before beginning the replacement.
  • Also ensure that the device is not plugged in while you are working on it.
    1. HTC Touch LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
      • Remove the back panel by sliding it up.
      Ask FixBot
    2. HTC Touch LCD Screen Replacement: step 2, image 1 of 1
      • Remove the battery.
      Ask FixBot
    3. HTC Touch LCD Screen Replacement: step 3, image 1 of 1
      • Remove the 4 torx-head screws in the corners of the phone using the T5 Torx Screwdriver.
      Ask FixBot
    4. HTC Touch LCD Screen Replacement: step 4, image 1 of 2 HTC Touch LCD Screen Replacement: step 4, image 2 of 2
      • Use the plastic opening tool to remove the front panel from the phone.
      • Be sure to unplug the front button cable from the inside of the phone.
      Ask FixBot
    5. HTC Touch LCD Screen Replacement: step 5, image 1 of 1
      • Unscrew the 2 torx-head screws at the base of the LCD screen using the T5 Torx Screwdriver.
      Ask FixBot
    6. HTC Touch LCD Screen Replacement: step 6, image 1 of 2 HTC Touch LCD Screen Replacement: step 6, image 2 of 2
      • Separate the motherboard from the black plastic casing.
      • Unplug the black and red wire from the motherboard.
      • Unplug the black and red wire from the black plastic casing.
      Ask FixBot
    7. HTC Touch LCD Screen Replacement: step 7, image 1 of 1
      • Lift the black lever next to the orange ribbon cable to remove the LCD screen.
      Ask FixBot
Author
with
callum rowland
253 Reputation
2 Guides authored
Cal Poly, Team 15-12, Regan Spring 2011 Member of Cal Poly, Team 15-12, Regan Spring 2011
CPSU-REGAN-S11S15G12
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 102
All Time: 11,602
