Tools
Introduction
Go to step 1 ↓If your photos appear blurry or the camera lens is visibly cracked or scratched, replacing the camera lens on your HTC Touch can restore photo clarity. This guide will show you how to safely remove and replace the rear camera lens using basic tools.
Warning: Make sure you are grounded whenever handling a circuit or logic board.
Before you begin this repair, make sure to power off your phone and disconnect the charger.
Slide the back panel upward using the grip at the bottom until it releases.
Lift and remove the panel.
Use the plastic opening tool to remove the front panel from the phone.
Place a spudger or an opening tool under the edge of the press connector and pry straight up to disconnect it.
Remove the camera lens from the motherboard using the plastic opening tool.
You've successfully replaced your HTC Touch's camera lens! Test your camera to ensure the new lens works properly and your images are clear. To reassemble your device, follow these instructions in reverse order.
2 other people completed this guide.
