Up to 20% off select tools
HTC Thunderbolt MicroSD Card Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
6
Past 7 Days:
28
Past 30 Days:
101
All Time:
2,134
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Use this guide to remove the microSD prior to taking apart the rest of the device.
    1. HTC Thunderbolt MicroSD Card Replacement, Rear Panel: step 1, image 1 of 1
      • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
      • Gently pry up on the rear panel around the edges until it is loose.
      Ask FixBot
    2. HTC Thunderbolt MicroSD Card Replacement: step 2, image 1 of 1
      • Lift and remove the rear panel.
      Ask FixBot
    1. HTC Thunderbolt MicroSD Card Replacement, Battery: step 3, image 1 of 2 HTC Thunderbolt MicroSD Card Replacement, Battery: step 3, image 2 of 2
      • Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
      • Remove the battery from the inner frame.
      Ask FixBot
    1. HTC Thunderbolt MicroSD Card Replacement, MicroSD Card: step 4, image 1 of 2 HTC Thunderbolt MicroSD Card Replacement, MicroSD Card: step 4, image 2 of 2
      • Use your finger to push the MicroSD card in towards the top of the phone, allowing it to be released from the casing.
      Ask FixBot
    2. HTC Thunderbolt MicroSD Card Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to grab onto the MicroSD card and carefully remove it from the casing.
      Ask FixBot
Author
with
Vanessa
60 Reputation
4 Guides authored
Cal Poly, Team 19-45, Regan Winter 2013 Member of Cal Poly, Team 19-45, Regan Winter 2013
CPSU-REGAN-W13S19G45
4 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 28
Past 30 Days: 101
All Time: 2,134
