Up to 20% off select tools
HTC Thunderbolt Volume Buttons Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
90
All Time:
1,264
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓
Use this guide to repair the side volume buttons.
    1. HTC Thunderbolt Volume Buttons Replacement, Rear Panel: step 1, image 1 of 1
      • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
      • Gently pry up on the rear panel around the edges until it is loose.
      Ask FixBot
    2. HTC Thunderbolt Volume Buttons Replacement: step 2, image 1 of 1
      • Lift and remove the rear panel.
      Ask FixBot
    1. HTC Thunderbolt Volume Buttons Replacement, Battery: step 3, image 1 of 2 HTC Thunderbolt Volume Buttons Replacement, Battery: step 3, image 2 of 2
      • Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
      • Remove the battery from the inner frame.
      Ask FixBot
    1. HTC Thunderbolt Volume Buttons Replacement, MicroSD Card: step 4, image 1 of 2 HTC Thunderbolt Volume Buttons Replacement, MicroSD Card: step 4, image 2 of 2
      • Use your finger to push the MicroSD card in towards the top of the phone, allowing it to be released from the casing.
      Ask FixBot
    2. HTC Thunderbolt Volume Buttons Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to grab onto the MicroSD card and carefully remove it from the casing.
      Ask FixBot
    1. HTC Thunderbolt Volume Buttons Replacement, Rear Frame: step 6, image 1 of 1
      • Remove the six Phillips screws from the perimeter of the rear frame.
      • By removing the screw with the "void" sticker on it, your Thunderbolt will no longer be covered under warranty.
      Ask FixBot
    2. HTC Thunderbolt Volume Buttons Replacement: step 7, image 1 of 2 HTC Thunderbolt Volume Buttons Replacement: step 7, image 2 of 2
      • Insert the plastic opening tool into the bottom of the phone underneath the soft keys.
      • Gently pry up on the plastic cover by sliding the plastic opening tool across the bottom of the phone.
      • Remove the plastic cover.
      • The plastic cover will have adhesive on it making it difficult to remove.
      Ask FixBot
    3. HTC Thunderbolt Volume Buttons Replacement: step 8, image 1 of 1
      • Remove the two Phillips screws where the plastic cover was.
      Ask FixBot
    4. HTC Thunderbolt Volume Buttons Replacement: step 9, image 1 of 2 HTC Thunderbolt Volume Buttons Replacement: step 9, image 2 of 2
      • Insert the plastic opening tool in between the screen and the frame on the side of the phone.
      • Slowly slide the the plastic opening tool along the side of the phone until the screen begins to separate from the frame.
      • Do the same for the opposite side of the phone.
      Ask FixBot
    5. HTC Thunderbolt Volume Buttons Replacement: step 10, image 1 of 3 HTC Thunderbolt Volume Buttons Replacement: step 10, image 2 of 3 HTC Thunderbolt Volume Buttons Replacement: step 10, image 3 of 3
      • Carefully separate the screen and phone from the rear frame, starting from the bottom.
      • Gently pull down on the phone and screen to fully separate it from the rear frame.
      Ask FixBot
    1. HTC Thunderbolt Volume Buttons Replacement, Volume Buttons: step 11, image 1 of 1
      • Locate the side volume buttons
      Ask FixBot
    2. HTC Thunderbolt Volume Buttons Replacement: step 12, image 1 of 2 HTC Thunderbolt Volume Buttons Replacement: step 12, image 2 of 2
      • Use a pry tool to lift the buttons out of the case
      Ask FixBot
Author
with
Vanessa
60 Reputation
4 Guides authored
Cal Poly, Team 19-45, Regan Winter 2013 Member of Cal Poly, Team 19-45, Regan Winter 2013
CPSU-REGAN-W13S19G45
4 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 90
All Time: 1,264
